查看: 3775|回复: 0
[技术] 基于激光轮廓扫描仪的钢轨磨耗检测系统
发表于 2015-7-13 01:12:20 | 显示全部楼层 |阅读模式
基于激光轮廓扫描仪的钢轨磨耗检测系统
Application of Optical Profile Scanner in Rail Wear Detection
下载全文
基于激光轮廓扫描仪的钢轨磨耗检测系统.pdf (230.35 KB, 下载次数: 0)
作  者:王德明 王桂宝 张广明 孙冬梅
WANG De-ming, WANG Gui-bao, ZHANG Guang-ming, SUN Dong-mei  ( Nanjing University of Technology, Nanjing 211816, China)
机构地区:南京工业大学自动化与电气工程学院,江苏南京211816
出  处:《仪表技术与传感器》 CSCD 2014年第10期 90-91页,98页,共3页
Instrument Technique and Sensor
基  金:国家自然科学基金项目(51277092)
摘  要:当前我国钢轨检测主要采用的是人工检测方式,效率低下,精度和可靠性不高.为了解决以上问题,文中提出了一种基于二维激光轮廓扫描仪的钢轨磨耗检测系统.通过对钢轨外形的扫描,系统运用计算机图形处理技术生成钢轨轮廓,并采用最小二乘法计算出钢轨磨耗.实验证明该方法方便快捷,稳定性较好,能够满足铁路部门检测要求.
China's current rail testing which is mainly used in artificial detection is inefficient, and have low accuracy and reli- ability. In order to solve these problems, the paper based on CCD imaging and laser triangulation measurement principle is proposed based on two-dimensional laser scanner profile rail wear detection system. By scanning the shape of the rail, the system can generate rail contours by the use of computer graphics technology, and calculate the rail wear by the least squares method. Experiments show that this method is convenient, have better stability, and can meet the testing requirements of the railway sector.
关键词:激光三角测距 CCD成像 计算机图像处理
laser triangulation measurement ; CCD ; computer image processing ;
