查看: 4069|回复: 0
[技术] 不同波长激光对 CCD的干扰性实验研究
发表于 2015-7-13 01:18:09 | 显示全部楼层 |阅读模式
不同波长激光对 CCD的干扰性实验研究
Experimental study on interference characteristics of CCD at different laser wavelengths
下载全文
不同波长激光对 CCD的干扰性实验研究.pdf (2.4 MB, 下载次数: 1)
作  者:张超[1] 张伟[2] 王滨[2] 万勇[2] 薛亮平[2] 李燕凌[2]
ZHANG ChaoZHNAG Wei WANG Bin  WAN Yong XUE   Ltangping , LING Yanling ( 1. Military Representative Office in Chengdu, Fourth Department of the Headquarters of the General Staff, Chinese Peo- ple' s Liberation Army, Chengdu 610036, China ; 2. Southwest Institute of Technical Physics, Chengdu 610041, China)
机构地区:[1]中国人民解放军总参谋部四部驻成都地区军代室,成都610036 [2]西南技术物理研究所,成都610041
出  处:《激光技术》 CSCD 2014年第38卷第6期 826-829页,共4页
Laser Technology
摘  要:为了对比研究激光对可见光CCD的干扰效果,采用532nm,808nm和1064nm波长的激光对同一可见光CCD进行了干扰实验。结果表明,3种波长的激光对CCD都有一定的干扰效果,由于干扰波长、干扰功率、工作方式等不一样,干扰效果也存在差异。对于脉冲式激光器,532nm激光比1064nm激光具有更低的光饱和阈值;当各波长激光输出达到一定功率时,CCD会出现饱和串音的现象。此干扰实验为更好干扰CCD成像系统提供了一定的实验依据。
To study the laser jamming of CCD comparatively , three lasers at wavelengths of 532nm, 808nm and 1064nm were adopted in the jamming experiments .The experiments results reveal that the jamming of three lasers to CCD is effective .However , the jamming effect is different because of the difference of the jamming wavelength , the power and the working mode.For pulsed lasers, 532nm laser has the lower light saturation threshold than 1064nm laser.When the output laser power reaches a certain value , the saturation crosstalk phenomenon occurs in a CCD . It provides an experimental basis for better jamming against CCD imaging systems .
关键词:激光技术 激光干扰 饱和串音
CCD ;laser technique ;charge coupled devices ;laser jamming ;saturation cross-talk
