查看: 3264|回复: 0
[技术] 一种实现LED光源均匀照明的透镜设计
发表于 2015-7-13 01:30:31 | 显示全部楼层 |阅读模式
一种实现LED光源均匀照明的透镜设计
Lens Design for Uniform Illumination of LED Source
下载全文
一种实现LED光源均匀照明的透镜设计.pdf (925.64 KB, 下载次数: 6)
作  者:孙健刚[1] 朱孔硕[1] 马晓光[2] 李果华[1,2]
SUN Jiangang, ZHU Kongshuo, MA Xiaoguang, LI Guohua ( 1. School of Science, Jiangnan University, Wuxi 214122, China ;2. Nanjing Puguang New Energy Co. Ltd. , Nanjing 211899, China)
机构地区:[1]江南大学理学院,江苏无锡214122 [2]南京浦光新能源有限公司,江苏南京211899
出  处:《江南大学学报:自然科学版》 2015年第14卷第1期 121-126页,共6页
Journal of Southern Yangtze University:Natural Science Edition
摘  要:为解决大功率LED难以直接应用于照明的问题,设计了一款适用单芯片大功率LED的透镜,可在特定照明面上实现均匀照明。根据朗伯型光源辐射特性,采用折射和反射结构,先进行理论计算设计自由曲面面型,再利用Tracepro的交互式优化功能实现对透镜优化。优化得到的透镜经过软件模拟验证,在距离光源200 mm处直径为100 mm的目标照明面内照度均匀性优于87%;不考虑光能损失,光能利用率高于94%。
In order to solve the problem that high-power LEDs cannot be applied directly in the field of illuminating,a lens was specially designed for high-power LED to realize uniform illuminating. According to the Lambertian source specification,the structure of refraction and reflection was adopted. A systemic theoretical calculation for the free-form surface was introduced. Moreover by making use of the function of interactive optimizer in Tracepro,the lens was optimized. In the radiation circle area within 100 mm diameter at distance of 200 mm from light source,the optimized lens was simulated in Tracepro. Its uniformity of illumination precedes 87%. The efficiency can reach 94% without any loss.
关键词:发光二极管 交互式优化 均匀度
LED ; interactive optimizer ; uniformity ;
