查看: 3323|回复: 1
[技术] 单色LED的变温光谱特性研究
发表于 2015-7-13 01:35:53 | 显示全部楼层 |阅读模式
单色LED的变温光谱特性研究
Influence of Temperature on the LED Spectrum
下载全文
单色LED的变温光谱特性研究.pdf (180.94 KB, 下载次数: 3)
作  者:李莉君 熊永红
LI Lijun, XIONG Yonghong (School of Physics, Huazhong University of Science and Technology, Wuhan 430074, China)
机构地区:华中科技大学物理学院,武汉430074
出  处:《实验科学与技术》 2015年第13卷第1期 31-33页,共3页
Experiment Science & Technology
摘  要:运用自制的LED物性变温测量实验装置,在30℃~90℃的温度范围内,测试了单色LED的变温光谱。通过对光谱曲线的分析和计算,得出了被测LED的峰值波长和辐射通量随温度的变化规律,并从LED的结构与材料特性原理机制两方面作了分析与探讨。
Using homemade LED variable temperature measuring physics properties of experimental apparatus,at the temperature range from 30℃ to 90℃,the spectrum of monochrome LED was tested under the change of temperature. Through the analysis and calculation of the spectrum curve,LED peak wavelength and radiation flux were obtained and tested with temperature. The principle mechanism was analyzed and discussed from the LED structure and material properties.
关键词:发光二极管 变温 光谱 峰值波长 辐射通量
light emitting diode ; change of temperature ; spectrum ; peak wavelength ; radiant flux ;
发表于 2015-7-29 01:13:00 | 显示全部楼层
xie xie                ...
