查看: 3859|回复: 0
[技术] ZnO基柔性染料敏化太阳能电池的研究
发表于 2015-7-13 22:41:54 | 显示全部楼层 |阅读模式
ZnO基柔性染料敏化太阳能电池的研究
Flexible ZnO-based Dye-sensitized Solar Cells
下载全文
ZnO基柔性染料敏化太阳能电池的研究.pdf (786.57 KB, 下载次数: 0)
作  者:王艳香 周时俊 孙健 杨志胜 黄丽群
WANG Yanxiang,ZHOU Shijun,SUN Jian,YANG Zhisheng,HUANG Liqun (Jingdezhen Ceramic Institute, Jingdezhen 333403, Jiangxi, China)
机构地区:景德镇陶瓷学院,江西景德镇333403
出  处:《陶瓷学报》 2015年第36卷第1期 31-35页,共5页
Journal of Ceramics
基  金:国际科技合作专项(编号:2013DFA51000); 国家自然科学基金(编号:51102122); 江西省对外科技合作项目(编号:2010EHA02700)
摘  要:采用化学浴沉积法制备Zn O光阳极薄膜,并将所制备光阳极膜组装成柔性染料敏化太阳能电池。主要研究了沉淀剂的种类和沉淀剂的浓度对所形成的薄膜和电池性能的影响。采用XRD和SEM分别对薄膜的物相组成和显微形貌进行了表征。采用I-V测试系统对电池的光电性能进行测试。研究结果表明:沉积温度为80℃,六次甲基四胺(HMT)的浓度为0.30 M,硝酸锌(Zn(NO3)2·6H2O)浓度为0.1 M时,制备Zn O薄膜光电性能较好,所组装的柔性染料敏化太阳能电池的开路电压为0.60V,短路电流为2.57 m A·cm^-2,填充因子为0.72,效率为1.13%。
The flexible Zn O-based dye-sensitized solar cells were prepared by chemical bath deposition method. The effect of kind and concentration of precipitants on Zn O film microstructure and DSSC photoelectric performance were studied. The phase composition and microstructure of the Zn O films were characterized by SEM and XRD, respectively. The photoelectric performance of DSSCs was tested by I-V testing system. The results show: the cell using the Zn O film prepared with 0.3 M HMT and 0. 1M Zn(NO3)2?6H2O exhibited optimal performance under an AM-1.5 illumination. The Voc, Jsc, FF and PCE of the DSSC were 0.60 V, 2.57 m A·cm^-2, 0.72 and 1.13%, respectively.
关键词:柔性染料敏化太阳能电池 Zn O光阳极 化学浴沉积法 光电性
flexible dye-sensitized solar cell ; ZnO photoanode ; chemical bath deposition method ; photoelectric performance ;
本帖被以下淘专辑推荐:
