查看: 3896|回复: 0
[技术] 新型平板太阳能PV/T空气集热器传热特性的数值研究
发表于 2015-7-13 22:42:35 | 显示全部楼层 |阅读模式
Numerical Simulation of Thermal Performance of a New Type of Flat-Plate Solar PV/T Air Collector
下载全文
T空气集热器传热特性的数值研究.pdf (291.8 KB, 下载次数: 0)
作  者:孙健 徐银文 黄章峰 李杰
SUN Jian,XU Yinwen,HUANG Zhangfeng,LI Jie (Jingdezhen Ceramic Institute, Jingdezhen 333403, Jiangxi, China)
机构地区:景德镇陶瓷学院,江西景德镇333403
出  处:《陶瓷学报》 2015年第36卷第1期 78-82页,共5页
Journal of Ceramics
基  金:江西省对外科技合作项目(编号:20142BDH80024)
摘  要:文中设计了一款新型PV/T一体化空气集热器,建立了新型PV/T空气系统内部传热过程的一维非稳态数学模型,并利用差分法对模型进行了数值计算。根据计算结果对一体化系统的性能及影响因素进行了分析。结果表明:在一定的光照强度下,随着空气质量流量增加,电池板温度Tp逐渐下降,空气温升逐渐降低;而热效率、光电转化效率、联合效率随空气流量的增加有所升高。模型的建立为高性能太阳能PV/T一体化空气集热器的优化设计提供较好理论依据。
In this paper, a new type of integrated solar PV/T air collector is designed. A one-dimensional unsteady mathematical model is developed, the internal heat transfer process is calculated by finite difference approach. The performance of PV/T solar air collector is predicted under different parameters and conditions. Results indicate that the temperature of solar cell and outlet air decrease with the increase of air mass flow rate under the same incident solar intensity. Then, the thermal efficiency, electrical efficiency and total efficiency of PV/T system increase with the rising of the inlet air mass flow rate. The models provide valuable theoretical basis for the optimal design of highperformance solar PV/T integrated air system.
关键词:PV/T 数值模拟 耦合特性
PV/T ; numerical simulation ; coupled properties ;
本帖被以下淘专辑推荐:
