查看: 4389|回复: 0
[技术] 相变太阳能集热管放热特性的数值研究
发表于 2015-7-13 22:54:47 | 显示全部楼层 |阅读模式
相变太阳能集热管放热特性的数值研究
NUMERICAL STUDY ON THE HEAT RELEASE CHARACTERISTIC OF SOLAR THERMAL COLLECTOR WITH PHASE CHANGE MATERIAL
下载全文
相变太阳能集热管放热特性的数值研究.pdf (604.81 KB, 下载次数: 1)
作  者:肖桂菀[1] 穆迪[1] 赵恒谊[2] 沈延飞[3] 高乃平[1]
XIAO Gui-wan, MU Di, ZHAO Heng-yi, SHEN Yan-fei, GAO Nai-ping  (1. School of Mechanical and Energy Engineering, Tongji University, Shanghai 201804, China;  2. International Copper Association, Shanghai Representative Office, Shanghai 200092, China:  3. Himin Solar (Shanghai) Co. Ltd, Shanghai 200092, China)
机构地区:[1]同济大学机械与能源工程学院,上海201804 [2]国际铜业协会上海代表处,上海200092 [3]皇明太阳能(上海)有限公司,上海200092
出  处:《井冈山大学学报:自然科学版》 2015年第36卷第1期 25-29页,共5页
摘  要:采用计算流体力学(CFD)的方法分析了单根太阳能集热管的放热过程,讨论了热水管管材分别为316L不锈钢、黄铜、紫铜三种情况。结果表明,随着热水管导热系数的增大,单根太阳能集热管的放热速率没有明显提高。相变放热过程的主要传热热阻不是热水管的导热热阻,而是由固态相变材料(PCM)的导热系数低所致。
Computational Fluid Dynamics(CFD) method was used to analyze the heat release process of solar thermal collector with three different kinds of materials for hot water pipes, namely 316 L stainless steel, brass and copper. The results show that the heat release performance is not obviously improved when the thermal conductivity of hot water pipe is increased. Further discussion reveals that the main heat transfer resistance is caused by the low thermal conductivity of PCM in the solid state instead of the thermal resistance of hot water pipe.
关键词:相变传热 太阳能集热管 管材属性 相变材料 数值模拟
heat transfer with phase change ; solar thermal collector ; pipe properties ; phase change material ; numerical simulation ;
本帖被以下淘专辑推荐:
