发表于 2013-1-13 08:27:46
显示全部楼层
michael kors handbags 4 Tips to Overcome Your Prob
Ever wonder why gambling is so addicting,
coach factory outlet A Faster Method for Realizing Enlighten
? How you want to stop but something inside you just keeps you wanting more of it. How you just can't fight that urge even if your conscious mind already tells you it's bound to cause trouble. That's because gambling is designed to prey upon the subconscious, and once it gets its hold on you, it can escalate into a very destructive addiction,michael kors handbags.
And now that gambling can be done online, what's going to keep you from just playing and spending a whole lot of money on it?
Don't sabotage your own life. Control your problems with Internet gambling. Here are some tips:
1. Live without Internet connection. The first and most recommended course of action is for you to remove your Internet connection entirely, especially your home connection if you spend a lot of time playing online when you're at home. After all, the easiest way to keep yourself from temptation is to remove the source,
Some other styles i
2. Install a web filter. If you can't remove your Internet connection at home because you or other household members need it, your next best option is to install a web filter. This is ideal for those who find themselves online gambling even at the office. Since most offices require Internet connection for its operations, removing the connection is not an option. Thus, a web filter is the only way to block your access to online gambling websites.
3. Get hypnotherapy. If you want to seek professional treatment, one of the most effective techniques is hypnotherapy. You don't have to join support groups if you don't feel comfortable. Hypnotherapy sessions are done in private at a therapist's office. During the sessions, you will be hypnotized to a certain consciousness level so your subconscious becomes receptive and very sensitive to influence and reinforcement. What the therapist will do is to remove the subconscious fixation to Internet gambling from where it is rooted: your subconscious. <br
4. Watch subliminal videos daily. If you don't feel like getting treatment or you want to save money, you can also add an anti-gambling habit to your daily routine. Watching subliminal videos is an effective way of curing yourself from your problems with Internet gambling. This is an ideal treatment for most people since it does not just remove external triggers such as your Internet connection; it removes the urge from within you so even if you stay somewhere with an Internet connection available, you won't feel the need to gamble again.
This is also a highly preferable solution because it is affordable and can be done without anyone else knowing about your problems with Internet gambling. Also, you don't have to make time for it; you can just watch the videos every night before you sleep or whenever you have free time. The videos only last for just a few minutes. They are available for free trial download and affordable purchase online.
These subliminal videos work by making your conscious mind focus on images that are being flashed on your screen then sending hidden messages straight to your subconscious mind,michael kors outlet,
michael kors handbags 5 Clues to Getting A Guy Back
. The subliminal messages can go like this:
I am fully in control of my desires.
I decide how to spend my time.
I spend my time and money on important worthwhile things.
I have strong willpower and self-control,coach outlet store. |
