查看: 1952|回复: 1
LD前工艺中的ECR
发表于 2004-10-19 00:01:00 | 显示全部楼层 |阅读模式
小弟正在做ecr,就是电子回旋共振。
该仪器公司有说明如下:The system is designed to permit surface processing by an ECR generated plasma of up to quantity three, 2" diameter, or a single 5" wafer subject to temperature control and RF bias. Vacuum pressure in the main chamber is capable of reaching pressures less than 1x10-10m.bar with turbo-molecular pumping plus optional titanium sublimation pumping. Vacuum ports are available for diagnostic and gas introduction.
The system is installed as shown on a support table with 19" electrical rack and one power distribution panel. The electrical system will require extra power with customer supplied breakefor the ECR source to supply the 1 kW 208 VAC 1 phase, 15 Amp microwave source and two magnets requiring 208 VAC 3 phase, 20 Amp and 208 VAC 3 phase, 15 Amp. Vacuum integrity via a leak test to 2x10-10 Torr 1/sec He, along with sample transfer and heating, will be demonstrated.
不知各位大虾可有用过,若有,指点一二,不尽感激。
 楼主| 发表于 2004-10-20 23:01:00 | 显示全部楼层
