查看: 2224|回复: 3
zemax新版本(2004-9-28)的新增功能
发表于 2004-10-27 18:39:00 | 显示全部楼层 |阅读模式
<b><FONT size=4>September 28, 2004</FONT></b>
<P><B>New Features</B>
<OL type=1>
<LI>The Interferogram and all three Zernike Coefficient analysis features now support an option to reference the OPD to the surface vertex rather than the chief ray. This feature is useful for seeing the effects of tilt aberration that ZEMAX normally subtracts out.
<LI>Extension commands InsertConfig and DeleteConfig have been added.
<LI>The log scale feature is now supported on the true color Huygens PSF. </LI></OL>
<P><B>Bug Fixes</B>
<OL type=1>
<LI>Import of SAT objects was not working.
<LI>The "compact" display option for editor data was not working correctly.
<LI>ZPL macros with long lines could cause an error message and macro failure.
<LI>The convert to NSC tool did not properly convert toroids in mirror spaces.
<LI>A problem with using CONF and IMSF operands simultaneously in the merit function has been fixed. </LI></OL>
<P>
<B><FONT size=+1>September 21, 2004</FONT></B>
<OL type=1>
<LI>ZEMAX now automatically checks to see if an updated version of ZEMAX is available on our web site. ZEMAX Development Corporation will no longer send any update notices by email, since email is increasingly less reliable.
<LI>The Huygens PSF now can display a "true color" representation of the PSF. The wavelengths used are converted to their nearest RGB equivalent and used to make a realistic color image.
<LI>The ZEMAX Element Drawing has a number of improvements. The new buttons "Save As" and "Load From" allow all settings to be saved in separate files to help recreate drawings. The date is now a user editable field. The default note 1 regarding lens units can be replaced by a user defined note 1. The number of decimal places is now user selectable.
<LI>The Wavefront Map feature now optionally subtracts out tilt.
<LI>The Field Curvature/Distortion plot is now more clearly labeled. The distortion may now be shown as length or as a percentage.
<LI>The optimizations operands DIST, DISC, DISG, and DIMX now all support an option to use units of length rather than percent.
<LI>The last path specified for export graphics is remembered and used again as the default.
<LI>Decentered apertures on standard surfaces are now supported when converting to an NSC group.
<LI>An Annular Aspheric Lens NSC object has been added.
<LI>ZPL keyword SETNSCPROPERTY now controls values on the NSC object diffraction and bulk scattering tabs.
<LI>ZPL function MCON returns extended data from the multi configuration editor.
<LI>The optimization operand EFNO was added to compute Effective F/#.
<LI>Additional digits of precision are now displayed on the ray trace listing.
<LI>The default Abbe tolerance now uses a percent rather than a fixed specification.
<LI>ZPL macros now use considerably less memory than before, resulting in faster execution in some cases. </LI></OL>
<P><B>Bug Fixes</B>
<OL type=1>
<LI>Some rarely occurring problems with the POP orientation vector caused by round-off error were fixed.
<LI>Compound tilts and decenters on coordinate break surfaces were not handled correctly by the skew Gaussian beam feature.
<LI>A bug that could cause ZEMAX to lock up when an error message dialog was hidden from view has been fixed.
<LI>There was an index derivative bug in the GRIN10.DLL file used by NSC objects. </LI></OL>
发表于 2004-10-29 04:11:00 | 显示全部楼层
新版本的ZEMAX在非序列模式下的探测器仍然不够完善,仅能看到一个平面和探测器中间功率密度分布图,不能进行三维立体显示和数据分析,每次我都要把数据导到matlab里进行处理,像元取得大了处理起来累死人!
发表于 2004-10-29 04:57:00 | 显示全部楼层
不知道讯技有没有提供一些测评的可能?
比如针对常用的一些很耗时的功能,比如monte carlo公差分析,比较OSLO和Zemax的性能,这样比较有利于用户选择更为准确
 楼主| 发表于 2004-10-29 23:30:00 | 显示全部楼层
<DIV class=quote><B>以下是引用<I>小马过河</I>在2004-10-28 20:57:01的发言:</B>
<P>不知道讯技有没有提供一些测评的可能?</P>
<P>比如针对常用的一些很耗时的功能,比如monte carlo公差分析,比较OSLO和Zemax的性能,这样比较有利于用户选择更为准确</P></DIV>
<P>因为我们不是权威的测试机构,所以不方便做这种测试,不然对原厂是一种侵权。</P>
