查看: 4102|回复: 3
麻烦解释一下一个物理名词
发表于 2004-11-30 18:40:00 | 显示全部楼层 |阅读模式
费米能级
物理意义,以及定义
发表于 2005-1-26 17:26:00 | 显示全部楼层
你查一下原子物理这本书就可以得到详细而权威的解释了。
发表于 2005-12-30 22:45:00 | 显示全部楼层
任何一本有关半导体的书籍都会讲解的。
发表于 2006-1-3 01:41:00 | 显示全部楼层
在温度0 K,且一个原子不被授与能量时,最高层电子所在的能阶,就是费米能阶,而能量就是费米能量。
The Fermi Energy, which is synonymous with the electron chemical potential at T=0, represents the energy level that the next electron into the system must have, to be at the lowest possible freely-available state.
The Fermi level is the level at which the electron occupancy is 0.5 (or the highest filled level at 0 K).
The Fermi energy is the energy of the electrons in that level.
The highest energy level in the crystal that can remain populated by electrons at a temperature of Absolute Zero.
