查看: 1897|回复: 0
[供应] 等离子体专业分析厂商-北京佳诺贝科技有限责任公司网站更新
发表于 2016-3-22 15:59:22 | 显示全部楼层 |阅读模式
http://www.jnbt-plasma.com/index.html
欢迎大家点击查看,提供宝贵建议
sales@jnbt-plasma.com
新增产品
高精度超音速气体喷嘴-产地 日本
Speci?cation
1) LX-03R Fast Solenoid Valve Driver
   >Input Voltage 85~264V (AC)
   >Drive voltage 40-180V (Pulse)
   >ulse duration for excitation 0.1-99ms
   >ulse duration for negative voltage 0.1-10.1ms
   >Maximum Drive current:  35A
2) A2-6443 Fast Solenoid Valve
   >Out-let Aperture size  D=1.5 mm
   > Maximum working pressure 7MPa
   >Internal leakage: Less than  10 cm3/min   (Air at 7 Mpa)
   >External leakage ess than  1.33*10-6Pa*m3
/s He
   >Voltage : DC48V for driving armature (7~10 ms),
                    DC12V for keeping  armature position (0~10 ms)
   >Gas Connection : 1/4 inch Swagelok
   >Repetition 10Hz (Max)
3) MS05-XX-166 Wave-free slit nozzles
   > Nozzle Wall: designed by the Method of Characteristics
   > Exit slit size 1.2x XXmm)
   > Throat width: 120 micron with slit shape
   > Mach Number at Exit of nozzle : ~5 (for Helium, Argon).
欢饮来电来信咨询
catalog 2010E.pdf
875.67 KB, 下载次数: 0, 下载积分: 光电贝 -1 元
产品说明
