查看: 2424|回复: 3
[供应] 四川梓冠光电科技专业生产D2X2B光开关
发表于 2016-12-1 11:28:37 | 显示全部楼层 |阅读模式
Applications:
·Metropolitan area network
·Laboratory research
·System monitoring
·Dynamic configuration
points inserted multiplexing
Features:
Low insertion loss
Wide wavelength range
Low cross talk
High stability, reliability
Exclusive patent technology
Optical path without glue
    Latching or non-latching
Parameters
D2×2B
Wavelength range  nm
670~980
1260~1650
Testing wavelength  nm
670/785/850/980
1310/1490/1550/1625/1650
Insertion loss  dB
Typ:0.8  Max:1.2
Return loss  dB
SM≥50  MM≥30
Cross talk  dB
SM≥55  MM≥35
Polarization dependant loss dB
≤0.05
Wavelength dependant loss dB
≤0.25
Temperature dependant loss dB
≤0.25
Repeatability  dB
≤±0.05
Working voltage V
3.0 or 5.0
Lifetime times
≥107
Switching time   ms
≤8
Transmission power  mW
≤300
Operating temperature ℃
-20~+70
Storage temperature ℃
-40~+85
Dimension  mm
16
Wavelength range  nm
(L)27.0×(W)12.6×(H)8.0(公差±0.2)
可提供波长:
808nm 机械光开关
850nm 机械式光开关
915nm 机械式光开关
980nm 机械式光开关
1053nm机械式光开关
1064nm机械式光开关
1260nm机械式光开关
1310nm机械式光开关
1550nm机械式光开关
1650nm机械式光开关
 楼主| 发表于 2016-12-28 13:38:52 | 显示全部楼层
性能稳定,高低温方面实现重大突破18190010738
发表于 2017-1-22 09:15:28 | 显示全部楼层
可提供全波长,特殊波长光开关
大功率光开关,
保偏系列光开关,多模系列光开关,特殊光纤光开关等
咨询电话:18190010738
 楼主| 发表于 2017-4-1 15:27:37 | 显示全部楼层
咨询电话:18190010738
