查看: 2360|回复: 3
[供应] D1X2单模机械式光开关
发表于 2016-12-1 11:39:05 | 显示全部楼层 |阅读模式
【特点】
• Unmatched Low Cost
• Low Insertion Loss
• High Channel Isolation
• Highly Stability and Reliability
• Epoxy-Free Optical Path
• Latching or Non-Latching
【应用】
• Optical Signal Routing
• Optical Network Protection/Restoration
• Transmitter and Receiver Protection
• Network Test System
• Instrumentation
• Configurable Optical ADD/DROP
Model number
Unit
D1×2
Wavelength range
nm
1260-1650
Testing wavelength测试波长(可选)
nm
1310/1490/1550/1625
Insertion loss
dB
Typ:0.5  Max:0.8
Return loss
dB
≥50
Cross talk
dB
≥55
Polarization dependant loss
dB
≤0.05
Wavelength dependant loss
dB
≤0.25
Temperature dependant loss
dB
≤0.25
Repeatability
dB
≤±0.02
Operating voltage
v
3.0 or 5.0
Lifetime
≥107
Switching time
ms
≤3
Transmission time
mw
≤500
Operating Temperature
-40~+80
Storage temperature
-40~+85
Weight
g
16
Dimension
mm
(L)27.2×(W)12.8×(H)8.5(公差±0.1~0.2mm)
 楼主| 发表于 2016-12-28 13:57:07 | 显示全部楼层
光开关产品,有需求可以联系我哦,  我可以提供样品测试18190010738
发表于 2017-1-22 09:23:39 | 显示全部楼层
四川梓冠光电科技有限公司原四川超光通信有限公司
可提供全波长,特殊波长光开关
大功率光开关,
保偏系列光开关,多模系列光开关,特殊光纤光开关等
咨询电话:18190010738(杨浩)
发表于 2017-3-15 09:27:00 | 显示全部楼层
四川梓冠光电(原四川超光)供应mems光开关。量大价优,质量保证
