查看: 2060|回复: 2
[供应] 超低温工作APD
发表于 2016-12-12 13:40:54 | 显示全部楼层 |阅读模式
Butterfly APD Receiver
ZGBxA1-701x-00
Description
The product integrates a high linearity InGaAs APD with TEC and thermistor, Low dark current, High linearity, High responsivity
Features:
Long wavelength operation
Package: 8pin & 14pin butterfly package
Built-in thermistor, and TEC
Low dark current
Excellent reliability compliance to GR-468-CORE
Compliance to RoHS standard
Applications
Optical fiber sensor system
Optical fiber communications system
Absolute Maximum Ratings
Parameter
Symbol
Min
Max
Unit
Condition
Operating Case Temperature
Tc
-40
85
°C
Storage Temperature
Tstg
-40
85
°C
Reverse Voltage
Vr
Vbr
V
Thermoelectric cooler voltage
VTEC
2.6
V
Forward current
5
mA
Reverse current
2
mA
Lead solder Temperature
260
°C
Lead Soldering Time
10
s
Optical/Electrical Characteristics (T=25℃,unless otherwise stated)
Parameter
Symbol
Min
Typ
Max
Unit
Test Conditions
Optical Wavelength
λ
1100
1650
nm
Breakdown Voltage
Vbr
40
48
53
V
Id=10uA;Tc=25℃~-20℃
Dark Current
Id
50
nA
Tc=25℃;VR=0.9Vbr
Responsivity
Re
0.85
A/W
λ = 1550nmM=125°C
Tc=25℃~-20℃
TEC Current
Itec
1500
mA
Tc=25℃; VR=0.9Vbr
Cutoff frequency
fc
2.0
3.5
GHz
Tc=25℃; VR=0.9Vbr
Capacitance
C
0.38
0.5
pF
f = 1MHz; Vr = 0.9 Vbr
Thermistor Resistance
RT
9.9
10
10.1
kΩ
@25℃
Thermistor B-Value
3950
K
25/85
Dimensions and Pin Description
Dimensions are in millimeters. All dimensions are ±0.1mm unless otherwise specified.
8pin butterfly package
Pin
Description
1
TE Cooler (+)
2
Thermistor
3
Thermistor
4
APD (P)
5
APD  (N)
6
NC
7
NC
8
TE Cooler (-)
 楼主| 发表于 2016-12-30 13:29:41 | 显示全部楼层
2016即将结束感谢大家的支持。2017年我们共同携手共进。
 楼主| 发表于 2017-2-16 10:56:22 | 显示全部楼层
专业生产,,自主封装。。欢迎来电咨询。。。
