查看: 1900|回复: 1
[供应] 简易激光器驱动
发表于 2016-12-12 13:45:35 | 显示全部楼层 |阅读模式
Applications:
Optical fiber component manufacture & test
Laser parameters test system
R & D and lab application.
Compatible with PUMP and DFB butterfly package
Features:
Auto Current Control
Auto Temperature Control
Dynamic monitoring laser test data
LCD display
Specifications:
Parameters
Positive drive
Negative drive
Max bias current(ma)
1000
350
Temperature control range(℃)
15~45
15~45
TEC Temperature Stability(℃)
≤ 0.01
≤ 0.01
Bias current stability(8 hour)
0.5%
0.8%
Wavelength stability  (pm)
10
8
Serial interfaces
(SPI  /I2C  /RS-232) to Host System
Display
LCD display
Power supply
8-40V DC / 2A
Operating temperature (℃)
0 ~ +65
Storage temperature (℃)
-20 ~+70
Dimensions (L×W×H mm)
100×100×70
Order informations:
LD
Type
Dived Laser
M=Module
D=Desk-top
D=DFB
P=Pump
S=SLED
A=SOA
 楼主| 发表于 2017-2-22 09:49:49 | 显示全部楼层
四川梓冠光电激光器,激光器驱动生产供应,。欢迎来电咨询。
