查看: 5654|回复: 5
[原创] 智能电表、水表等测量仪器爱普生晶振选型指南
发表于 2017-2-9 09:21:03 | 显示全部楼层 |阅读模式
爱普生晶体晶振在无线通讯领域的应用
33 秒前 上传
下载附件 (29.67 KB)
EPSON晶振FC-135
Block
Function
Epson Products
Function
Category
Model
Description 1
Description 2
A
Transceiver
Ref. Clock
Crystal Unit
FA-20H
FA-128
FA-118T
16.0MHz, 20MHz, 26.0MHz, 37.4MHz, 38.4MHz, 40.0MHz, 48.0MHz
Crystal unit for WiFi, BT
A
Transceiver
Ref. Clock
Crystal Unit
FA-20HS
FA-128S
19.2MHz, 26.0MHz, 38.4MHz, 52.0MHz
Crystal with Thermistor for GPS and Cellular
A
Transceiver
Ref. Clock
VC-TCXO
TG-5006CJ
For Cellular RF
A
Transceiver
Ref. Clock
TCXO
TG-5006CJ
16.368MHz, 26.0MHz, 37.4MHz, 38.4MHz, 40.0MHz
For GPS and WiFi
B
Base Band
PMIC (RTC)
Crystal Unit
FC-135
FC-12M
FC1610AN
32.768kHz
C
Base Band
MCU
Crystal Unit
FA-20H
FA-128
FA-118T
24MHz, 24.576MHz
爱普生晶体振荡器、谐振器、时钟芯片在示波器中的应用
33 秒前 上传
下载附件 (24 KB)
MC-146
Block
Function
Epson Products
Function
Category
Model
Description 1
Description 2
A
CLK Generator
Clock
SPXO
SG-210STF
12.288MHz, 15.36MHz, 19.44MHz, 25MHz
B
CLK Distribution
Jitter clean
VCXO
VG-4501CA
122.88MHz
APR:+/-20ppm Min.
C
MCU
Clock
OSC
SG-8003CG
SG-8003CE
SG-8003LB
SG-8003CA
SG-8003JF
20MHz, 27MHz, 30MHz etc.
D
MCU
RTC
Crystal unit
MC-146
FC-135
32.768kHz
D
MCU
RTC
Built in
Crystal Unit
RX6110SA
RX8010SJ
I2C, SPI
E
Ethernet(LAN)
Clock
SPXO
SG-210STF
25MHz, 50MHz
E
Ethernet(LAN)
Clock
Crystal unit
FA-238
25MHz, 50MHz
F
USB
Clock
SPXO
SG-210STF
12MHz, 24MHz, 48MHz
F
USB
Clock
Crystal unit
FA-238
FA-238
12MHz, 24MHz, 48MHz
G
Reference CLK
Ref Clock
OCXO
(contact us)
10MHz
爱普生频率元器件在Smart Meter(智能电表)领域的应用
34 秒前 上传
下载附件 (24.77 KB)
FA-20H
Block
Function
Epson Products
Function
Category
Model
Description 1
Description 2
A
MCU
Clock
Crystal unit
MA-406
FA-238
4MHz, 8MHz, 12MHz
B
MCU
RTC
Built in
Crystal unit
RX6110SA
I2C & SPI
Low Power
B
MCU
RTC
Built in
Crystal unit
RX-8803SA
RX-8803LC
I2C
Hight stability
B
MCU
RTC
Built in
Crystal unit
RX-4803SA
RX-4803LC
SPI
Hight stability
C
Communication unit
W-PAN
Crystal unit
TSX-3225
FA-20H
FA-128
26MHz, 30MHz, 32MHz
C
Communication unit
W-PAN
TCXO
TG-5021CG
TG-5021CE
TG-5006CJ
TG-5006CG
TG-5006CE
26MHz, 30MHz, 32MHz
C
Communication unit
W-LAN
Crystal unit
TSX-3225
FA-20H
FA-128
26MHz, 30MHz, 32MHz
D
Ethernet
Clock
SPXO
SG-210STF
25MHz, 50MHz
D
Ethernet
Clock
Crystal unit
FA-238
25MHz, 50MHz
以上资料经专业的晶振供应商-上海唐辉电子整理,公司作为EPSON的代理商,可提供各种常用标准频率值,各种片式规格尺寸的常用型号晶振,并提供专业的晶振选型指导,为客户提供100%的原装正品。
发表于 2017-2-15 16:02:54 | 显示全部楼层
很全很强大,顶一个。
发表于 2017-7-12 08:54:30 | 显示全部楼层
发表于 2017-12-20 09:54:08 | 显示全部楼层
发表于 2017-12-22 09:08:13 | 显示全部楼层
发表于 2018-1-9 11:14:30 | 显示全部楼层
