<P>用CODE V做公差分析时,操作数DLF和DLR感觉好像表示的都是曲率半径的公差,只不过表现手段不一样,手册解释为:</P>
<P>DLF:Tolerance(s) on test plate fit (in fringes at FRW wavelength) over the clear aperture for each of the designated surface(s) Sk|Si..j, for all zoom positions. You can also specify X and Y offsets with respect to the vertex (i.e., center or origin) of the designated surface(s). </P>
<P>DLR:Tolerance(s) on radius for each of the designated surface(s) Sk|Si..j, for all zoom positions. DLR, DLS and DLC are alternate forms of surface power tolerance; not active on plano surfaces, often used to indicate the tolerance on the testplate radius. You can also specify X and Y offsets with respect to the vertex (i.e., center or origin) of the designated surface(s). </P>
<P>但是根据数值观察两者好像不是简单的光圈数与光程差的对应关系,请问两者之间有什么本质不同</P>
<P>redflag,您好,谢谢您的回答,我也觉得是一样的,但是在下面的例子中,各个面的DLF是一样的,但是DLR却有较大差别,下面是一个公差分析的部分结果:</P><P> TOLERANCES
On Surfaces 0 to 7
( 53 total)
TOL
# TYPE VALUE
1 DLF S1 2.0000000 v
2 DLF S2 2.0000000 v
3 DLF S3 2.0000000 v
4 DLF S4 2.0000000 v
5 DLF S5 2.0000000 v
6 DLF S6 2.0000000 v
7 DLR S1 0.0600000 v
8 DLR S2 0.4000000 v
9 DLR S3 0.0200000 v
10 DLR S4 0.0800000 v
11 DLR S5 14.0000000 v
12 DLR S6 0.0200000 v
13 DLT S1 0.0800000 v
14 DLT S2 0.0200000 v
15 DLT S3 0.0200000 v
16 DLT S4 0.0200000 v
17 DLT S5 0.0200000 v</P><P>..............</P><P>请问,这是为什么?谢谢</P>
