查看: 3469|回复: 13
帮忙看看6-60变焦的结果
发表于 2005-1-23 04:32:00 | 显示全部楼层 |阅读模式
<img src="data/attachment/forum/dvbbs/2005-1/200512220315341.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'data/attachment/forum/dvbbs/2005-1/200512220315341.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="data/attachment/forum/dvbbs/2005-1/200512220321468.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'data/attachment/forum/dvbbs/2005-1/200512220321468.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="data/attachment/forum/dvbbs/2005-1/2005122203226197.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'data/attachment/forum/dvbbs/2005-1/2005122203226197.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="data/attachment/forum/dvbbs/2005-1/2005122203240376.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'data/attachment/forum/dvbbs/2005-1/2005122203240376.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
帮忙看看6-60变焦的结果
发表于 2005-1-24 16:31:00 | 显示全部楼层
你给的曲线太那个了吧,有谁看得出. 另不知你的这个是做什么用的.只有MTF曲线也是不够的.
 楼主| 发表于 2005-1-24 19:19:00 | 显示全部楼层
<P>哦,一般的监视镜头,那需要提供那些指标可以给出评价,帮忙指点啊</P>
发表于 2005-1-24 19:26:00 | 显示全部楼层
<P>你将MTF频率设小点</P>
发表于 2005-1-24 22:32:00 | 显示全部楼层
你把频率设置到80/MM左右,我们才能看清楚,并大相差看这个好象不能完全确定的.看你后面CCD的象素的大小,最好RSM半径不大于一个象素的直径.
发表于 2005-1-24 23:32:00 | 显示全部楼层
各图对应的视场、口径及焦距?
 楼主| 发表于 2005-1-25 02:16:00 | 显示全部楼层
先看看MTF F#=1.6~2.8
发表于 2005-1-26 03:16:00 | 显示全部楼层
从这图上看的话,第二个可以用
发表于 2005-1-26 17:41:00 | 显示全部楼层
只是MTF圖是不夠的吧,其他的象差圖呢?2D圖?
发表于 2005-1-27 01:22:00 | 显示全部楼层
如此大的变焦,给ccd用的,分辨率到100lp/mm应该够了吧。
 楼主| 发表于 2005-1-27 20:01:00 | 显示全部楼层
只是一般监视镜头用的,如果还需要象差图我改天传上来,还请各位指点一二.
发表于 2005-1-28 21:57:00 | 显示全部楼层
一般来说50线对的空间频率足已,还有就是设置多重配置(multi configuration), 视场用像面尺寸来定,不是用入射角度,这样的话不管如何变焦,像面尺寸都是一样的,像你这样,每个都重新算,太麻烦啦,不过从设计结果来看,光学系统的分辨率足够啦,50lp/mm处的MTF在0.5左右,考虑光学系统的加工装调误差和CCD本身的MTF,最后的MTF达到0.2以上不成问题。
