查看: 1926|回复: 2
求购激光管
发表于 2005-1-27 08:10:00 | 显示全部楼层 |阅读模式
请问哪里可以买到这样的激光
Laser wave length: 632.8 nm Output power: 7 mW Polarization: linear polarized 500 : 1 Beam waist: 0.76 - 0.84 mm (1/e2) Beam divergence: approx. 0.96 mrad Longitudinal mode spacing: 438 Mhz nominal Warm up time: 15 min (90 % power level) Output power stability: 2.5 % / 8 h long time drift Operating voltage: 2350 ± 200V Operating current: 6.5 mA Operating temperature: +15°C to +50°C Storage temperature: -40°C to +80°C Relative humidity: 0 to 90 % Weight: approx. 700 g Life time: 20000 h
发表于 2005-1-27 19:45:00 | 显示全部楼层
你可以联系北京大学物理系 010-62751753
 楼主| 发表于 2005-1-27 22:07:00 | 显示全部楼层
好的,谢谢你了。
