CWL: 1064.0 +/- 0.5 nm
FWHM: 1.0 +/- 0.4 nm
Transmission: 40% min. peak
Blocking: OD 4 from 200 to 1150 nm
Flatness: 3-5 waves per inch or better
Parallelism: 3-5 arc minutes or better
Surface Quality: 80/50 scratch/dig
Dimensions: 25.0 +/- 0.12 mm diameter, 21.0mm min.clear aperture,8.0 mm max.thickness
all specs. at room temp and normal A.O.I.
labitzk@126.com
该Ultra narrow band filter 如果要求峰值大于95%以上还是有点难度的,90%左右较好做。
