Accession Number: 786393
Document type: Journal Paper
Title: [B]Optical surface roughness determination using speckle correlation technique [/B]
Author(s): Leger, D., Mathieu, E., Perrin, J.C.
Source: Applied Optics vol.14, no.4 : 872-7 , April 1975
Language: English
Treatment: Theoretical or Mathematical, Experimental
Abstract: In the method described, a rough surface is illuminated successively from different directions by a laser beam (HeNe). Two speckle patterns are produced and their correlation depends on the surface roughness. The patterns are recorded on the same film by double exposure. Correlation is deduced by measurements of the visibility of Young fringes. Theory of the method is given and experimental results are described.
Controlled Indexing: light interferometry, surface measurement, surface texture
Uncontrolled Indexing: optical surface roughness determination; speckle correlation technique; laser beam; double exposure; Young fringes
Classification Code(s):
A0630C Spatial variables measurement
A0760L Optical interferometry
A4220 Optical propagation and transmission in inhomogeneous media
A6820 Solid surface structure
Author Address: Centre Etudes Recherches, Le Bourget, France
Number of References: 13
Abstract Number: A75052398
CODEN: APOPAI
ISSN: 0003-6935 [0 records marked]
(Save, Export, E-mail, Order, Print)
Create Citation Alert
Receive e-mail alerts on future
citations to this record.
(Requires registration.)
View record in
Web of Science
