2005-8-9 22:08:00 | 显示全部楼层 | 阅读模式
请问高手们ZEMAX可以计算反射率吗?在COATING 里设置以后为什么不变呢?
2603查看3回复
2005-8-13 09:01:00
<P>ZEMAX coating model is the simplified one. If you want more accurate reflection spectrum, better use the film design software. So the throughput simulated in ZEMAX is only a referance data, which is open for negotiation with the vendor.</P>
<P>-mdfremont</P>
2005-8-15 05:30:00
两层膜的非垂直反射可以计算吗?
2005-9-1 00:22:00
怎么没人回复呢?我自己编的coating,结果是错的.高手们指点一下吧.谢谢!
