查看: 1927|回复: 3
ZEMAX玩家请进
发表于 2005-8-12 19:35:00 | 显示全部楼层 |阅读模式
<P>各位ZEMAX玩家:我有一个问题想用ZEMAX来模拟,结果总不如意,不知各位是否有什么变通的办法?请赐教!</P>
<P>我的问题是这样的:</P>
<P>每个人可能都曾经在带反光的圆柱前站立过,一定曾看到过柱子里面变形的自己,变形的大小当然与圆柱的半径有关。如何通过ZEMAX来真实地模拟自己眼中看到的自己呢?</P>
<P>请各位能模拟出来的将图片贴上来。谢谢!</P>
发表于 2005-8-13 08:55:00 | 显示全部楼层
<P>This is a complicated model. IMHO, you could model a imaging system with extended source and a cylindrical reflecting surface.The extended source is your body, the imaging plane will be placed at the location of the source. Then you could get a distorted imaging. The issue is the imaging your eyes viewed. This make the system a complicated one. I think you could insert human eyes optical model into your system just in front of your iris and at the location of the extended source. You will find that the system is a tilted system with the limitation of the eyes FOV. This could be starting point.</P>
<P>-mdfremont</P>
 楼主| 发表于 2005-8-14 04:20:00 | 显示全部楼层
<P>Hi,mdfremont,</P>
<P>how about posting your simulating result? can you get a right result?</P>
发表于 2005-9-2 22:37:00 | 显示全部楼层
这个应该很简单,用一个圆柱反射面就可以
