查看: 4664|回复: 8
How output these diagram in CODE V?
发表于 2005-10-7 23:55:00 | 显示全部楼层 |阅读模式
2BvgAxja.pdf (15.61 KB, 下载次数: 66)
1.Relative Illuminance
2.Chief ray angle Vs. Image height
3.TV Distortion
[此贴子已经被作者于2005-10-7 15:56:33编辑过]
发表于 2005-10-8 04:37:00 | 显示全部楼层
除了最后一个,其它的都需要编写宏才能实现.
 楼主| 发表于 2005-10-8 16:42:00 | 显示全部楼层
<P>谢谢,网上那能找到这种宏?</P>
发表于 2005-10-8 17:00:00 | 显示全部楼层
 楼主| 发表于 2005-10-10 15:59:00 | 显示全部楼层
<P>Redflag:</P>
<P>Sorry,我看不懂,能否细说?</P>
发表于 2005-10-10 20:24:00 | 显示全部楼层
送你一个宏,现主光线在像面上的入射角度的。相对亮度的可以修改此宏实现。 更多的分析都需要自己动手去实现。
在网上,别人可以帮助你,但对自己而言,需要更多的时间去学习,而不是索取答案。
! Sequence: TELEPLOT.SEQ
! Purpose: Macro to plot INCIDENT RAY ANGLE
! Syntax: in TELEPLOT
! Author: Doffey Date: 2005-10-08
! History: 2003-07-15
! arg0 "Plot the Incident angle on the Image surface"
! arg1 name "Maximum Incident angle"
! arg1 type num
! arg1 default 30
! arg1 help "Maximum Incident angle"
! arg2 name "Plot Grid?"
! arg2 type str
! arg2 choice "Yes" "No"
! arg2 default "Yes"
! arg2 help "Plot Grid On the Graph?"
rfd 30 y
lcl num ^numfld ^i ^j
lcl num ^fld(25) ^reli(25)
lcl str ^dim
lcl num ^maxfld
lcl str ^plot_grd
^plot_grd == rfstr(2)
^plot_grd == substr(upcase(^plot_grd),1,1)
if ^plot_grd "N"
^plot_grd == "Y"
end if
ver n
out n
^numfld == (num f)
!********** 可以扩展采样密度,使画出的曲线更准确 *****************************
!if (typ fld)="ANG"
! ^maxfld == (yan f^numfld)
!else if (typ fld)="OBJ"
^maxfld == (yob f^numfld)
!else if (typ fld)="IMG"
^maxfld == (yim f^numfld)
!else if (typ fld)="RIH"
! ^maxfld == (yri f^numfld)
!else
! ^maxfld == 0
!end if
!^f=='f'
!save
!del fa
!for ^i 1 20
!ins f^i+1
!^f==concat(^f,num_to_str(^i+1))
!in cv_macrcvsetfield Y ^i*^maxfld/20 $f
!^f=='f'
!end for
^numfld == (num f)
for ^i 1 ^numfld
if (typ fld)="ANG"
^fld(^i) == (yan f^i)
^fld(^i) == (yob f^i)
^fld(^i) == (yim f^i)
^fld(^i) == (yri f^i)
else
^fld(^i) == 0
end if
end for
out y
wri "Calculating the Incident Rany angle..."
wri
wri " Field Incident Ray angle"
for ^i 1 ^numfld
wri Q" 'dd.ddd' 'dd.ddd'" ^fld(^i) (aoi si w2 r1 f^i)
end for
out n
! plot the Incident ray angle vs Field curves using UGR
ugr
tit substr((tit),1,40)
if (dim)="I"
^dim == " (inches)"
else if (dim)="M"
^dim == " (mm)"
else if (dim)="C"
^dim == " (cm)"
else
^dim == ""
end if
if (typ fld)="ANG"
xla "FIELD ANGLE"
xla concat("OBJECT HEIGHT",^dim)
xla concat("IMAGE HEIGHT",^dim)
xla concat("REAL IMAGE HEIGHT",^dim)
else
end if
yla "INCIDENT RAY ANGLE"
xax 0 ! x and y cross at zero
if ^plot_grd = "Y"
xde grd (^fld(^numfld))/10
els
xde (^fld(^numfld))/10
end if
yax 0
ymi 0 ! MTF range 0-1 by 0.1
yma #1
if ^plot_grd = "Y"
yde grd 1
els
yde 1
end if
yfo f 1 ! number formats for labels
xfo f 2
! create data point sets
dpo 'R1 (Chief Ray)'
spl 1 red
for ^i 1 ^numfld
end for
end
^str == num_to_str(#1)
^str == concat(^str, " DEGREE")
DPO ^str; LIN 6 blu;
0 0;
^fld(^numfld) #1;
0 #1;
END
go
GOT END
wri
lbl ER
out y
wri "ERROR: buffer error,Please check your lens!"
out n
lbl END
!res
ver y
OUT YES
 楼主| 发表于 2005-10-10 22:30:00 | 显示全部楼层
<P>Thank you! </P>
<P>这个已运行成功,我可以借此研究研究啦!</P>
发表于 2009-7-30 13:39:34 | 显示全部楼层
This document related to my current job. Thanks for the sharing!
发表于 2009-12-13 19:57:10 | 显示全部楼层
不错,看来要好好学习了,
