查看: 1790|回复: 0
我们新代理的激光技术
发表于 2005-10-25 00:19:00 | 显示全部楼层 |阅读模式
Laser Diode Submounts are used for the fiber optic industry.  Many companies use Aluminum Nitride(ALN) material to thermally dissipate heat out of the Laser.  It is usually mounted on the TOP of the circuit.  We put Gold Tin(Au/Sn) on the circuit so all they have to do is heat up the part up to 280C and the Au/Sn will flow and attach the component that they mount on our substrate.  Usually an operator will put an Au/Sn preform on the circuit and manually put the Laser on the substrate and attach with this method.  This has a high labor content.
With the Au/Sn already on the substrate all they have to do is us a pick and place machine in place and they can automate this!
各位大虾,这是我们新代理的产品,如果您感兴趣请与我们联系。南京傲文科技,E-mail:sales@allwintek.com
