查看: 1578|回复: 0
代理美国ATP的产品
发表于 2005-10-25 17:52:00 | 显示全部楼层 |阅读模式
Laser Diode Submounts are used for the fiber optic industry.  Many companies use Aluminum Nitride(ALN) material to thermally dissipate heat out of the Laser.  It is usually mounted on the TOP of the circuit.  We put Gold Tin(Au/Sn) on the circuit so all they have to do is heat up the part up to 280C and the Au/Sn will flow and attach the component that they mount on our substrate.  Usually an operator will put an Au/Sn preform on the circuit and manually put the Laser on the substrate and attach with this method.  This has a high labor content.
With the Au/Sn already on the substrate all they have to do is us a pick and place machine in place and they can automate this!
激光器二极管广泛应用于光纤产业。很多公司都运用氮化铝材料驱散激光器的热量。它通常被裱在电路顶部。我们将金锡合金置于电路上面,它们的作用是使局部加热到280摄氏度,这时金锡合金将会溶化流动,并且贴缚在电路上。通常操作人员会将金锡合金的粗加工成品置于电路上,然后把激光器放在底部并用同样的方法贴缚好。金锡合金置于感光底层后,我只需将其放于一定构造上,它将自动操作。
翻译有不准的地方请指出,谢谢
如果有需要请与我们联系:sales@allwintek.com 南京傲文科技有限公司 我们的网站:www.allwintek.com
