查看: 1737|回复: 2
Question about TIR......
发表于 2005-11-16 09:39:00 | 显示全部楼层 |阅读模式
<>First,I am sorry I can input English only</P>
<>Question:</P>
<>  In the merit funciton Editor Uptating,it always warns:TIR on the image plane.Hence,the optimization process can not work.As a result the merit value is always very large~~~</P>
<>  I don't know how to solve this problem.If anyone knows,will you help me? Thanks a lot:)</P>
发表于 2005-12-22 07:27:00 | 显示全部楼层
my question are the same .fast fast come help me!!!
发表于 2006-1-3 21:20:00 | 显示全部楼层
发生了全反射就不能计算了,你可以把这个面的曲率半径改大一点
