查看: 1765|回复: 2
MTF optimization by “User-Defined Constraint”
发表于 2005-11-29 06:51:00 | 显示全部楼层 |阅读模式
When I use MTF error function type, I can get different MTF distribution of different fields by changing the weights of MTF in different fields, but I can’t get exact MTF value I want. How can I optimize MTF by using “User-Defined Constraint” ?
发表于 2005-11-29 18:10:00 | 显示全部楼层
MTF优化并不能得到精确的数值,因为有多个像差在平衡,你的系统必须有能力达到你的目标值。
 楼主| 发表于 2005-12-3 18:27:00 | 显示全部楼层
<FONT face="Times New Roman" size=4>
<P 0cm 0cm 0pt">Thanks a lot.  In addition, could it be possible to write a macro (“User-Defined Constraint” type) to calculate MTF?</P></FONT>
