查看: 7122|回复: 9
[求助]请问在ZEMAX中是否可以可以模拟高斯光束的传播??
发表于 2005-12-7 23:08:00 | 显示全部楼层 |阅读模式
该怎么设置?谢谢!!
发表于 2005-12-7 23:35:00 | 显示全部楼层
帮助中有详细说明。
Paraxial Gaussian Beam
Computes Gaussian beam parameters.
Wavelength: The wavelength number to use for the calculation.
M2 Factor: The M2 quality factor used to simulate mixed mode beams. See the Discussion.
Waist Size: The radial size of the embedded (perfect TEM00 mode) beam waist in object space in lens units.
Surf 1 to Waist: The distance from surface 1 (NOT the object surface) to the beam waist location. This parameter will be negative if the waist lies to the left of surface 1.
Update, Orient, Surface: See below.
Discussion: This feature computes ideal and aberrated Gaussian beam data, such as beam size, beam divergence, and waist locations, as a given input beam propagates through the lens system. This discussion is not meant to be a complete tutorial on laser beam propagation theory. For more information on Gaussian beam propagation, see one of the following references: "Lasers", A. E. Siegman, University Science Books (1986), "Gaussian beam ray-equivalent modeling and optical design", R. Herloski, S. Marshall, and R. Antos, Applied Optics Vol. 22, No. 8 pp. 1168 (1983), "Beam characterization and measurement of propagation attributes", M. W. Sasnett and T. F. Johnson, Jr., Proc. SPIE Vol. 1414, pp 21 (1991), and "New developments in laser resonators", A. E. Siegman, Proc. SPIE Vol. 1224, pp 2 (1990).
A Gaussian laser beam is described by a beam waist size, a wavelength, and a location in object space. The Gaussian beam is an idealization that can be approached but never attained in practice. However, real laser beams can be well described by an embedded Gaussian beam with ideal characteristics, and a quality factor, called M2, which defines the relative beam size and divergence with respect to the embedded Gaussian mode. The ideal M2 value is unity, but real lasers will always have an M2 value greater than unity.
This feature requires the definition of the initial input embedded beam properties, and the M2 value. The input embedded beam is defined by the location of the input beam waist relative to surface 1 (note this is not the object surface, but the first surface after the object) and the waist radial size at this location. ZEMAX then propagates this embedded beam through the lens system, and at each surface the beam data is computed and displayed in the output window. ZEMAX computes the Gaussian beam parameters for both X and Y orientations.
Default beam parameters:
ZEMAX defaults to a waist size of 0.05 lens units (no matter what the lens units are) and a surface 1 to waist distance of zero; this of course means the waist is at surface 1. The default values may be reset by clicking on the "Reset" button. After the default values are computed and displayed, any alternate beam waist size and location may be entered and that Gaussian beam will be traced instead.
Propagating the embedded beam:
Once the initial beam waist and location parameters are established, ZEMAX traces the embedded beam through the system and computes the radial beam size, the narrowest radial waist, the surface coordinate relative to the beam waist, the phase radius of curvature of the beam, the semi-divergence angle, and the Rayleigh range for every surface in the system. ZEMAX calls these parameters the Size, Waist, Waist Z, Radius, Divergence, and Rayleigh, respectively, on the text listing that is generated.
The quality factor:
All of the preceding results are correct for the ideal embedded Gaussian beam. For aberrated, mixed-mode beams, a simple extension to the fundamental Gaussian beam model has been developed by Siegman. The method uses a term called the beam quality factor, usually denoted by M2. The factor M2 can be though of as "times diffraction limited" number, and is always greater than unity. The M2 factor determines the size of the real, aberrated Gaussian beam by scaling the size and divergence of the embedded Gaussian mode by M. It is common practice to specify M2 for a laser beam, rather than M, although the factor M is used to scale the beam size. The M2 factor must be measured to be determined correctly. If the M2 factor is set to unity, the default value, ZEMAX simply computes the TEM00 data described above. If M2 is greater than unity, them ZEMAX computes both the embedded Gaussian beam parameters as well as the scaled data.
Because the embedded Gaussian beam parameters are based upon paraxial ray data the results cannot be trusted for systems which have large aberrations, or those poorly described by paraxial optics, such as non-rotationally symmetric systems. This feature ignores all apertures, and assumes the Gaussian beam propagates well within the apertures of all the lenses in the system.
Interactive Analysis:
The Settings dialog box for this feature also supports an interactive mode. After defining the various input beam parameters, clicking on "Update" will immediately trace the specified Gaussian beam, and display the usual results in the dialog box. The parameters for any surface may be viewed, and the surface number selected from the drop down list. The orientation may also be selected using the provided control.
The interactive feature does not in any way modify the lens or the system data; it is simply a handy calculator for displaying Gaussian beam data.
 楼主| 发表于 2005-12-7 23:48:00 | 显示全部楼层
<P>谢谢楼上的,学习一下!!</P>
 楼主| 发表于 2005-12-8 16:14:00 | 显示全部楼层
<P>看了这一段了,不过没有讲该怎么在ZEMAX中设置啊。还请再指点一下!</P>
发表于 2005-12-8 17:16:00 | 显示全部楼层
[B]以下是引用[I]huhaocheng1[/I]在2005-12-8 8:14:00的发言:[/B][BR]
 楼主| 发表于 2005-12-8 18:39:00 | 显示全部楼层
<P>谢谢小马过河,可是我怎么找不到进行高斯光束的设置的对话框呢?是我的版本问题,不能够进行高斯光束的分析嘛??</P>
 楼主| 发表于 2005-12-8 18:51:00 | 显示全部楼层
<P>不好意思,我找到了。不过这样看来,在ZEMAX中只能计算高斯光束传输,但是不能用来优化,不知道是不是?可以针对高斯光束进行优化吗?</P>
发表于 2005-12-8 19:16:00 | 显示全部楼层
Gaussian beam operands:GBPS, GBPW, GBPP, GBPR, GBPD, GBSS, GBSW, GBSP, GBSR, GBSD 读手册!
[B]以下是引用[I]huhaocheng1[/I]在2005-12-8 10:51:00的发言:[/B][BR]
 楼主| 发表于 2005-12-8 23:10:00 | 显示全部楼层
谢谢小马过河,希望能经常向你请教!!
 楼主| 发表于 2006-2-20 22:44:00 | 显示全部楼层
小马过河!ZEMAX里面没这些操作数吧?只有:GBWO,GBWA,GBWD,GBWR,GBWZ这5个啊!另外我想知道高斯光束计算中光源是如何设置的?是否在优化的时候,需要在镜头前面加一个面,然后用GBWA或者GBWD指定该面上的高斯光束的尺寸或半径,即按这个方法设置光源,然后选择参数进行优化,知道符合需要既可?请赐教!!
[B]以下是引用[I]小马过河[/I]在2005-12-8 11:16:00的发言:[/B][BR]Gaussian beam operands:GBPS, GBPW, GBPP, GBPR, GBPD, GBSS, GBSW, GBSP, GBSR, GBSD 读手册!
