查看: 2088|回复: 3
请问有2940NM 的激光器出售吗?
发表于 2006-2-22 22:34:00 | 显示全部楼层 |阅读模式
  有朋友打听,作用在基因处理上面的2940NM的激光器何处有售?
发表于 2006-2-23 09:11:00 | 显示全部楼层
http://www.laserwelt.com/uploads/media/ERYAG.pdf
可以看看
The Lovely II Er:YAG 2940nm laser handpiece is powered by a robust, precision technology that enables controlled skin injury for many skin abnormalities attributed to photodamge/photoage skin. It provides a very safe and comfortable means to trigger superficial thermal injury to create smoother, healthier more revitalized skin. The precise tissue ablation and small zone of residual thermal damage results in faster re-epithelialization and improved morbidity. The safety, accuracy and ease of use eliminate the need for lengthy and complex pre and post treatment procedures and result in no or limited patient downtime. The Er:YAG handpiece can fit 1mm 4mm spot sizes that provide adequate short pulse durations and different penetration depths, to effectively treat and improve a wide range of skin anomalies, such as rhydites, epidermal nevi, skin tags, verrucae, keratoses, acne scars, leucoplasia, rhinophyma,debulking benign tumors, and other flat epidermal lesions.
发表于 2006-2-23 09:14:00 | 显示全部楼层
我知道有一家公司已经开发出来了Er:YAG激光器,用于医疗激光的.具体的指标也不知道符合不?
但主要销往国外,不知道销不销国内
如果需要,我帮你打听一下.
[此贴子已经被作者于2006-2-23 20:48:57编辑过]
 楼主| 发表于 2006-2-23 19:20:00 | 显示全部楼层
无聊瓜子:你好,谢谢你的信息!! 请看消息/。
