查看: 1370|回复: 0
[推荐][建议]UV LED二极管紫外线点光源照射机(UV-LED)
发表于 2006-6-13 17:21:00 | 显示全部楼层 |阅读模式
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">国内首发,</span></b><b style="mso-bidi-font-weight: normal;"><span lang="EN-US" style="FONT-SIZE: 12pt;"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US" style="FONT-SIZE: 12pt;"><font face="Times New Roman">D UV SPOT CURING SYSTEM</font></span></b><b style="mso-bidi-font-weight: normal;"><span style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">二极管发光式紫外线点光源照射机</span></b><b style="mso-bidi-font-weight: normal;"><span lang="EN-US" style="FONT-SIZE: 12pt;"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><font face="Times New Roman"><p></p></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">深圳市蓝谱里克科技有限公司从事紫外线点光源照射系统近十年,采用日本最新技术,开发了新型紫外线照射系统,采用</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">LED</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">发光方式,发出高纯度的紫外线能量,使电</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">-</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">光能量的转换达到最佳效果,</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b><span lang="EN-US" style="FONT-SIZE: 12pt; COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">1</font></span></b><b><span style="FONT-SIZE: 12pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">,最小热辐射的紫外线点光源照射机</span></b><b><span lang="EN-US" style="FONT-SIZE: 12pt; COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 22.5pt;"><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">本机光源采用高能量的</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">365nm</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">的</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">UV-LED</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">,与以往的超高压汞灯发光照射方式不同,</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 22.5pt;"><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">其光源是不会产生红外线的纯粹紫外光,可以在不损伤部品的情况下,完成紫外线</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt;"><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">接着剂的固化,实现高精度的部件接合。</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: -10.5pt; mso-char-indent-count: -1.0; mso-char-indent-size: 10.5pt;"><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">(采用传统超高压紫外线汞灯发光方式来照射,被照射的物体表面温度上升</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">35-40</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">度,而采用</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">LED </font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">紫外线照射方式,温度只上升</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">3</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">度左右。)</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18.0pt;"><b><span lang="EN-US" style="FONT-SIZE: 12pt; COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">2,<span style="FONT: 7pt Times New Roman;"> </span></font></span></b><b><span style="FONT-SIZE: 12pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">效降低生产成本</span></b><b><span lang="EN-US" style="FONT-SIZE: 12pt; COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: -15.75pt; mso-char-indent-count: -1.5; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">A</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">:由于采用</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">LED</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">的发光方式,寿命长达</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">25000</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">小时(连续点燃寿命)采用节能设计,只有在需要照射时才点亮,实际使用寿命将长达</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">30000</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">小时以上。</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: -15.75pt; mso-char-indent-count: -1.5; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">B</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">:和高压汞灯对比,减少了更换灯泡的时间,更节约了频繁更换灯泡的费用,有效降低耗材成本。</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: -15.75pt; mso-char-indent-count: -1.5; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">C</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">:由于采用</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">LED</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">发光方式,只有照射时候才消耗电能,这样有效地节约了电能消耗,</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">D</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">:</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">LED</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">直接照射,不需要输出光缆,减少了光缆损耗。</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: -15.75pt; mso-char-indent-count: -1.5; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">E</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">:本机器大约可以在使用的</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">5-8</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">年内不需要更换任何零件,可以比传统的</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman">UV</font></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">照射机每年节省一万多元的费用。</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b><span lang="EN-US" style="FONT-SIZE: 15pt; COLOR: black;"><font face="Times New Roman">3</font></span></b><b><span style="FONT-SIZE: 12pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 15.0pt;">,</span></b><b><span style="FONT-SIZE: 12pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">点光源行业最小机身</span></b><b><span lang="EN-US" style="FONT-SIZE: 12pt; COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 26.25pt; TEXT-INDENT: -26.25pt; mso-char-indent-count: -2.5; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><span style="mso-spacerun: yes;"><font face="Times New Roman"> </font></span></span><span lang="EN-US" style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt;"><span style="mso-spacerun: yes;"></span>本机采用超小机身,只有原先高压汞灯照射机的1/8的体积,这样使得本机不仅可以用于单元生产线,也可以安装在小型设备中,为了更方便操作,照射头采用从机身背面引出的方式。<p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US" style="FONT-SIZE: 15pt; COLOR: black;"><font face="Times New Roman">4</font></span><span style="FONT-SIZE: 15pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">,</span><b><span style="FONT-SIZE: 12pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">照射头可以输出四种光点直径</span></b><span lang="EN-US" style="FONT-SIZE: 15pt; COLOR: black;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 22.5pt; TEXT-INDENT: -22.5pt; mso-char-indent-count: -1.5; mso-char-indent-size: 15.0pt;"><span lang="EN-US" style="FONT-SIZE: 15pt; COLOR: black;"><span style="mso-spacerun: yes;"><font face="Times New Roman"> </font></span></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">只需要更换照射头的透镜,即可以改变输出光点的直径,从四种透镜中选择最适合工件的光点尺寸,就可以实现可靠的接合,(配备</span><span lang="EN-US" style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt;">ф3。Ф4 。ф6 。ф8。照射透镜)</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b><span lang="EN-US" style="FONT-SIZE: 12pt; COLOR: black; mso-bidi-font-size: 15.0pt;"><font face="Times New Roman">5</font></span></b><b><span style="FONT-SIZE: 12pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 15.0pt;">,具备四个独立控制的照射头</span></b><b><span lang="EN-US" style="FONT-SIZE: 12pt; COLOR: black; mso-bidi-font-size: 15.0pt;"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 22.5pt; TEXT-INDENT: -22.5pt; mso-char-indent-count: -1.5; mso-char-indent-size: 15.0pt;"><span lang="EN-US" style="FONT-SIZE: 15pt; COLOR: black;"><span style="mso-spacerun: yes;"><font face="Times New Roman"> </font></span></span><span style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman; mso-bidi-font-size: 10.5pt;">四个独立控制的照射头可以同时应用于四个需要单头输出的独立工位,有效减少设备配置,同时,四个照射头还可以通过电脑编程模式,来控制次序照射,进一步支持高精度的接合需求,减少人为操作的时间误差</span><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 26.25pt; TEXT-INDENT: -26.25pt; mso-char-indent-count: -2.5; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 26.25pt; TEXT-INDENT: -26.25pt; mso-char-indent-count: -2.5; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 26.25pt; TEXT-INDENT: -26.25pt; mso-char-indent-count: -2.5; mso-char-indent-size: 10.5pt;"><span lang="EN-US" style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt;"><p></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 26.25pt; TEXT-INDENT: -26.25pt; mso-char-indent-count: -2.5; mso-char-indent-size: 10.5pt;"><span style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt;">联系人:魏陈平<span lang="EN-US"><p></p></span></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 26.25pt; TEXT-INDENT: -26.25pt; mso-char-indent-count: -2.5; mso-char-indent-size: 10.5pt;"><span style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt;">电话:<span lang="EN-US">0755-82871176<p></p></span></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt 26.25pt; TEXT-INDENT: -26.25pt; mso-char-indent-count: -2.5; mso-char-indent-size: 10.5pt;"><span style="COLOR: black; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.5pt;">邮箱:<span lang="EN-US">weichenping511@sina.com<p></p></span></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: -15pt; mso-char-indent-count: -1.5; mso-char-indent-size: 10.0pt;"><shapetype id="_x0000_t75" stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" opreferrelative="t" ospt="75" coordsize="21600,21600"><stroke joinstyle="miter"></stroke><formulas><f eqn="if lineDrawn pixelLineWidth 0"></f><f eqn="sum @0 1 0"></f><f eqn="sum 0 0 @1"></f><f eqn="prod @2 1 2"></f><f eqn="prod @3 21600 pixelWidth"></f><f eqn="prod @3 21600 pixelHeight"></f><f eqn="sum @0 0 1"></f><f eqn="prod @6 1 2"></f><f eqn="prod @7 21600 pixelWidth"></f><f eqn="sum @8 21600 0"></f><f eqn="prod @7 21600 pixelHeight"></f><f eqn="sum @10 21600 0"></f></formulas><path oconnecttype="rect" gradientshapeok="t" oextrusionok="f"></path><lock aspectratio="t" vext="edit"></lock></shapetype><shape id="_x0000_s1026" type="#_x0000_t75" style="MARGIN-TOP: 7.8pt; Z-INDEX: 1; LEFT: 0px; MARGIN-LEFT: 333pt; WIDTH: 44.25pt; POSITION: absolute; HEIGHT: 42pt; TEXT-ALIGN: left;"><imagedata otitle="" src="file:///C:/DOCUME~1/acer/LOCALS~1/Temp/msoclip1/01/clip_image001.png"></imagedata></shape><shape id="_x0000_s1027" type="#_x0000_t75" style="MARGIN-TOP: 7.8pt; Z-INDEX: 2; LEFT: 0px; MARGIN-LEFT: 45pt; WIDTH: 44.25pt; POSITION: absolute; HEIGHT: 42.75pt; TEXT-ALIGN: left;"><imagedata otitle="" src="file:///C:/DOCUME~1/acer/LOCALS~1/Temp/msoclip1/01/clip_image002.png"></imagedata></shape><span lang="EN-US" style="COLOR: black; mso-bidi-font-size: 10.5pt;"><font face="Times New Roman"><p></p></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: -10.5pt; mso-char-indent-count: -1.0; mso-char-indent-size: 10.5pt;"><span lang="EN-US"><font face="Times New Roman"><p></p></font></span></p>
