查看: 3921|回复: 5
讨论一下像质评价问题
发表于 2006-6-28 06:14:00 | 显示全部楼层 |阅读模式
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">像质评价问题在评价一个系统时,如何通过系统各个指标来判断该系统的质量?(比如对摄影物镜来说)</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><font face="Times New Roman">1</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">、一般情况下,用哪几个指标来判断?比如,</span><span lang="EN-US"><font face="Times New Roman">Ray Aberration</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">、</span><span lang="EN-US"><font face="Times New Roman">Spot Diagrams</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">、</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><font face="Times New Roman">MTF</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">、塞德系数,等等,其中哪个指标最为权威??或者说要达到设计要求,哪几个指标是必须达到的,或者都必须达到?</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><font face="Times New Roman">2</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">、在用</span><span lang="EN-US"><font face="Times New Roman">Spot Diagrams</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">评价成像质量时,主要用</span><span lang="EN-US"><font face="Times New Roman">RMS</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">还是</span><span lang="EN-US"><font face="Times New Roman">GEO</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">,对一个分辨力要达到</span><span lang="EN-US"><font face="Times New Roman">100 lp/mm</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">的系统,其</span><span lang="EN-US"><font face="Times New Roman">Spot Diagrams</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">值要求达到什么程度?</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><font face="Times New Roman">3</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">、点扩散函数和成像质量的关系,是不是点扩散函数很理想时,该系统的成像质量就很好?</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><font face="Times New Roman">4</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">、</span><span lang="EN-US"><font face="Times New Roman">Image Analysis</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">菜单中的</span><span lang="EN-US"><font face="Times New Roman">Diffraction Image Analysis</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">项,当从图中看到衍射效果明显时,对系统成像的分辨本领影响大吗?</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><p><font face="Times New Roman"></font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">以上是本人学习</span><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: Times New Roman; mso-hansi-font-family: Times New Roman;">过程中想了解清楚的一些问题,想请教一下大家,也希望大家提出新的问题,就像质评价问题进行讨论。谢谢!</span></p>
发表于 2006-7-6 04:13:00 | 显示全部楼层
当你想要很多答案的时候,通常你就得不到答案:-)
发表于 2006-7-19 19:02:00 | 显示全部楼层
不同的指标都有各自不同的作用.
发表于 2006-7-21 03:53:00 | 显示全部楼层
<p>1,在成像领域,像质评价首推MTF。在设计、应用、测试中MTF均是一个标准参数,而且客观、真实,与系统的其它部分衔接自然。在整个信息传递过程中,都可以用MTF来评价、衡量,分系统的好坏,以及整个系统的优肋。而其它参数仅在传统的成像领域才有意义。要说到实际测量,大多都没有办法。</p><p>2,RMS和GEO都可以。GEO理论直观,容易理解掌握,方便思维。RMS更具有严谨性,如果确实理解的话,RMS更准确。后面的,Spot*要达到什么样的水平,和具体要求密切相关,别人都不能替你回答。设计时建议你看看100lp/mm下的MTF值,很有参考价值。</p><p>3,理论上讲,点扩散函数的傅立叶变换就是MTF(二维的)。这点很容易理解的,点扩散函数的理想状态是<span style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;">△函数,它的傅立叶变换就是1,换句话说就是:理想像点(<span style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;">△函数)对应MTF=1,这就是个理想系统</span></span>。我们常用的MTF是一维的,它是线扩散函数的傅立叶变换,这点略有不同,注意到就行。</p><p>4,这也是个具体问题,笼统的答案是没有的。如果是一般透镜系统,大可不必担心,基本没什么影响。如果是特殊应用(使用的衍射元件?),另当别论。</p>
发表于 2006-7-24 08:29:00 | 显示全部楼层
<p>
[B]以下是引用[I]luaim[/I]在2006-7-20 19:53:00的发言:[/B][BR]p1,在成像领域,像质评价首推MTF。....设计时建议你看看100lp/mm下的MTF值,很有参考价值..../p
</p><p></p><p>请教一下,MTF值一般要求达到多少,再实际解像中才OK呢?</p>
发表于 2007-9-3 14:57:51 | 显示全部楼层
学习了不过讲的还是不够详细
MTF是特定频率下像物对比度的比值。是综合评价镜头的一种方法,是很好的和镜头设计与生产联系起来。
