查看: 6327|回复: 7
Buchdahl像差是什么像差?怎么翻译啊?
发表于 2006-7-3 18:15:00 | 显示全部楼层 |阅读模式
在GOOGLE上面没查到中文的解释。
请教,谢谢!
发表于 2006-7-4 16:22:00 | 显示全部楼层
我的几个词典里面都没有:(
发表于 2006-7-6 00:02:00 | 显示全部楼层
Hans A. Buchdahl. For his extensive publications in the field of geometrical optics, relativity, and thermodynamics, and for developing a practical way of computing the higher order aberration coefficients of lens systems (Buchdahl's optical aberration coefficients).
A German by birth, Hans Buchdahl has lived most of his life in Australia, where he worked originally at the University of Tasmania. In the 1960s, he because Department Head in Theoretical Physics at the Australian National University in Canberra. Although now retired, he maintains an emeritus position at the Australian National University to continue his scientific pursuits.
Buchdahl's work in optics has concentrated in the theoretical analysis of optical systems using Lagrangian aberration functions or Hamilton's characteristic functions. He has made significant contributions in the areas of aberration theory, algorithms for the calculation of aberration coefficients, limitations imposed by system symmetries and in the definition of chromatic coordinates for modeling dispersion. He has published two books and over 100 papers on geometrical optics, and has published extensively in the field of relativity and thermodynamics.
从上面的描述可以看出来Buchdahl's optical aberration coefficients是一种比较实用的用于计算高级像差的方法,由德国人Buchdahl提出。Code V中的五级像差系数即是Buchdahl's optical aberration coefficients。估计没有什么通用的中文名称。
详细的关于Buchdahl's optical aberration coefficients的计算方法可以参看:
http://www.sinopt.com/learning1/optsoft/evaluation/evaluation.htm
 楼主| 发表于 2006-7-6 00:44:00 | 显示全部楼层
谢谢楼上的高人,这个德国人的名字怎么读呢?
就是发音啊,我读不出来,所以没法给别人讲啊,呵呵。
发表于 2006-7-7 04:10:00 | 显示全部楼层
姑且读作布赫达(尔)吧!
发表于 2011-10-12 15:00:20 | 显示全部楼层
刚刚看到这个名词,不了解
发表于 2011-10-13 22:57:43 | 显示全部楼层
中文称: 布克达尔
布克达尔(buchdahl)模型得到铊玻璃自聚焦透镜的色差方程,计算和实验证明:两步离子交换所得自聚焦透镜比一步交换的一级色差要大得多^^
发表于 2011-10-13 23:00:02 | 显示全部楼层
楼主可以再用这个名称查一下哦
