查看: 4756|回复: 8
[求助]ZEMAX定焦数码相机镜头设计
发表于 2006-7-8 02:42:00 | 显示全部楼层 |阅读模式
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 20pt; mso-line-height-rule: exactly;"><span style="FONT-SIZE: 14pt; COLOR: black; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.0pt;">谢谢</span></p>
发表于 2006-7-8 05:05:00 | 显示全部楼层
<p>同求!</p>
发表于 2006-7-11 10:27:00 | 显示全部楼层
<p>这两个一定是暑期实习不肯花力气的家伙</p>
发表于 2006-7-12 07:45:00 | 显示全部楼层
<p>具体要求</p><p>什么用途</p>
发表于 2006-7-12 08:35:00 | 显示全部楼层
<p>好提议!!!</p><p>希望高手指点</p><p>我列一下要求:<span style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.0pt; mso-bidi-font-family: Times New Roman; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;">焦距:<span lang="EN-US">f’=9.6mm</span>,相对孔径<span lang="EN-US">D/f’</span>不小于<span lang="EN-US">1/2.8</span>,图像传感器为<span lang="EN-US">1/2.5</span>英吋的<span lang="EN-US">CCD</span>,成像面大小为<span lang="EN-US">4.32mm</span>×<span lang="EN-US">5.76mm</span>。在可见光波段设计<span lang="EN-US">(</span>取<span lang="EN-US">d</span>、<span lang="EN-US">F</span>、<span lang="EN-US">C</span>三种色光,<span lang="EN-US">d</span>为主波长<span lang="EN-US">)</span></span></p><p><span style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 10.0pt; mso-bidi-font-family: Times New Roman; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;"><span lang="EN-US"></span></span></p>
发表于 2006-7-12 17:27:00 | 显示全部楼层
Surf Type Radius Thickness Glass Diameter
OBJ STANDARD Infinity Infinity 0
1 STANDARD 3.477242 1.334351 N-SK4 4.276467
2 STANDARD 2135.576 0.5676572 3.651443
STO STANDARD -8.588066 0.6363188 N-F2 2.775577
4 STANDARD 3.099306 0.6398978 2.782367
5 STANDARD 6.330279 1.192418 N-SK4 3.855707
6 STANDARD -7.653473 0.4950512 4.163541
7 STANDARD Infinity 0.3 BK7 4.537057
8 STANDARD Infinity 5.710102 4.629506
IMA STANDARD Infinity 7.375692
发表于 2006-8-5 22:23:00 | 显示全部楼层
光栏怎么还有曲率啊
发表于 2009-10-20 21:19:01 | 显示全部楼层
ms这个课题这么多年了还在用,我们今年也是类似的课程设计,数据不一样罢了~~
遇到了一些瓶颈,参考下,谢谢了~~
发表于 2009-10-20 21:34:00 | 显示全部楼层
上面那个方案有问题吧?~
