查看: 2109|回复: 3
how much is the CO2 tube
发表于 2006-8-17 01:37:00 | 显示全部楼层 |阅读模式
There is a CO2 marking machine , the CO2 tube needs to replace. Who know the manufacturer of it and how about the price?
1: power 30W,length 80cm
2: power 60w, length 120cm
and the price of Nd: YAG rod ,the size as following:diameter 6mm, length more than 110mm.
and the Xe lamp: diameter 7mm, length 210mm, the distance between pole 100mm.
发表于 2006-8-18 01:16:00 | 显示全部楼层
这些东西满大街都是,厂家售,代理售,等等...
 楼主| 发表于 2006-8-18 02:39:00 | 显示全部楼层
As for CO2 tube ,I have not used it even before ,so I'm not familiar with it.Whether there is some difference between them? I mean I do not know each of them can be used in our marking machine. The coupler in the end of tube is the same with each other? Thanks very much.
 楼主| 发表于 2006-8-18 02:48:00 | 显示全部楼层
I know there are a lot of manufacturer , hehe, I just want to campare the prices, of course , I want to buy the cheaper product with good quality.
