查看: 3487|回复: 1
[转帖]Laser Hair Removal - Color Of Hair And Skin
发表于 2006-8-29 22:42:00 | 显示全部楼层 |阅读模式
Laser is the concentrated beam of light energy that is used to remove hair from body for skin care. Laser has very high energy and destroys the hair follicles in seconds. While removing the hair, laser is focused on skin and it gets attracted to the color of hair follicle and destroyed it. Let us find out how to do skin care with laser hair removal and how the color of hair and color of your skin affects the results.
Laser hair removal and color of skin- laser gets attracted to dark pigments in the skin. That is how it reaches the hair follicles and heats them to destroy. If your skin is dark in color, that will also absorb some laser energy and may get blistered or swell. With latest lasers, this problem is getting eliminated. For getting good skin without hair, you must talk with your physician about your skin color and the kind of laser equipment they have.
Laser hair removal and color of hair- as laser destroys the hair getting attracted to the pigment in the hair, it is easier to remove dark hair with laser. If you have light color hair- blonde, red, etc. you need to talk to your physician about that and find out the effectiveness of their equipment for your hair color.
Skin care and laser hair removal- for good skin care laser is a semi permanent solution. if the contrast between your hair and skin color is high, you are an ideal candidate for this procedure for skin care. With latest advances in skin care you need not worry about the color of hair and skin but must talk to your physician and find out about the facility they have.
This article is only for informative purposes. This article is not intended to be a medical advice and it is not a substitute for professional medical advice. Please consult your doctor for all your medical concerns. Please follow any information given in this article only after consulting your doctor or qualified medical professional. The author is not liable for any outcome or damage resulting from any information obtained from this article.
发表于 2006-9-23 19:25:00 | 显示全部楼层
乏味版主 你好啊!
我想下载昨天那个
Optics Laser Europe
最新的2006 7-9 期的
我不知道该怎么弄!!
多谢赐教!!!
还有 有没有它们的中文版的
最好和英语一起的
那样看起来会很快哦
