<p align="center" class="MsoNormal" style="text-align: center;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;"> 光学设计MSN日记<op></op></span></b></p>
<p class="MsoDate" style="text-indent: 160.65pt;"> 2006-10-16</p>
<p align="center" class="MsoNormal" style="text-align: center;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">节选自许正光和胡绘珠的聊天纪录<op></op></span></b></p>
<p align="center" class="MsoNormal" style="text-align: center;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">文章有些零散,尚未整理,请读者谅解<op></op></span></b></p>
<p align="center" class="MsoNormal" style="text-align: center;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;"><!--Element not supported - Type: 8 Name: #comment--> <!--Element not supported - Type: 8 Name: #comment--><op></op></span></b></p>
<p class="MsoNormal"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">光学设计有三个阶段<op></op></span></b></p>
<p class="MsoNormal"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">1、结构选择,确保高级像差能够满足要求;2、整体上像质满足要求。结构稳定。易于加工;3、工程化阶段。我说的第三个阶段,就是解决</span></b><b><span style="font-size: 16pt;">“</span></b><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">加工难度</span></b><b><span style="font-size: 16pt;">”</span></b><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">、</span></b><b><span style="font-size: 16pt;">“</span></b><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">工程公差</span></b><b><span style="font-size: 16pt;">”</span></b><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">、</span></b><b><span style="font-size: 16pt;">“</span></b><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">成本控制</span></b><b><span style="font-size: 16pt;">”</span></b><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">的问题。<op></op></span></b></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;"><!--Element not supported - Type: 8 Name: #comment--> <!--Element not supported - Type: 8 Name: #comment--><op></op></span></b></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">镜片加工的过程,要考虑镜片的形状,胶合难易程度,装卡等等。所以设计的时候就要工程师想到。所以说,精密结构设计是光学人员必须掌握的知识之一。<op></op></span></b></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">我认为:避免几种常见的情形 是必要的。<op></op></span></b></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">1、镜片厚薄问题。例如边缘锋利。中间太薄。这是有国家标准的。<op></op></span></b></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">2、镜面曲率,由加工成本的问题。镜片曲率太小,加工难度高,加工难度高,造成误差概率也就大;且从光学设计角度来说,曲率小的面一般敏感度增加,这样造成的像质损坏也就大。一般而言,我们都要避开工厂能够加工的最小的曲率半径。当然特别大,例如动辄1000以上曲率也不对,到了那个程度你就干脆修改成为平面。<op></op></span></b></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">3、镜片的形状选择和设计中,要尽量减少同心镜片,曲率太小、太大的镜面。像差平衡过程中尽量使得镜片的敏感度均匀化。空气厚度、玻璃厚度的敏感性也要均匀化。否则,某一个地方的误差会导致成品率下降。<op></op></span></b></p>
<p class="MsoNormal"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;"><!--Element not supported - Type: 8 Name: #comment--> <!--Element not supported - Type: 8 Name: #comment--><op></op></span></b></p>
<p class="MsoNormal"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">我说的设计三原则:1、满足设计要求;2、性能价格比;3、加工装调可行性。我说的三个阶段,三个原则,要贯穿始终哦。每个阶段都要遵循三个原则,每个阶段工作重心不一样。<op></op></span></b></p>
<p class="MsoNormal"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">胶合镜片的成本比单个镜片大,所以不需要使用胶合的时候就不要使用胶合。你要明白为什么要使用胶合或者非用不可的时候才用。这样考虑兼顾了成本、工艺和设计要求。<op></op></span></b></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><span lang="EN-US" style="font-size: 14pt;"><!--Element not supported - Type: 8 Name: #comment--> <!--Element not supported - Type: 8 Name: #comment--><op></op></span></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">NLAF10 首先:镧系玻璃,镧是一种稀土金属,本身就带有同位素,同位素是一种重金属、发射r射线的材料;此外,火石玻璃都是含一定比例氧化铅的硅酸盐系玻璃。铅是有毒重金属。这种玻璃能够说是环保玻璃?我说的环保型是指符合欧盟最新环保电子仪器产品要求的RoSH指令。<op></op></span></b></p>
<p align="left" class="MsoNormal" style="margin-right: 0.9pt; text-align: left;"><b><span style="font-size: 16pt; font-family: 楷体_GB2312;">4、玻璃选择的考虑。光学玻璃是镜头的主要成本之一。当我们在成本、像质之间犹豫不决的时候,有的时候必须做出经验性的偏好选择。通常的做法是,宁可增加一个镜片也不要采用高折射率、异常相对色散的非常用玻璃。<op></op></span></b></p>
<b><span style="font-size: 16pt; font-family: 楷体_GB2312;">常用的玻璃体系就是国家标准中给出的黑色加黑的推荐玻璃。这些玻璃之所以推荐使用,是因为生产批量大,工艺性能好,稳定性强,更为成熟,因此:物理化学性能都是可靠的,成本也是最便宜的。<br/><br/><br/>---------------------<br/>MSN: msxzg@sina.com.cn<br/>共同学习,共同进步<br/></span></b>
