查看: 3544|回复: 2
光学设计笔记:安防镜头设计像质评价(二)
发表于 2006-10-20 20:14:00 | 显示全部楼层 |阅读模式
<div class="blogtext" id="blogtext__fks_Zf0jtS6yRixd_TI8uDBFTg==" style="width: 97%;">
                <p align="center" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: center;"><b><span style="font-size: 16pt; font-family: 宋体;">光学设计笔记</span></b><b><span style="font-size: 16pt;">(</span></b><b><span style="font-size: 16pt; font-family: 宋体;">二</span></b><b><span style="font-size: 16pt;">)<op></op></span></b></p>
                <p align="center" style="text-align: center;">2006-10-20</p>
                <p align="center" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: center;"><span style="font-size: 14pt; font-family: 宋体;"><摘选自许正光和胡绘珠聊天纪录></span><span style="font-size: 14pt;"><op></op></span></p>
                <p align="center" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: center;"><span style="font-size: 14pt;"></span><span style="font-size: 14pt; font-family: 宋体;">没有整理,请读者谅解</span><span style="font-size: 14pt;"></span></p><p align="center" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: center;"><br/><span style="font-size: 14pt;">
                <p align="center" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: center;"><span style="font-size: 14pt;"><!--Element not supported - Type: 8 Name: #comment--> <!--Element not supported - Type: 8 Name: #comment--><op></op></span></p>
                <p align="left" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: left;"><b><span style="font-size: 14pt; font-family: 宋体;">胡</span></b><span style="font-size: 14pt; font-family: 宋体;">:</span><span lang="EN-US" style="font-size: 14pt;">RMS</span><span style="font-size: 14pt; font-family: 宋体;">和</span><span lang="EN-US" style="font-size: 14pt;">GEO</span><span style="font-size: 14pt; font-family: 宋体;">具体物理上是什么意思?在用来评价设计系统像质的时候如何使用?</span><span lang="EN-US" style="font-size: 14pt;"><op></op></span></p>
                <p><b><span style="font-size: 14pt; font-family: 楷体_GB2312;">许</span></b><span style="font-size: 14pt; font-family: 楷体_GB2312;">:</span><span style="font-size: 14pt;">GEO</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">大概是指若干个抽样光线经过镜头后落在像面上,形成了如敢离散点的分布,这个分布的最小外接圆半径。</span><span style="font-size: 14pt;"><op></op></span></p>
                <p style="text-indent: 14pt;"><span style="font-size: 14pt;">RMS</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">是指按照计算质心的方法先计算一个重心位置,然后以此位置作为坐标原点,按照平方和的方法将所有的抽样点进行计算,然后求方根。这样得到的半径。从这个半径我们可以了解光线的集中程度。</span><span lang="EN-US" style="font-size: 14pt;"><op></op></span></p>
                <p align="left" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: left;"><span lang="EN-US" style="font-size: 14pt;"><!--Element not supported - Type: 8 Name: #comment--> <!--Element not supported - Type: 8 Name: #comment--><op></op></span></p>
                <p align="left" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: left;"><b><span style="font-size: 14pt; font-family: 宋体;">胡</span></b><span style="font-size: 14pt; font-family: 宋体;">:虽然说</span><span style="font-size: 14pt;">0.7</span><span style="font-size: 14pt; font-family: 宋体;">视场按对角线来算是</span><span style="font-size: 14pt;">2.1</span><span style="font-size: 14pt; font-family: 宋体;">,也就是你说的内接圆的半径,但是认为应该按</span><span style="font-size: 14pt;">1.8</span><span style="font-size: 14pt; font-family: 宋体;">来作为内切圆的半径,因为按你说的算圆的面积,再除以</span><span style="font-size: 14pt;"> CCD</span><span style="font-size: 14pt; font-family: 宋体;">的面积,得到的结果有些牵强啊</span><span style="font-size: 14pt;">! </span><span style="font-size: 14pt; font-family: 宋体;">因为有一部分圆的的面积根本就没有显示到</span><span style="font-size: 14pt;">CCD</span><span style="font-size: 14pt; font-family: 宋体;">上啊?</span><span style="font-size: 14pt;"><op></op></span></p>
                <p style="margin-left: 14.05pt; text-indent: -14.05pt;"><b><span style="font-size: 14pt;"><span></span></span></b><b><span style="font-size: 14pt; font-family: 楷体_GB2312;">许:</span></b><span style="font-size: 14pt; font-family: 楷体_GB2312;">这不过是一个指导思想。也正就是说,安防镜头</span><span style="font-size: 14pt;">0.7</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">视场覆盖,在垂直视场上已经覆盖全部高度</span><span style="font-size: 14pt;">4.23.6</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">;而在水平视场上,已经覆盖</span><span style="font-size: 14pt;">87.5%</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">。</span><span style="font-size: 14pt;">(2.1/2.4)</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">。</span><span style="font-size: 14pt;"><op></op></span></p>
                <p align="left" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: left; text-indent: 28pt;"><span style="font-size: 14pt; font-family: 楷体_GB2312;">至于四个角上,都不是我们平常监视的主要位置。这就是镜头检测都主要以这个视场为权衡的原因。</span><span style="font-size: 14pt;">
                        </span><span style="font-size: 14pt; font-family: 楷体_GB2312;">大概是不能够过于较真的。主要是理解其思想。</span><span style="font-size: 14pt;"><op></op></span></p>
                <p align="left" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: left; text-indent: 28pt;"><span style="font-size: 14pt; font-family: 楷体_GB2312;">其实,更为优秀的镜头也不过关注到</span><span style="font-size: 14pt;">0.85</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">视场。下面计算一下</span><span style="font-size: 14pt;">0.85</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">视场的比重。在水平视场、垂直视场上,</span><span style="font-size: 14pt;">0.85</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">视场已经完全覆盖。只剩下小小的四个角。所以,如果不是复制用的镜头,也不是需要高保真的镜头。实际上,按照</span><span style="font-size: 14pt;">0.85</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">去检测安防镜头,已经算是高品质或者说没有必要了。当然</span><span style="font-size: 14pt;">
                        </span><span style="font-size: 14pt; font-family: 楷体_GB2312;">设计的时候你可以对自己提这个要求。下面做一个小结。</span></p><p align="left" style="margin-top: 0cm; margin-right: 0.9pt; margin-bottom: 0.0001pt; text-align: left; text-indent: 28pt;"><br/><span style="font-size: 14pt; font-family: 楷体_GB2312;"></span><span style="font-size: 14pt;"><op></op></span></p>
                <p align="center" style="text-align: center;"><b><span style="font-size: 14pt; font-family: 楷体_GB2312;">安防镜头设计一些总结</span></b></p><p align="center" style="text-align: center;"><br/><b><span style="font-size: 14pt; font-family: 楷体_GB2312;"></span></b><b><span style="font-size: 14pt;"><op></op></span></b></p>
                <p style="text-indent: 28pt;"><span style="font-size: 14pt; font-family: 楷体_GB2312;">由此,安防镜头设计的思想可以归纳一下了:对于像质评价而言。一般重要关心中心视场,边缘视场一般关注到0</span><span style="font-size: 14pt;">.707</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">左右,最多不超过</span><span style="font-size: 14pt;">0.85</span><span style="font-size: 14pt; font-family: 楷体_GB2312;">。设计人员要追求这个范围内的设计质量。</span></p><p style="text-indent: 28pt;"><br/><span style="font-size: 14pt; font-family: 楷体_GB2312;"></span><span style="font-size: 14pt;"><op></op></span></p>
                <p style="text-indent: 28pt;"><span style="font-size: 14pt;">为什么这么做呢?一个因素,这是和使用特点相符合的;二个因素呢,因为设计人员追求的是最低成本、最简单结构,因此常常手中拥有的变量不会太多。那么在像差设计的时候,就会要有所偏重。</span><span style="font-size: 14pt; font-family: Times New Roman;"><op></op></span></p>
                <p style="text-indent: 28pt;"><span style="font-size: 14pt;">此外,对于图像畸变的看
法。图像畸变不影响图像的清晰程度,因此并不影响安防监视。通常的照相镜头对畸变要求是非常严格的。安防镜头的行业标准并未统一建立起来。公安部第一研究
所的标准认为:在40度视场下,边缘视场畸变不允许超过5%,每增加10度视场,允许畸变增加1%左右。实际上,允许畸变增加的范围在</span><span style="font-size: 14pt; font-family: Times New Roman;">1.5%</span><span style="font-size: 14pt;">左右也没有关系,而且当视场增加到</span><span style="font-size: 14pt; font-family: Times New Roman;">100</span><span style="font-size: 14pt;">度附近,有的时候畸变在</span><span style="font-size: 14pt; font-family: Times New Roman;">12%</span><span style="font-size: 14pt; font-family: Times New Roman;">~</span><span style="font-size: 14pt; font-family: Times New Roman;">15%</span><span style="font-size: 14pt;">左
右也是允许的。并未要求那么严格。这就给设计人员对初始结构的选择范围增加了,关注的像差放宽了很多。其实,归功到底,我们可以看得出来,光学设计思想就
是“服务于使用目的,权衡使用要求”。仅仅坐在电脑旁边设计,不去生产一线看看加工和装配、不和客户了解一下需求,不愿意把理论基础打牢固。是不可能成为
真正优秀的光学工程师的。</span><span style="font-size: 14pt; font-family: Times New Roman;"><op></op></span></p>
                <div style="border-style: none none solid; border-color: -moz-use-text-color -moz-use-text-color windowtext; border-width: medium medium 1.5pt; padding: 0cm 0cm 1pt;">
                        <p style="border: medium none ; padding: 0cm; text-indent: 0cm;"><span style="font-size: 14pt; font-family: Times New Roman;"><!--Element not supported - Type: 8 Name: #comment--> <!--Element not supported - Type: 8 Name: #comment--><op></op></span></p>
                </div>
                <p style="text-indent: 0cm;"><span style="font-size: 14pt;">欢迎交流,共同进步!</span><span style="font-size: 14pt; font-family: Times New Roman;"><op></op></span></p>
                <p style="text-indent: 0cm;"><span lang="EN-US" style="font-size: 14pt; font-family: Times New Roman;">MSN: </span><span style="font-size: 14pt;"><a href="mailto:msxzg@sina.com"><span lang="EN-US">msxzg@sina.com</span></a></span><span lang="EN-US" style="font-size: 14pt; font-family: Times New Roman;"><op></op></span></p>
                <p style="text-indent: 0cm;"><span lang="EN-US" style="font-size: 14pt; font-family: Times New Roman;">Email: </span><span style="font-size: 14pt;"><a href="mailto:msxzg@sina.com.cn"><span lang="EN-US">msxzg@sina.com.cn</span></a></span><span lang="EN-US" style="font-size: 14pt; font-family: Times New Roman;"><op></op></span></p>
                <span lang="EN-US" style="font-size: 14pt; font-family: Times New Roman;">Blog:
blog.163.com/oepower</span></div>
 楼主| 发表于 2006-10-20 20:15:00 | 显示全部楼层
欢迎光顾我的博客。 blog.163.com/oepower<br/>
发表于 2006-10-21 19:19:00 | 显示全部楼层
<p>谢谢,许工</p><p>我已经不您的博客添加的收藏夹里了!</p><p>希望您以后有更多的更好的经验与大家分享!</p><p>另外,我发现许工对文学方面也涉猎较广,佩服呀!</p>
