查看: 3759|回复: 1
ZEMAX Develops Photo-Realistic Image Simulation
发表于 2006-10-28 22:22:00 | 显示全部楼层 |阅读模式
From Optics.org
Updated: 24 October 2006
The ZEMAX optical system design program now has a photo-realistic image simulation feature, allowing the designer to select an object scene or test pattern and ray trace this through the system.
This gives a fast and accurate representation of the quality of the formed image. This new analysis feature is perfect for communicating performance to non-optics specialists.
The graphic shows a scene as imaged though a simple singlet lens, and clearly shows pin-cushion distortion and field curvature. This analysis can be applied to any imaging system.
Dr Mark Nicholson, Vice President Operations of ZEMAX Development Corporation, says “We've put a lot of effort into making this feature ray-trace extremely quickly. On single-CPU machines you can get useful results in less than a minute, and photo-realistic quality is about 20 minutes. But, ZEMAX can work with up to 16 CPUs. Whilst such big machines are still fairly uncommon, four-core machines are becoming standard in engineering workstations. ZEMAX is designed from the ground up to split calculations over multiple CPUs and recombine the results seamlessly”
This feature is just one of over 30 additions to the latest version of the highly successful ZEMAX optical design package. Ask us for more information on how ZEMAX can help you, today.
Company Information:
Optima Research Ltd is the European distributor of ZEMAX, the industry standard lens design code. ZEMAX is used for lens design, illumination system design, stray light analysis and laser beam propagation. Optima Research also provides training in computer-based optical design methods.
For more information
Contact: Neil Barrett, Optical Engineer neil.barrett@optima-research.com or phone +44 (0)1279 810911
发表于 2006-11-23 22:52:00 | 显示全部楼层
能翻译一下吗?
