查看: 14919|回复: 35
为庆贺两件事,高兴之余编了一个计算景深的ZEMAX宏
发表于 2006-11-12 00:06:00 | 显示全部楼层 |阅读模式
<p>计算景深的ZEMAX宏</p><p>使用方法:</p><p>把文件考到ZEMAX\Macros目录下,打开ZEMAX,在Macros菜单下选择DepthOfField</p><p>Focal length(mm) 填入镜头焦距,如35<br/>F/# 填入镜头F/#,如2.8<br/>Subject distance(m)(Input 0 for infinity)", 填入对准平面距离,如10米<br/>INPUT "Circle of confusion(mm)", 填入允许的弥散圆大小,如0.031mm</p><p>然后,计算结果就出来了</p><p></p><p>今天光棍节,光棍们快乐!</p> U9ZS3tea.rar (640 Bytes, 下载次数: 172) <br/>
本帖被以下淘专辑推荐:
发表于 2006-11-15 19:23:00 | 显示全部楼层
<p>昨天把lz的小软件下载用了用,还不错,谢谢!</p><p>有一点想请教lz:</p><p>Circle of confusion(mm) 填入允许的弥散圆大小,如0.031mm</p><p>这弥散圆的大小是根据RMS,GEO,AIRY的大小来确定么</p><p>万分感激!!</p>
 楼主| 发表于 2006-11-15 21:03:00 | 显示全部楼层
<table width="90%" summary="notes for circle of confusion calculator" border="0"><tbody><tr colspan="3"><td><p>The circles of confusion above were calculated using the formula:</p><i><p>The normal range for 35mm format circle of confusion is 0.025 - 0.035 mm. The Leica standard circle of confusion for 35mm format is 0.025 mm.</p><p></p><p><table width="90%" summary="notes for circle of confusion calculator" border="0"><tbody><tr colspan="3"><td><p>The circles of confusion above were calculated using the formula:</p><p><i>CoC = (CoC for 35mm format) / (Digital camera lens focal length multiplier)</i>
        </p></td></tr><tr colspan="3"><td><br/><p>The focal length multiplier for a camera is specified by the manufacturer, or is calculated using the formula:</p><p><i>Multiplier = (35mm equivalent lens focal length) / (Actual lens focal length)</i></p></td></tr></tbody></table>mm format) / (Digital camera lens focal length multiplier) </p></i>
                                </td></tr><tr colspan="3"><td><br/><p>The focal length multiplier for a camera is specified by the manufacturer, or is calculated using the formula:</p><p><i>Multiplier = (35mm equivalent lens focal length) / (Actual lens focal length)</i></p><p><em></em></p><p><em><table width="70%" summary="circles of confusion for digital cameras" border="1"><tbody><tr><td><p><b>Manufacturer</b></p></td><td><p><b>Model</b></p></td><td width="20%"><p><b>Circle of Confusion (mm)</b></p></td></tr><!--Element not supported - Type: 8 Name: #comment--><tr><td><p>Agfa</p></td><td><p>ePhoto CL-18</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>1D</p></td><td><p>0.023</p></td></tr><tr><td><p>Canon</p></td><td><p>1D Mark II</p></td><td><p>0.023</p></td></tr><tr><td><p>Canon</p></td><td><p>1D Mark II N</p></td><td><p>0.023</p></td></tr><tr><td><p>Canon</p></td><td><p>1DS</p></td><td><p>0.030</p></td></tr><tr><td><p>Canon</p></td><td><p>1Ds Mark II</p></td><td><p>0.030</p></td></tr><tr><td><p>Canon</p></td><td><p>5D</p></td><td><p>0.030</p></td></tr><tr><td><p>Canon</p></td><td><p>10D</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>20D</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>20Da</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>30D</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>D30</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>D60</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>Digital Rebel / 300D</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>Digital Rebel XT / 350D</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>Digital Rebel XTi / 400D</p></td><td><p>0.019</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A10</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A20</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A30</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A40</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A60</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A70</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A75</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A80</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A85</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A95</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A100</p></td><td><p>0.004</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A200</p></td><td><p>0.004</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A300</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A310</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A400</p></td><td><p>0.004</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A430</p></td><td><p>0.004</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A510</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A520</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A530</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A540</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A610</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A620</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A630</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A640</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A700</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot A710IS</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot G1</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot G2</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot G3</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot G5</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot G6</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot Pro1</p></td><td><p>0.008</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot Pro 90 IS</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot S1 IS</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot S2 IS</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot S3 IS</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S30</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S40</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S45</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S50</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S60</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S70</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S80</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S110 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S200 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S230 Elf</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S300 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S330 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S400</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S410</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>PowerShot S500</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD10 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD20 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD30 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD100 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD110 Elph</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD200</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD300</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD400</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD430 Wireless</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD450</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD500</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD550</p></td><td><p>0.006</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD600</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD630</p></td><td><p>0.005</p></td></tr><tr><td><p>Canon</p></td><td><p>Powershot SD700 IS</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-S2</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-M2</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-P505</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-P600</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-P700</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-S100</p></td><td><p>0.004</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-S500</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-S600</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-S600D</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-S770</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z5</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z30</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z40</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z50</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z55</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z57</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z60</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z70</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z110</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z120</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z500</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z600</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z700</p></td><td><p>0.005</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z750</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z850</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim EX-Z1000</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim QV-R51</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim QV-R61</p></td><td><p>0.006</p></td></tr><tr><td><p>Casio</p></td><td><p>Exilim QV-R62</p></td><td><p>0.006</p></td></tr><tr><td><p>Contax</p></td><td><p>N Digital</p></td><td><p>0.030</p></td></tr><tr><td><p>Contax</p></td><td><p>TVS Digital</p></td><td><p>0.006</p></td></tr><tr><td><p>Contax</p></td><td><p>SL300RT</p></td><td><p>0.005</p></td></tr><tr><td><p>Epson</p></td><td><p>PhotoPC 3100 Z</p></td><td><p>0.006</p></td></tr><tr><td><p>Epson</p></td><td><p>PhotoPC L-410</p></td><td><p>0.005</p></td></tr><tr><td><p>Epson</p></td><td><p>L-500V</p></td><td><p>0.005</p></td></tr><tr><td><p>Epson</p></td><td><p>RD-1</p></td><td><p>0.020</p></td></tr><tr><td><p>Epson</p></td><td><p>RD-1S</p></td><td><p>0.020</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 30i</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A120</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A203</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A303</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A330</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A340</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A345</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A350</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A400</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix A600</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix E500</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix E510</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix E550</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix E900</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F10</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F11</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F20</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F30</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F401</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F402</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F440</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F450</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F455</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F470</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F510</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F601</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F650</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F700</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F710</p></td><td><p>0.006</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix F810</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S602</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 2600</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 2650</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 2800</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 3800</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 4800</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 4900</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S3000</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S3100</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S3500</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S5000</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S5200 / S5600</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S5500 / S5100</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 6800</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix 7000</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S6500fd</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S9000 / S9500</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S1 Pro</p></td><td><p>0.020</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S2 Pro</p></td><td><p>0.020</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S3 Pro</p></td><td><p>0.020</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S3 Pro UVIR</p></td><td><p>0.020</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix S20 Pro</p></td><td><p>0.007</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix V10</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix Z1</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix Z2</p></td><td><p>0.005</p></td></tr><tr><td><p>Fujifilm</p></td><td><p>FinePix Z3</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 120</p></td><td><p>0.008</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 318</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 320</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 435</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 620</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 635</p></td><td><p>0.004</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 715</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 720</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 735</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 812</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 850</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 912</p></td><td><p>0.007</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 935</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart 945</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart C215</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M22</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M23</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M307</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M407</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M417</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M425</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M517</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M525</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart M527</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart R507</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart R607</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart R707</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart R717</p></td><td><p>0.006</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart R817</p></td><td><p>0.005</p></td></tr><tr><td><p>Hewlett Packard</p></td><td><p>PhotoSmart R818</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>CX-7430</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>CX-6330</p></td><td><p>0.006</p></td></tr><tr><td><p>Kodak</p></td><td><p>CX-7330</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>CX-7530</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>DC-5000</p></td><td><p>0.007</p></td></tr><tr><td><p>Kodak</p></td><td><p>DCS-14N</p></td><td><p>0.030</p></td></tr><tr><td><p>Kodak</p></td><td><p>DCS-720X</p></td><td><p>0.019</p></td></tr><tr><td><p>Kodak</p></td><td><p>DCS-760</p></td><td><p>0.023</p></td></tr><tr><td><p>Kodak</p></td><td><p>DCS Pro</p></td><td><p>0.030</p></td></tr><tr><td><p>Kodak</p></td><td><p>DX-4530</p></td><td><p>0.006</p></td></tr><tr><td><p>Kodak</p></td><td><p>DX-6440</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>DX-6490</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>DX-7440</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>DX-7590</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>DX-7630</p></td><td><p>0.007</p></td></tr><tr><td><p>Kodak</p></td><td><p>LS-743</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>LS-753</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>PalmPix 100/500</p></td><td><p>0.004</p></td></tr><tr><td><p>Kodak</p></td><td><p>Z730</p></td><td><p>0.005</p></td></tr><tr><td><p>Kodak</p></td><td><p>Z760</p></td><td><p>0.006</p></td></tr><tr><td><p>Kodak</p></td><td><p>Z7590</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica</p></td><td><p>KD-310Z</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica</p></td><td><p>KD-400</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica</p></td><td><p>KD-500</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage 5</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage 7</p></td><td><p>0.008</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage 7i</p></td><td><p>0.008</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage 7Hi</p></td><td><p>0.008</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage A1</p></td><td><p>0.008</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage A2</p></td><td><p>0.008</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage A200</p></td><td><p>0.008</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage E50</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage E223</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage F100</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage F300</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage G400</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage G600</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage S404</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage S414</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage X</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Xg</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Xi</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Xt</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage X1</p></td><td><p>0.006</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage X20</p></td><td><p>0.004</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage X31</p></td><td><p>0.004</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage X50</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage X60</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Z1</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Z2</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Z3</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Z5</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Z6</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Z10</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Dimage Z20</p></td><td><p>0.005</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Maxxum 5D</p></td><td><p>0.020</p></td></tr><tr><td><p>Konica Minolta</p></td><td><p>Maxxum 7D</p></td><td><p>0.020</p></td></tr><tr><td><p>Kyocera</p></td><td><p>FineCam L4v</p></td><td><p>0.005</p></td></tr><tr><td><p>Kyocera</p></td><td><p>FineCam M410R</p></td><td><p>0.005</p></td></tr><tr><td><p>Kyocera</p></td><td><p>FineCam S3</p></td><td><p>0.006</p></td></tr><tr><td><p>Kyocera</p></td><td><p>FineCam S3x</p></td><td><p>0.006</p></td></tr><tr><td><p>Kyocera</p></td><td><p>FineCam S4</p></td><td><p>0.006</p></td></tr><tr><td><p>Kyocera</p></td><td><p>FineCam S5</p></td><td><p>0.006</p></td></tr><tr><td><p>Kyocera</p></td><td><p>FineCam SL300R</p></td><td><p>0.005</p></td></tr><tr><td><p>Kyocera</p></td><td><p>FineCam SL400R</p></td><td><p>0.005</p></td></tr><tr><td><p>Leica</p></td><td><p>C-Lux 1</p></td><td><p>0.005</p></td></tr><tr><td><p>Leica</p></td><td><p>Digilux 1</p></td><td><p>0.006</p></td></tr><tr><td><p>Leica</p></td><td><p>Digilux 2</p></td><td><p>0.008</p></td></tr><tr><td><p>Leica</p></td><td><p>D-Lux</p></td><td><p>0.005</p></td></tr><tr><td><p>Leica</p></td><td><p>D-Lux 2</p></td><td><p>0.007</p></td></tr><tr><td><p>Mamiya</p></td><td><p>ZD</p></td><td><p>0.039</p></td></tr><tr><td><p>Microtek</p></td><td><p>Take-it D1</p></td><td><p>0.006</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage 5</p></td><td><p>0.006</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage 7</p></td><td><p>0.008</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage 7i</p></td><td><p>0.008</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage 7Hi</p></td><td><p>0.008</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage A1</p></td><td><p>0.008</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage A2</p></td><td><p>0.008</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage E223</p></td><td><p>0.005</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage F100</p></td><td><p>0.006</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage F300</p></td><td><p>0.006</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage G400</p></td><td><p>0.005</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage G600</p></td><td><p>0.006</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage S404</p></td><td><p>0.006</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage S414</p></td><td><p>0.006</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage X</p></td><td><p>0.005</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage Xg</p></td><td><p>0.005</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage Xi</p></td><td><p>0.005</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage Xt</p></td><td><p>0.005</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage X20</p></td><td><p>0.004</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage X50</p></td><td><p>0.005</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage Z1</p></td><td><p>0.005</p></td></tr><tr><td><p>Minolta</p></td><td><p>Dimage Z2</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 2000</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 2100</p></td><td><p>0.004</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 2200</p></td><td><p>0.004</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 2500</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 3100</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 3200</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 3500</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 3700</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 4100</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 4200</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 4300</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 4500</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 4600</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 4800</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 5000</p></td><td><p>0.008</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 5200</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 5400</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 5600</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 5700</p></td><td><p>0.008</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 5900</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 7600</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 7900</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 8400</p></td><td><p>0.008</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 8700</p></td><td><p>0.008</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 8800</p></td><td><p>0.008</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S9600 / S9100</p></td><td><p>0.007</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 775</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 885</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix 995</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix L1</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix L2</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix L3</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix L4</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix L5</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix L6</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix P1</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix P2</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix P3</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix P4</p></td><td><p>0.006</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix SQ</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S1</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S2</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S3</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S4</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S5</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S6</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S7c</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S9</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>Coolpix S10</p></td><td><p>0.005</p></td></tr><tr><td><p>Nikon</p></td><td><p>D1H</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D1X</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D2H</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D2Hs</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D2X</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D2Xs</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D50</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D70</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D70s</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D80</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D100</p></td><td><p>0.020</p></td></tr><tr><td><p>Nikon</p></td><td><p>D200</p></td><td><p>0.020</p></td></tr><tr><td><p>Olympus</p></td><td><p>AZ-1</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Brio D-230</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-160</p></td><td><p>0.004</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-2500L</p></td><td><p>0.008</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-3020</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-3040</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-460 ZOOM del Sol</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-4000</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-4040Z</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-50</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-55 / C-5500</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-60</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-70 / C-7000</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-500</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-5000</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-5050</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-5060</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-5500</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-700 ZU</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-7070</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-7000</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-730 CZ</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-720</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-730</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-740</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-750</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-765</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-770</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>C-8080</p></td><td><p>0.008</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-40</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-100 Brio</p></td><td><p>0.004</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-150 Brio</p></td><td><p>0.004</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-370</p></td><td><p>0.004</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-380</p></td><td><p>0.004</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-390</p></td><td><p>0.004</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-395</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-425</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-435</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-510</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-520</p></td><td><p>0.004</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-535 / C-370</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-540</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-545</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-550</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-560</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-580</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-590</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-595</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>D-630</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>E-1</p></td><td><p>0.015</p></td></tr><tr><td><p>Olympus</p></td><td><p>E-10</p></td><td><p>0.008</p></td></tr><tr><td><p>Olympus</p></td><td><p>E-100 RS</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>E-20</p></td><td><p>0.008</p></td></tr><tr><td><p>Olympus</p></td><td><p>E-300</p></td><td><p>0.015</p></td></tr><tr><td><p>Olympus</p></td><td><p>E-330</p></td><td><p>0.015</p></td></tr><tr><td><p>Olympus</p></td><td><p>E-500</p></td><td><p>0.015</p></td></tr><tr><td><p>Olympus</p></td><td><p>Ferrari DIGITAL MODEL 2004</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-100</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-110</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-115</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-120</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-130</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-140</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-150</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-170</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-180</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-200</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>FE-5500</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>ImageLink</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>IR-300</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>IR-500</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>SP-310</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>SP-320</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>SP-350</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>SP-500 UZ</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>SP-510 UZ</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>SP-700</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 300</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 410</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 500</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 600</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 700</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 720 SW</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 725 SW</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 730</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 740</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 750</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 800</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 810</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus 1000</p></td><td><p>0.006</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus Verve</p></td><td><p>0.005</p></td></tr><tr><td><p>Olympus</p></td><td><p>Stylus Verve s</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-F7</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FX01</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FX07</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FX2</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FX3</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FX7</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FX8</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FX9</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FX50</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ1</p></td><td><p>0.004</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ3</p></td><td><p>0.004</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ4</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ5</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ7</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ10</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ20</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ30</p></td><td><p>0.006</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-FZ50</p></td><td><p>0.006</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-L1</p></td><td><p>0.015</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LC1</p></td><td><p>0.008</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LC20</p></td><td><p>0.004</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LC40</p></td><td><p>0.006</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LC5</p></td><td><p>0.006</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LC50</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LC70</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LC80</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LS1</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LS2</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LX1</p></td><td><p>0.007</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LX2</p></td><td><p>0.007</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LZ1</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LZ2</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LZ3</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-LZ5</p></td><td><p>0.005</p></td></tr><tr><td><p>Panasonic</p></td><td><p>Lumix DMC-TZ1</p></td><td><p>0.004</p></td></tr><tr><td><p>Pentax</p></td><td><p>EI-100</p></td><td><p>0.004</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 30</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 33WR</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 43WR</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 33LF</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 50</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 60</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 230</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 330</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 330GS</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 430</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 430 RS</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 450</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 550</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 555</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio 750Z</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio A10</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio A20</p></td><td><p>0.006</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio E10</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio MX4</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio M10</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio M20</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S4i</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S5i</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S5n</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S5z</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S6</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S7</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S30</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S40</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S45</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S50</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S55</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio S60</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio SV</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio SVi </p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio T10</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio X</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio W10</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio W20</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio WP</p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>Optio WPi </p></td><td><p>0.005</p></td></tr><tr><td><p>Pentax</p></td><td><p>*ist D</p></td><td><p>0.020</p></td></tr><tr><td><p>Pentax</p></td><td><p>*ist DL</p></td><td><p>0.020</p></td></tr><tr><td><p>Pentax</p></td><td><p>*ist DL2</p></td><td><p>0.020</p></td></tr><tr><td><p>Pentax</p></td><td><p>*ist DS</p></td><td><p>0.020</p></td></tr><tr><td><p>Pentax</p></td><td><p>*ist DS2</p></td><td><p>0.020</p></td></tr><tr><td><p>Pentax</p></td><td><p>K100D</p></td><td><p>0.020</p></td></tr><tr><td><p>Pentax</p></td><td><p>K110D</p></td><td><p>0.020</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio 500G wide</p></td><td><p>0.006</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio RX</p></td><td><p>0.005</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio R2</p></td><td><p>0.005</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio R3</p></td><td><p>0.005</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio R4</p></td><td><p>0.005</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio R5</p></td><td><p>0.005</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio R30</p></td><td><p>0.005</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio R40</p></td><td><p>0.005</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio RR530</p></td><td><p>0.005</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio GX</p></td><td><p>0.006</p></td></tr><tr><td><p>Ricoh</p></td><td><p>Caplio GX8</p></td><td><p>0.006</p></td></tr><tr><td><p>Ricoh</p></td><td><p>GR</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax 230</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax 410</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax 240</p></td><td><p>0.004</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A4</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A5</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A6</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A7</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A40</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A50</p></td><td><p>0.004</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A55W</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A400</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A302</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A402</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax A502</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax i5</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax i50 MP3</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax L50</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax L60</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax L55W</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax U-CA 4</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax U-CA 5</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax V3</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax V4</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax V6</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax V50</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax V70</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax V700</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>Digimax V800</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>GX-1L</p></td><td><p>0.020</p></td></tr><tr><td><p>Samsung</p></td><td><p>GX-1S</p></td><td><p>0.020</p></td></tr><tr><td><p>Samsung</p></td><td><p>NV3</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>NV7 OPS</p></td><td><p>0.005</p></td></tr><tr><td><p>Samsung</p></td><td><p>NV10</p></td><td><p>0.006</p></td></tr><tr><td><p>Samsung</p></td><td><p>PRO815</p></td><td><p>0.008</p></td></tr><tr><td><p>Sanyo</p></td><td><p>Xacti DSC-S1</p></td><td><p>0.005</p></td></tr><tr><td><p>Sanyo</p></td><td><p>Xacti DSC-S3</p></td><td><p>0.005</p></td></tr><tr><td><p>Sanyo</p></td><td><p>Xacti DSC-S4</p></td><td><p>0.005</p></td></tr><tr><td><p>Sanyo</p></td><td><p>Xacti J4</p></td><td><p>0.005</p></td></tr><tr><td><p>Sanyo</p></td><td><p>VPC-AZ3</p></td><td><p>0.006</p></td></tr><tr><td><p>Sanyo</p></td><td><p>VPC-J1</p></td><td><p>0.005</p></td></tr><tr><td><p>Sigma</p></td><td><p>SD-9</p></td><td><p>0.018</p></td></tr><tr><td><p>Sigma</p></td><td><p>SD-10</p></td><td><p>0.018</p></td></tr><tr><td><p>Sony</p></td><td><p>Alpha DSLR-A100</p></td><td><p>0.020</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-F88</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-F707</p></td><td><p>0.008</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-F717</p></td><td><p>0.008</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-F828</p></td><td><p>0.008</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-H1</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-H2</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-H5</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-L1</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-M1</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-M2</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-N1</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P2</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P3</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P30</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P31</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P32</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P41</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P5</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P7</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P8</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P9</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P10</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P50</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P51</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P52</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P71</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P72</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P73</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P92</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P93</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P100</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P120</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P150</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-P200</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-R1</p></td><td><p>0.018</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-S40</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-S60</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-S75</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-S85</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-S90</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-S600</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T1</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T3</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T5</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T7</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T9</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T10</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T11</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T30</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-T33</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-U20</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-U40</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-U60</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-V1</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-V3</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-W1</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-W5</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-W7</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-W30</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-W50</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-W70</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Cyber Shot DSC-W100</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Mavica MVC-CD200</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Mavica MVC-CD250</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Mavica MVC-CD300</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Mavica MVC-CD350</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Mavica MVC-CD400</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Mavica MVC-CD500</p></td><td><p>0.006</p></td></tr><tr><td><p>Sony</p></td><td><p>Mavica MVC-FD100</p></td><td><p>0.005</p></td></tr><tr><td><p>Sony</p></td><td><p>Mavica MVC-FD200</p></td><td><p>0.005</p></td></tr><tr><td><p>Vivitar</p></td><td><p>Vivicam 3330</p></td><td><p>0.006</p></td></tr></tbody></table></em></p><p><em></em></p><p><em></em></p></td></tr></tbody></table>
发表于 2006-11-28 00:32:00 | 显示全部楼层
<p>非常感谢————————————————————————————————————</p>
发表于 2006-12-4 18:27:00 | 显示全部楼层
<p>收了!</p><p>希望lz常遇喜事,多交好运!</p>
发表于 2006-12-17 21:36:00 | 显示全部楼层
饮水不忘挖井人,
发表于 2007-8-1 13:34:38 | 显示全部楼层
不错。多谢提供。楼主强人啊呵呵。
发表于 2007-8-10 17:49:56 | 显示全部楼层
我变得更穷了
发表于 2007-8-10 20:31:11 | 显示全部楼层
感谢楼主的共享啊
谢谢
发表于 2007-10-10 13:37:39 | 显示全部楼层
感谢楼主
好人!
发表于 2007-10-10 22:15:09 | 显示全部楼层
非常感谢楼主提供!
发表于 2007-10-11 09:35:23 | 显示全部楼层
先感谢了楼主在下载,,
