查看: 6429|回复: 10
zemax中怎么输入一个锥面
发表于 2006-11-30 18:19:00 | 显示全部楼层 |阅读模式
怎么输入锥面?可以在面形调出来呢,还是要编宏?知道赐教一下吧,谢谢
发表于 2006-12-8 07:04:00 | 显示全部楼层
我编过一个Axicon.dll的用户定义面,好久没搞光学了,到时找出来给你,要等一个星期左右
发表于 2006-12-22 17:00:00 | 显示全部楼层
<p>2楼的大哥,能发给我一份吗?</p><p>急需要,谢谢大哥了啊!</p><p><a href="mailto:jiajun.song@accelink.com">jiajun.song@accelink.com</a></p>
发表于 2006-12-24 22:44:00 | 显示全部楼层
<p>如果是圆锥的话可以用奇数非球面来设置,设置它的一次系数即可,系数值是正切值</p>
发表于 2006-12-25 19:47:00 | 显示全部楼层
对,后来我也发现我编的用户定义面是多余的,请按附件做就可以了 4C3659dt.rar (599 Bytes, 下载次数: 46) <br/>
发表于 2006-12-30 22:00:00 | 显示全部楼层
那奇数非球面的前面RADIUS如果取值,而不是∞,将会是什么情况?表示什么意思
发表于 2007-1-17 07:28:00 | 显示全部楼层
用数学知识理解一下就很简单了。每一个面型的公式定义的几何意义。
 楼主| 发表于 2007-1-20 00:56:00 | 显示全部楼层
那天晚上是用一个奇次非球面的,不过非球面系数好像有点限制,有时光线出不来
发表于 2007-1-20 06:36:00 | 显示全部楼层
Zemax manual page 288
Modeling an axicon with the standard surface
The standard surface can be used to make an almost perfect axicon. If (1+k)C^2R^21, the standard surface reduces to
                 Z=r/sqrt(-1-k) or z=rtan(alpha) , where tan(alpha) = 1/sqrt(-1-k) ,
and alpha is the axicon angle, measured from the XY plane to the axicon surface. To create an axicon, calculate
the conic constant value (k) from the angle (alpha ) desired, and use any small value for the radius of curvature. The
resulting value of k must be negative. The exact value of the radius or curvature is not important, as long as it is
roughly three or more orders of magnitude smaller than the radial aperture of the axicon. The axicon is not perfect
in the sense that there is no cusp at the origin; the region around the surface vertex will be rounded off over a
size given approximately by the radius value. This is actually a desirable property for ray tracing, as the surface
is everywhere smooth.
发表于 2011-5-20 14:42:26 | 显示全部楼层
学习下。。。。
发表于 2011-11-17 16:15:30 | 显示全部楼层
不错
