MEMs Optical 1x2 Switch The C-OPTIC’s 1x2;2X2 switch is a very fast opto-mechanical switch based on the latest silicon MEMS technology and uses micro-mechanical mirrors to redirect the light. The switch is built by cascading 1x2;2X2 switches which are qualified according to Telcordia GR1073
Features Applications High reliability Optical Reconfiguration Low insertion loss Instrumentation TTL or CMOS drive WDM Latching or non-latching
Specifications Parameter | Value | Unit | Wavelength range | 1250~1640,600~1700(multi-mode) | nm | Insertion loss | typ.0.8,max 1.2 | dB | Return loss | =45 | dB | Polarization dependent loss | 0.1 | dB | Cross talk | Typ.60, Max 55 | dB | Repeatability | =0.01 | dB | Switch speed | 20, max 30 | ns | Operating Voltage | 5 | VDC | Power Consumption | typ 10, max 50 | mW | Operation temperature | 0~65 | ℃ | Storage temperature | -40~80 | ℃ | Durability | 1billion | degree | Size | ¢5.5 x 35 | mm |
Ordering Information Mode | Switch hannel | Latching or Non-Latching | Fiber Type | Fiber Length | Connector | SM MM | 14=1x4 18=1x8 110=1x10 112=1x12 113=1x13 116=1x16 3232=32X3 | L=Latching N=Non-Latching | S9=SMF 9/125/900um M5=MMF 50/125/900um M6=MMF 62.5/125/900um XX=others | 1=1.0m 2=2.0m XX=others | NE=None FA=FC/APC FC=FC/PC SA=SC/APC SC=SC/PC ST=ST/PC LA=LC/APC LC=LC/PC XX=others |
同行唯一超高速光开关(MEMS)
