发表于 2007-3-9 19:08:00
显示全部楼层
<p>在ZEMAX中有個檔案為SEQ2ZEM</p><p>這正是ZEMAX提供給用戶做檔案轉換的工具</p><p>用法如下</p><p> Utility to convert Code V(TM) sequence files to ZEMAX files</p><p> Syntax:</p><p> SEQ2ZMX INPUTFILENAME OUTPUTFILENAME LOGFILENAME</p><p> Where<br/> INPUTFILENAME is the input sequence file name, i.e. LENS.SEQ<br/> OUTPUTFILENAME is the output ZEMAX file name, i.e. LENS.ZMX<br/> LOGFILENAME is the optional log file name. Default = seq2zmx.LOG<br/> File names may include the drive and path.</p>
