查看: 2772|回复: 5
█ 谈谈2M pix 手机镜头规格
发表于 2007-7-6 08:17:33 | 显示全部楼层 |阅读模式
能否请各位先进谈谈目前两百万像素手机镜头的规格,TKS。
 楼主| 发表于 2007-7-9 17:38:13 | 显示全部楼层
So far as I know
pixel size =2.2microns
fno = 2.8
image circle = 4.7mm
TTL < 4.0mm ,from top of barrel to image plane
at center 220lps  MTF> 0.3
at 1.76mm 110lps  MTF> 0.3
 楼主| 发表于 2007-7-11 14:58:13 | 显示全部楼层
Does anybody have any idea about it?
发表于 2007-7-11 17:01:20 | 显示全部楼层
這麼簡單的設計有什麼可說的?
发表于 2007-7-11 17:02:17 | 显示全部楼层
除了ttl有點挑戰外
 楼主| 发表于 2007-7-13 08:05:50 | 显示全部楼层
If it is possible, would you please share the result of your design ? Thank you very much.
