查看: 9418|回复: 14
激光三维成像雷达
发表于 2007-7-9 15:25:35 | 显示全部楼层 |阅读模式
附件是一个关于激光三维成像雷达的资料,请各位浏览..
  LaserGrab Laser radar system
Laser radar scanner working in the 4-400 meter distance range with high accuracy
High speed scanning and high measurement speed
Scans a scene in a 3D profile like a radar system but with laser light and no radar
Detects and check predetermined areas for obstacles and intruders
Adjustable alarm levels based on position and size of target / obstacle
Invisible laser beam impossible to see by the bare eye, no beam stop at far end
Fail safe thinking for demanding applications in rail roads and security
Output by relay, RS 232 interface, wire less link, GSM Phone or SMS messaging
LaserGrab is produced and developed by Laseroptronix and we have been working with laser radar
systems since over 10 years. This system is available in several configurations with different specifications
and performance. The main difference between the different models is the distance meter unit and
computing performance. There is no general system making all problems easy to solve and a careful
analyse is always needed before the choice is done.
LaserGrab can scan in speeds of less 1 scan per sec to 50 scans per sec and we use similar mechanics
for this and change the motor and encoder upon demands.
LaserGrab can measure the distance from the short range systems of about 25-50 meter to over 1000
meter for long range systems. Resolution can differ from a few cm to 1-2 meter depending on what
distance meter we select.
Output can be a string with a distance value and an angle from the encoder and this is for qualified OEM
users. We can also supply solutions with a microprocessor , PLC or a PC with or without software.
This is not to easy so we want a communication with our customer about what is the best solution for their
application. The software is a key form all and we have long experience in smart dynamic filters which
helps a lot.
激光三维成像雷达.doc
609 KB, 下载次数: 138, 下载积分: 光电贝 -10 元
发表于 2007-10-10 09:53:46 | 显示全部楼层
回复 #1 yuki 的帖子
kankan.xiexie!!
发表于 2007-10-11 13:21:14 | 显示全部楼层
see
it goodit goodit goodit goodit goodit goodit good
发表于 2008-1-13 14:28:22 | 显示全部楼层
不错,看看看
不错,看看看看大大大dddddd大大大dddddddd
发表于 2008-9-20 15:20:08 | 显示全部楼层
真是个好的东西,找个好久
发表于 2008-12-28 12:32:27 | 显示全部楼层
看看啊,不错的东西!!
发表于 2008-12-28 13:46:27 | 显示全部楼层
为什么我下不了呢,一下就死机????
发表于 2008-12-28 20:05:13 | 显示全部楼层
顶一下,谢谢楼主的分享  谢谢
发表于 2009-1-16 15:19:34 | 显示全部楼层
这个比较有意思,谢谢楼主
发表于 2009-3-26 16:46:31 | 显示全部楼层
好东西,一定要看
发表于 2009-6-9 23:34:05 | 显示全部楼层
顶一下,先看看,谢谢楼主
发表于 2009-12-31 08:31:47 | 显示全部楼层
看一看,是不是国外的最新资料?
