查看: 4246|回复: 2
1000W YAG 1064nm激光切割效率
发表于 2007-7-11 17:09:41 | 显示全部楼层 |阅读模式
1. Summary of Laser Cutting          (1000W YAG 1064nm激光切割效率)
Material                                                  Thickness         Laser Power                          Cut Speed            Cover Gas
304L Stainless Steel                        1 mm                        500 Watts                        6 m/min                        O2 at 40 psi
304L Stainless Steel                        2 mm                        500 Watts                        4 m/min                        O2 at 40 psi
304L Stainless Steel                        3 mm                        500 Watts                        1 m/min                        O2 at 40 psi
发表于 2007-7-12 16:32:26 | 显示全部楼层
thank thank thank thank
 楼主| 发表于 2007-8-3 17:45:05 | 显示全部楼层
这是灯泵YAG的数据
实际上,如果采用光纤激光器,可能效果更好;
www.spilaser.com
