查看: 4634|回复: 9
光学镜头经典100例
发表于 2007-9-3 11:31:37 | 显示全部楼层 |阅读模式
2-1         48 INCH FOCAL LENGTH TELESCOPE OBJECTIVE f/8
             RADIUS       THICKNESS    MATERIAL      DIAMETER
   0          0.00000     1.00000E+07
   1         29.20970       0.6550     BK7             6.100
   2        -19.90470       0.0320     Air             6.100
   3        -19.89790       0.5780     SF2             6.000
   4        -66.39370      47.3810     Air             6.100
2-2         CEMENTED ACHROMAT f/6 20 INCH FOCAL LENGTH
   1         12.80180       0.4340     BAK1            3.410
   2         -9.06230       0.3210     SF8             3.410
   3        -37.65530      19.6310     Air             3.410
2-3      ACHROMAT, 10. EFL
     SURF     RADIUS      THICKNESS     MATERIAL     DIAMETER
      0       0.0000   1.0000E+10
      1         Stop       0.0000                     2.000
      2       6.5042       0.3500         BAK1        2.000
      3      -4.9573       0.2000          SF1        2.000
      4     -17.1987       9.7266                     2.000
      5       0.0000       0.0000                     0.526
2-4         LENS WITH REDUCED SECONDARY COLOR
   1          7.33240       0.4170     SSKN5           3.440
   2          4.79290       0.6550     FPL53           3.440
   3        -18.22250       0.6000     BAK1            3.440
   4        -44.88000      18.8460     Air             3.440
  3-2         f/3.5 TRIPLET
   0          0.00000   1.0000E+08
   1          1.42100       0.6499      SK16           1.720
   2        -10.90452       0.2300      Air            1.720
   3         -2.93835       0.1500      F2             1.100
   4          1.19190       0.8113      Air            1.100
   5          3.48672       0.4756      SK16           1.650
   6         -4.26794       3.3393                     1.650
3-3          INFARED TRIPLET  8 TO 14 MICRON
   0          0.00000  1.00000E+08
   1         10.19495       0.5901     Germanium       5.160
   2         13.60077       5.2510     Air             5.000
   3        -10.32501       0.5900     Zinc Selenide   3.480
   4        -11.45795       4.7353     Air             3.600
   5          2.57509       0.3918     Germanium       2.300
   6          2.48667       1.3065     Air             2.000
3-4          4 INCH IR TRIPLET 3.2 TO 4.2 MICRON f/4
   1          4.83277       0.2221     Silicon         2.560
   2         10.81975       0.8982     Air             2.560
   3        -11.10034       0.1000     Germanium       1.690
   4         25.38585       1.1915     Air             1.690
   5         12.18196       0.1525     Silicon         1.600
   6        -16.34242       2.7736     Air             1.600
3-5          50 INCH f/8 TRIPLET
   1         15.92647       0.3567     SK16            6.390
   2         56.81993       3.3886     Air             6.390
   3        -19.85031       1.3318     LF5             6.000
   4         20.90835       1.9021     Air             6.080
   5         87.76516       0.6203     SK16            6.500
   6        -16.11775      47.2106     Air             6.500
4-1          HELIAR  f/5
   0           0.00000      1.00000E+08              3.527E+07
   1          4.13088       0.8890     SK16            2.980
   2         -4.03166       0.2999     LLF6            2.980
   3         13.80239       0.8820     Air             2.360
   4         -3.16214       0.2000     LLF6            1.780
   5          3.07900       0.3110     Air             1.660
   6           Stop         0.0533     Air             1.617
   7         14.13740       0.2500     LLF6            2.100
   8          2.33444       0.7474     SK16            2.100
   9         -3.25924       8.5118     Air             2.100
4-2        f/4.5 Tessar Lens
   1          1.31474       0.3295      SK15           1.540
   2        -21.01899       0.2230      Air            1.540
   3         -2.43301       0.0813      F2             0.980
   4          1.17176       0.1940      Air            0.810
   5           Stop         0.1248      Air            0.720
   6        -31.84181       0.0825      K10            0.900
   7          1.40052       0.2780      SK15           1.160
   8         -1.69907       3.3037      Air            1.160
4-3         SLIDE PROJECTOR LENS
   1         10.24807       0.3057      SK4            2.590
   2         -7.12157       0.0219      Air            2.590
   3          1.66975       0.5764      SK4            2.130
   4          4.07843       0.4103      Air            1.720
   5         -2.90882       0.0895      SF8            1.350
   6          1.22930       0.6322      Air            1.120
   7           Stop         0.0230      Air            1.050
   8          5.45922       0.2559      SK4            1.220
   9         -1.51086       2.8789      Air            1.220
5-1           PETZVAL LENS  f/1.4   14 DEG FOV
   0          0.00000   1.00000E+07      Air
   1          1.39649       0.3597      LAKN12         1.560
   2         -3.24586       0.0445      Air            1.560
   3         -2.36948       0.3983      SF8            1.480
   4          2.73116       0.7215      Air            1.280
   5          1.09027       0.6167      LAKN12         1.240
   6         -2.12417       0.1691      Air            1.240
   7         -0.88883       0.2000      SF4            0.760
   8         38.90132       0.3963      Air            0.700
5-2         100 mm f/2.8  PETZVAL LENS
   1          1.37404       0.6350      SK4            1.700
   2         -3.16813       0.2354      SF1            1.700
   3        -13.01628       0.1825      Air            1.700
   4           Stop         0.2500      Air            0.984
   5         -1.62596       0.1968      F5             0.940
   6          1.04471       0.5113      Air            0.940
   7          2.47184       0.2924      SK4            1.380
   8         -1.95684       2.1622      Air            1.380
6-1          DOUBLE GAUSS LENS  f/2.5
   1          3.19354       0.4902      LAK9           3.680
   2          9.50214       0.0226      Air            3.500
   3          1.89471       0.5421      LAK9           2.880
   4          5.17823       0.2827      SF8            2.880
   5          1.28019       0.6849      Air            1.780
   6          Stop          0.6663      Air            1.234
   7         -1.43984       0.2009      F2             1.680
   8        -25.74193       0.4418      LAK9           2.420
   9         -2.01304       0.0202      Air            2.420
  10         14.99510       0.4021      LAK9           2.900
  11         -4.21828       2.7891      Air            2.900
6-2         50 mm f/1.8 SLR CAMERA LENS
   0          0.00000   1.00600E+07      Air
   1          1.33078       0.2292      BASF2          1.640
   2          3.37474       0.0111      Air            1.540
   3          1.13167       0.2676      LAKN13         1.360
   4         14.28792       0.0801      SF2            1.360
   5          0.65856       0.3848      Air            0.890
   6           Stop         0.4024      Air            0.750
   7         -0.62845       0.0812      SF8            0.840
   8          5.61975       0.3107      LAK8           1.290
   9         -0.95580       0.0110      Air            1.290
  10         -8.56371       0.2358      LAKN12         1.580
  11         -1.47119       0.0110      Air            1.580
  12          3.06663       0.1810      LAK8           1.730
  13        -46.37912       1.3979      Air            1.730
6-3          f/1. 5 DEG FOV DOUBLE GAUSS
   1          3.55191       1.3991      LAF2           4.430
   2          0.00000       0.0088      Air            4.430
   3          1.70434       0.9385      PSK3           2.940
   4        -16.23815       0.2522      SF1            2.940
   5          0.98604       0.4336      Air            1.620
   6            Stop        0.2777      Air            1.600
   7         -1.64238       0.2702      SF1            1.620
   8          1.80278       1.1586      LAF2           2.050
   9         -2.33364       0.4472      Air            2.050
  10          1.65927       1.0438      LAF2           1.860
  11         14.41124       0.8128      Air            1.860
6-4         25 MM F/.85 DOUBLE GAUSS
   1         -2.83155       0.5001       LASF36A       2.280
   2         -2.19063       0.0700       Air           2.420
   3          1.97886       0.3494       LASF3         1.880
   4        -10.65614       0.1067       Air           1.880
   5         -2.75248       0.0805       SF6           1.660
   6        -21.99313       0.0100       Air           1.880
   7          0.69612       0.2000       LASF3         1.220
   8          0.67653       0.0806       SF6           0.980
   9          0.46644       0.3260       Air           0.810
  10            Stop        0.1256       Air           0.679
  11         -0.60866       0.0507       SF57          0.700
  12          0.81321       0.4156       LASFN31       1.060
  13         -0.91272       0.0105       Air           1.060
  14          1.55910       0.2367       LASFN31       1.240
  15         -6.18794       0.0104       Air           1.240
  16          0.90347       0.3699       LASF3         1.120
  17          1.99074       0.3431       Air           0.840
7-2         TELEPHOTO LENS f/5.6
   0          0.00000    1.000E+07      Air
   1          0.80002       0.2866      BK10           1.020
   2         -2.18598       0.0758      BASF10         1.020
   3          2.91954       0.0774      Air            0.840
   4           Stop         0.9228      Air            0.776
   5         -0.55672       0.0759      ZKN7           0.780
   6         -0.55398       0.1005      NLAF33         0.840
   7         -1.04609       0.0156      Air            0.980
   8         34.63436       0.1365      SF1            1.070
   9         -2.84343       2.4796      Air            1.070
7-3          F/2.8 180 mm TELEPHOTO LENS
   1          3.30455       0.4174      PK2            2.730
   2        -13.00895       0.0754      Air            2.730
   3         -7.01395       0.2347      F5             2.730
   4         11.92290       0.1827      Air            2.500
   5           Stop         0.1204      Air            2.380
   6          1.66033       0.3696      FPL53          2.540
   7          2.99976       0.2152      SF1            2.540
   8          2.56344       1.0264      Air            2.320
   9          4.08741       0.2193      LLF6           2.020
  10        -16.91399       0.6573      Air            2.020
  11         -1.65427       0.2964      K10            1.600
  12         -1.11837       0.1444      SF1            1.700
  13         -2.90997       0.7049      Air            1.700
  14         -1.62087       0.1774      ZK1            1.700
  15          3.49063       0.3314      SF5            1.840
  16         -2.76130       1.6287      Air            1.840
7-4         400 mm TELEPHOTO LENS f/4
   0          0.00000   1.00000E+08      Air
   1         10.93502       0.3166      FK5            4.200
   2        -84.15616       0.0236      Air            4.200
   3          3.37372       0.8165      FK51           3.980
   4        -19.47681       0.6471      Air            3.980
   5        -10.65171       0.3150      SF1            3.160
   6          7.89857       0.3695      Air            2.900
   7           Stop         2.3993      Air            2.766
   8          3.83829       0.3912      SF1            2.020
   9         -2.76429       0.2047      LAF3           2.020
  10          1.69264       1.3484      Air            1.700
  11          1.95739       0.2058      SF1            1.860
  12          1.49895       0.2767      FK5            1.860
  13          4.18140       4.8085      Air            1.700
7-5         APOCHROMAT TELEPHOTO FOR SLR
   1          2.63238       0.3731      LAKN-12        4.360
   2          2.06779       1.7493      FPL-53         3.800
   3         -4.49150       0.3731      SK-16          3.800
   4         -9.97634       1.1447      Air            4.360
   5        -15.42440       0.1976      SF-1           2.240
   6         48.62893       0.3277      Air            2.140
   7         -2.29235       0.1980      LAK-10         2.040
   8        -13.07957       0.0948      Air            2.140
   9          3.51306       0.5882      FPL-53         2.100
  10          2.93062       0.1713      Air            1.880
  11          5.27029       0.1937      SF-1           2.100
  12         52.33926       1.4482      Air            1.880
  13            Stop        2.6049      Air            1.383
  14         -2.84691       0.1463      LAK-10         1.220
  15          3.23717       0.2169      F-5            1.300
  16         -3.38932       9.8926      Air            1.300
7-6         CEMENTED ACHROMAT  WITH 2X EXTENDER
   1         12.80180       0.4343      BAK1           3.410
   2         -9.06229       0.3208      SF8            3.410
   3        -37.65534       7.5539      Air            3.410
   4         15.62625       0.2301      BAK1           2.320
   5          4.51190       0.1986      SF8            2.320
   6          6.43392      23.3191      Air            2.320
8-1          INVERTED TELEPHOTO   f/3.5
   1         16.19458       0.0964      PK50           0.820
   2          0.53435       0.5895      Air            0.650
   3          0.57741       0.1178      SF1            0.820
   4          0.53133       0.2701      Air            0.700
   5          2.35781       0.3038      LF7            0.820
   6         -1.51618       0.2158      Air            0.820
   7           Stop         0.0740      Air            0.640
   8          0.00000       0.0709      SF1            0.820
   9          0.72364       0.2104      LAK21          0.760
  10         -1.28454       2.1689      Air            0.760
8-2         10 MM CINEGON f/2.8
   1         -3.40689       0.0874      LAF2           1.420
   2          0.80610       0.4349      PSK3           1.210
   3         -1.56736       0.0467      Air            1.210
   4          1.52317       0.2421      SF3            0.980
   5         -1.52317       0.0649      K7             0.980
   6          0.29342       0.6220      Air            0.530
   7            Stop        0.3013      Air            0.252
   8          0.00000       0.0604      SF1            0.640
   9          1.08515       0.1488      SK16           0.640
  10         -0.86725       0.0153      Air            0.640
  11          1.55722       0.1296      LAKN12         0.690
  12         -1.42496       0.0154      Air            0.690
  13          0.83187       0.1878      PSK3           0.670
  14         -0.75273       0.0598      SF1            0.670
  15          1.37683       0.6194      Air            0.590
8-3      INVERTED TELEPHOTO FOR CAMERA
      0       0.0000 0.100000E+11         Air
      1       1.3936        0.286         LAF2         1.48
      2      -6.6020        0.118         LLF6         1.48
      3       0.5106        0.933         Air          0.88
      4       0.5237        0.092         SF5          0.60
      5       0.3319        0.490         Air          0.50
      6          STP        0.013         Air          0.52
      7       2.0899        0.265         LAK10        0.68
      8      -0.6855        0.046         Air          0.68
      9       1.8935        0.197         K5           0.68
     10      -0.4378        0.060         SF1          0.68
     11      -1.1966        0.010         Air          0.68
     12       0.8468        0.113         K5           0.58
     13      -0.8097        0.079         F5           0.58
     14       0.5542        0.654         Air          0.50
9-1         100 DEGREE FOV LENS
   1         -9.23618       0.2493      SK4            2.680
   2          1.28960       0.0924      Air            1.960
   3          1.38202       0.5414      SF1            1.980
   4         -5.43835       0.2136      SK4            1.980
   5          0.89262       0.4126      Air            1.300
   6         -1.84275       0.1394      SF1            1.300
   7         -1.52432       0.2066      SK4            1.400
   8         -2.18352       1.1359      Air            1.400
   9           Stop         0.2989      Air            0.875
  10         -6.62446       0.2255      SK4            1.330
  11         -1.97414       0.0213      Air            1.330
  12         25.66874       0.3400      SK4            1.400
  13         -1.03832       0.1463      SF1            1.400
  14         -4.20190       0.7575      Air            1.570
  15          8.25177       0.2069      SF1            2.100
  16          2.41933       0.0210      Air            1.980
  17          2.45181       0.4422      SK4            2.100
  18         -3.42632       0.0712      Air            2.100
  19          2.16988       0.3167      SK4            2.100
  20         33.66520       1.5604      Air            2.100
9-2          120 DEGREE FOV LENS
   1          0.00000       0.6912      BAK4           6.950
   2          2.43429       0.8803      Air            4.300
   3          2.70448       1.2685      SF1            4.080
   4         -8.65512       0.7206      SK4            4.080
   5          1.25812       0.7045      Air            2.020
   6         -2.76763       0.6868      SF1            2.020
   7         -2.17607       0.6906      SK4            2.120
   8         -4.38586       0.2195      Air            2.120
   9         14.51959       0.5684      SK4            1.800
  10         -1.55522       0.2486      SF1            1.800
  11         -5.21620       0.0621      Air            1.800
  12           Stop         0.6906      Air            1.450
  13        -10.38549       0.4657      SK4            2.270
  14         -2.58754       0.6637      Air            2.270
  15         95.06452       0.3271      SK4            2.700
  16         -5.07961       0.2841      Air            2.700
  17         -2.20197       0.2424      SF1            2.650
  18         -8.45074       0.2287      Air            3.030
  19         11.44286       0.3148      SF1            3.750
  20          4.63629       0.0653      Air            3.560
  21          5.07851       0.9991      SK4            3.750
  22         -3.49877       0.0612      Air            3.750
  23          3.22557       0.8110      SK4            3.750
  24         23.74864       1.9076      Air            3.750
9-3           160 DEGREE  f/2.
   1         21.45628       0.5342      BK7           11.270
   2          3.56551       2.0174      Air            6.420
   3          0.00000       0.6296      BK7            6.620
   4          5.38256       1.9296      Air            5.100
   5         -5.38256       0.6296      BK7            5.100
   6          0.00000       3.6842      Air            6.620
   7          5.08416       0.5276      SF4            2.400
   8        -16.49561       0.0280      Air            2.400
   9          2.30452       0.7150      SF4            2.400
  10          2.22341       0.1560      Air            1.340
  11           Stop         0.2876      Air            1.260
  12         -1.96261       0.4509      SF8            1.380
  13          2.54563       0.7439      LAKN7          2.200
  14         -2.54563       0.0309      Air            2.200
  15         11.68551       0.6871      LAKN7          2.380
  16         -1.53496       0.2347      SF4            2.380
  17         -5.07431       0.0289      Air            2.660
  18          3.38448       0.5704      LAKN7          2.780
  19         30.24403       2.2006      Air            2.780
9-4         170 DEGREE f/1.8
   1          4.97794       0.1796      BK7            4.650
   2          1.19204       1.0797      Air            2.350
   3        -10.73562       0.1939      SK5            2.250
   4          0.97296       0.4213      Air            1.680
   5          1.70682       0.5228      SF1            1.660
   6         -1.38378       0.2399      LAK9           1.660
   7          1.13444       2.4304      Air            1.200
   8          1.37528       0.2991      LAK9           1.060
   9          0.51233       0.6489      PSK3           0.880
  10         -0.79167       0.0205      Air            0.880
  11         -0.77634       0.0799      SF1            0.760
  12         -1.90832       0.1200      Air            0.820
  13           Iris         0.1207      Air            0.670
  14          0.96375       0.3331      PSK3           0.820
  15         -0.89273       0.0792      Air            0.820
  16         -0.73648       0.1076      SF1            0.690
  17         -1.42818       0.8308      Air            0.820
9-5         210 DEG FOV PROJECTION LENS
   1         18.53034       0.6999      K5            13.700
   2          3.42384       2.7086      Air            6.570
   3          0.00000       0.5999      K5             6.570
   4          6.04912       1.1030      Air            4.500
   5         -5.39443       0.5892      K5             4.050
   6         -2.90775       0.4097      SF1            4.150
   7         -2.82644       0.3769      PK2            4.150
   8          2.20673       0.6103      Air            3.000
   9          0.00000       0.4885      SF3            3.100
  10         -5.11554       0.5160      Air            3.100
  11          2.95828       0.4185      SSKN5          2.760
  12          3.74636       0.7503      Air            2.600
  13          5.14042       0.3987      SF3            2.260
  14          8.98951       0.6366      Air            2.260
  15         -7.49724       0.4585      SF5            2.260
  16         -5.30447       0.2918      Air            2.260
  17            Stop        0.3532      Air            1.270
  18         -4.06978       0.2042      SF8            1.520
  19          6.90124       0.5040      LAKN7          2.020
  20         -3.81584       0.0200      Air            2.020
  21          8.67629       0.6256      LAKN7          2.200
  22         -1.51779       0.3819      SF3            2.200
  23         -5.93765       0.0239      Air            2.520
  24          2.45072       0.5055      LAKN7          2.720
  25         16.23018       2.2162      Air            2.720
9-6      Panoramic Camera
      0       0.0000    1.000E+11       Air
      1       0.0000      -7.4044       Air          18.987
      2       3.0398     -28.0849       MIRROR        4.649
      3      -1.1073      -0.2300       LAKN7         0.875
      4      -6.1073      -0.0320       Air           0.811
      5         Stop      -0.7390       Air           0.800
      6       1.2583      -0.7643       SF1           0.615
      7      -1.0051      -0.6869       Air           0.666
      8      -5.5022      -0.4769       LAKN7         1.115
      9       1.6652      -4.0005       Air           1.219
     10      -1.2396      -0.8003       LAK21         1.249
     11      -0.8902      -0.5882       Air           0.917
10-2        10 X EYEPIECE
   0           Pupil        0.9160      Air            0.200
   1          4.54506       0.3677      SK5            1.060
   2         -0.85817       0.0238      Air            1.060
   3          1.10780       0.3488      PK2            0.980
   4         -0.68646       0.1192      SF1            0.980
   5          8.87539       0.5853      Air            0.900
10-3        10 X EYEPIECE
   0           Pupil        0.9870       Air           0.200
   1         -5.36474       0.2682       PK2           1.080
   2         -1.19131       0.0210       Air           1.080
   3          3.16992       0.2684       PK2           1.140
   4         -1.20795       0.0209       Air           1.140
   5          1.02345       0.3585       PSK3          1.040
   6         -0.80733       0.1359       SF1           1.040
   7          1.25388       0.4709       Air           0.800
10-4        PLOSSL EYEPIECE
   0           Pupil        0.761        Air           0.200
   1          2.12177       0.1182       SF1           0.980
   2          0.90425       0.2783       SK14          0.980
   3         -1.77007       0.0197       Air           0.980
   4          1.77007       0.2783       SK14          0.980
   5         -0.90425       0.1182       SF1           0.980
   6         -2.12177       0.7250       Air           0.980
10-5         ERFLE EYEPIECE 60 DEG FOV
   0           Pupil        0.7050      Air            0.197
   1         -0.85871       0.0900      SF1            0.780
   2          2.64172       0.5085      SK14           1.340
   3         -0.93336       0.0207      Air            1.340
   4          2.40312       0.4450      LAK10          1.730
   5         -1.73284       0.0210      Air            1.730
   6          1.06666       0.5837      FK3            1.400
   7         -0.98995       0.1993      SF1            1.400
   8          1.48913       0.4971      Air            1.140
10-6       25 MM FL F/5 EYEPIECE WITH INTERNAL IMAGE
      0       0.0000 0.100000E+11                      0.00
      1          STP        0.772                      0.20
      2      -1.4463       0.3686       LAKN22        0.740
      3      -0.6331       0.2067          SF1        0.900
      4      -1.2377       0.1980                     1.120
      5       2.3997       0.4924         ZKN7        1.440
      6      -1.5105       0.2017          SF1        1.440
      7      -2.4327       1.5941                     1.440
      8       0.9460       0.8486       LAKN22        1.400
      9       0.9786       1.3533                     0.920
     10      -2.5607       0.1502         SK16        0.540
     11       1.3128       0.1433          SF1        0.620
     12      11.1380      -1.2983                     0.620
     13       0.0000       0.0000                     0.730
11-1        10 X MICROSCOPE OBJECTIVE
   0           Stop         0.0119      Air            0.295
   1          0.51518       0.1387      K5             0.390
   2         -0.36923       0.0459      F2             0.390
   3         -4.41903       0.3404      Air            0.390
   4          0.45211       0.1323      K5             0.330
   5         -0.23655       0.0383      F2             0.330
   6         -0.83668       0.2967      Air            0.330
   7          0.00000       0.0068      K5 cover glass 0.063
   8          0.00000       0.0000
11-2        20 X MICROSCOPE OBJECTIVE
   0           Stop         0.0008      Air            0.320
   1          0.90753       0.1027      K10            0.360
   2         -0.30270       0.0413      SF1            0.360
   3         -1.11024       0.0057      Air            0.360
   4          0.42185       0.0854      SK5            0.360
   5          0.00000       0.2333      Air            0.360
   6          0.19915       0.1017      SK5            0.200
   7         -0.12326       0.0309      F5             0.200
   8          0.00000       0.0681      Air            0.200
   9          0.00000       0.0070      K5 cover glass 0.032
11-3        4MM APOCHROMATIC OBJECTIVE
   0          0.00000       6.5833      Air            0.630
   1          0.37307       0.0258      LAKN12         0.320
   2          0.17458       0.1361      CaF2           0.260
   3         -0.16802       0.0258      LAKN12         0.260
   4         -0.62359       0.0099      Air            0.320
   5          0.41731       0.0606      PSK3           0.320
   6         -0.68979       0.0067      Air            0.320
   7            Stop        0.0067      Air            0.260
   8          0.16865       0.1072      CaF2           0.240
   9         -0.17242       0.0220      F1             0.240
  10         -0.39327       0.0099      Air            0.240
  11          0.09842       0.0773      SK5            0.180
  12          0.00000       0.0083      Air            0.180
  13          0.00000       0.0070      K5             0.013
11-4        UV REFLECTING OBJECTIVE   53X
   0          Ent. Pupil   -1.1545     Air             0.184
   1          2.48604       0.0350     Silica          0.360
   2          7.53409       0.9731     Air             0.360
   3          0.18197      -0.4995     Mirror          0.160
   4          0.72977       0.5776     Mirror          1.100
   5          2.87713       0.0427     CaF2            0.600
   6          0.48327       0.0016     Air             0.450
   7          0.23165       0.1861     CaF2            0.400
   8         -1.27837       0.0011     Air             0.400
11-5         98 X OIL IMMERSION MICROSCOPE OBJECTIVE
   0          0.00000       6.8058       Air           0.630
   1          0.21035       0.0879       CaF2          0.210
   2         -0.12523       0.0216       F2            0.210
   3         -1.50811       0.0073       Air           0.210
   4          0.12314       0.0535       CaF2          0.190
   5         -0.60262       0.0215       F2            0.190
   6          1.20979       0.0031       Air           0.190
   7          0.09339       0.0321       SK14          0.145
   8          0.40165       0.0030       Air           0.130
   9          0.03356       0.0382       BK7           0.067
  10          0.00000       0.0060       Oil           0.049
  11          0.00000       0.0067       K5            0.029
12-3      FLAT-PORT,70 MM CAMERA LENS
      0                 1.000E+10        SEAWATER
      1        Flat        1.5000        PYREX        5.700
      2        Flat        0.2000        Air          5.700
      3      30.0125       0.3000        SK16         4.000
      4       2.3720       3.4344        Air          3.200
      5       2.3500       0.7040        LAKN7        1.840
      6     -11.6351       0.4022        Air          1.840
      7        Iris         0.397        Air          0.951
      8      -1.3367       0.1205        SF8          1.140
      9       9.3756       0.0702        Air          1.320
     10      -4.7790       0.2331        LAKN12       1.320
     11      -1.3442       0.0186        Air          1.480
     12       7.0017       0.3226        LAKN13       1.800
     13      -6.6768       3.6035        Air          1.800
     14       0.0000       0.0000                     3.220
12-5        WATER-DOME CORRECTOR
   0          0.00000  1.00000E+07     Seawater
   1          2.90001       1.2500     Acrylic         5.000
   2          1.65000       0.4475     Air             2.900
   3          2.00100       0.5218     FK5             2.700
   4          3.01500       0.9755     Air             2.600
   5         -2.45000       0.2000     BASF10          2.600
   6         -3.40400       0.0850     Air             2.700
   7        -14.65045       0.4017     BK10            2.600
   8         -2.50700       5.6990     Air             2.700
12-6        IN-WATER LENS WITH DOME
   1          2.72436       0.2435    BK7              2.230
   2          1.22947       1.4244    Air              1.760
   3          1.06980       0.3256    LAFN21           0.940
   4         -5.97491       0.0558    Air              0.940
   5           Stop         0.1091    Air              0.540
   6         -0.78030       0.0919    SF4              0.620
   7          1.92244       0.0534    Air              0.740
   8         -6.13483       0.1388    LAFN21           0.740
   9         -0.85199       0.0170    Air              0.860
  10         -5.72057       0.1132    LAFN21           0.900
  11         -1.41092       1.4470    Air              0.980
13-1        5 X LASER BEAM EXPANDER
   1          0.29627       0.0620      SF8            0.200
   2            Flat        2.4812      Air            0.200
   3            Flat        0.1320      SF8            0.700
   4         -1.48084                   Air            0.700
13-2        5 X LASER BEAM EXPANDER
   1         -0.34429       0.0300      SF8            0.150
   2           Flat         1.9154      Air            0.200
   4         -1.72112                   Air            0.700
13-3        50 X LASER BEAM EXPANDER
   1         -0.18905       0.0590      F2             0.090
   2          0.69752      11.0680      Air            0.180
   3        -15.13200       0.3360      SF8            3.900
   4         -7.85965       0.0390      Air            4.100
   5           Flat         0.3694      SF8            4.100
   6        -16.11744                   Air            4.100
13-4        4 X BINOCULAR
   0          0.00000   1.0000E+10      Air
   1          2.39778       0.1360      Plexiglas      1.440
   2          0.00000       3.5228      Air            1.440
   3         -0.96796       0.0500      Plexiglas      0.380
   4          1.65724                   Air            0.380
13-5        POWER CHANGER .75 X
   0          0.00000  1.00000E+10      Air
   1        -16.18482       0.1422      LF7            0.680
   2         -0.84948       0.0504      SK16           0.680
   3          2.79513       0.7857      Air            0.680
   4         -7.39751       0.1167      LF7            0.900
   5          1.33365       0.2242      SK16           1.040
   6         -2.25821                   Air            1.040
13-6          ALBADA VIEWFINDER
   0        Ent. Pupil      0.6000      Air            0.200
   1         -5.80200       0.0820      K5             0.550
   2          3.30100       0.9432      Air            0.550
   3         -1.59700       0.1230      K5             0.780
   4         -1.03200                   Air            0.860
13-7        DOOR VIEWER
   1          0.99393       0.0600       K5            0.900
   2          0.52338       0.1217       Air           0.620
   3          0.00000       0.0400       K5            0.700
   4          0.24502       0.1675       Air           0.360
   5         -0.24502       0.0400       K5            0.360
   6          0.00000       0.6016       Air           0.700
   7          0.95167       0.1500       K5            0.480
   8         -0.95167       0.5000       Air           0.480
   9        exit pupil                   Air           0.196
14-1        1 TO 1 RELAY
   0          0.00000      5.60183      Air            1.200
   1          3.55526       0.5591      LAKN12         1.780
   2         47.20269       0.7095      Air            1.780
   3          2.46089       0.6425      LAKN12         1.520
   4         -2.86878       0.1675      BAF4           1.520
   5          2.82682       0.0138      Air            1.160
   6          1.48812       0.2976      SSK4A          1.200
   7         -1.52102       0.1209      KZFSN4         1.200
   8          0.96535       0.3187      Air            0.900
   9            Stop        0.3187      Air            0.812
  10         -0.96535       0.1209      KZFSN4         0.900
  11          1.52102       0.2976      SSK4A          1.200
  12         -1.48812       0.0138      Air            1.200
  13         -2.82682       0.1675      BAF4           1.160
  14          2.86878       0.6425      LAKN12         1.520
  15         -2.46089       0.7095      Air            1.520
  16        -47.20269       0.5591      LAKN12         1.780
  17         -3.55526       5.5973      Air            1.780
14-2        1:1 COPY LENS f/11  675 MM FL
   0          0.00000       50.000      Air            50.00
   1          4.64461       0.9205      SK14           4.960
   2        -31.49862       0.3707      BALF5          4.960
   3          3.56406       0.1643      Air            3.730
   4          4.88823       0.3725      FK51           3.760
   5          6.96846       1.4193      Air            3.500
   6           Iris         1.4193      Air            2.040
   7         -6.96846       0.3725      FK51           3.500
   8         -4.88823       0.1643      Air            3.760
   9         -3.56406       0.3707      BALF5          3.730
  10         31.49862       0.9205      SK14           4.960
  11         -4.64461      49.9560      Air            4.960
14-3        6 X COPY LENS
   0          0.00000      16.6667      Air            5.000
   1          2.20687       0.7634      LAKN12         2.380
   2        -11.63771       0.0444      Air            2.380
   3         -8.36718       0.3558      LF5            2.040
   4          1.53422       0.1418      Air            1.680
   5          3.02110       0.4607      LAKN7          1.740
   6          6.51790       0.2662      Air            1.540
   7            Stop        0.2441      Air            1.410
   8         -2.69626       0.4767      LAKN7          1.500
   9         -2.00098       0.1345      Air            1.740
  10         -1.51146       0.1966      LF5            1.680
  11        -11.30521       0.0160      Air            1.960
  12        -25.44453       0.5831      LAKN12         2.150
  13         -2.15957       9.1020      Air            2.150
14-4        RIFLE SIGHT
   1          2.69406       0.1417      BK7            0.870
   2         -2.61456       0.0984      F2             0.870
   3        217.12603       5.8379      Air            0.870
   4          0.58062       0.1968      BK7            0.650
   5          0.00000       1.0416      Air            0.650
   6          0.23026       0.0915      SSK4A          0.260
   7          2.23574       0.0530      Air            0.260
   8         -0.26421       0.0322      SF2            0.210
   9          0.18961       0.0396      Air            0.210
  10          0.44149       0.0942      SSK4A          0.250
  11         -0.22138       2.6157      Air            0.250
  12         -3.19380       0.1783      SF4            1.100
  13          1.49598       0.3679      SK2            1.360
  14         -1.49598       0.3356      Air            1.360
  15          2.24645       0.2754      BAF3           1.540
  16         -3.51257       3.9275      Air            1.540
14-5        EYEPIECE RELAY
   1         15.49980       0.0880      SF8            0.760
   2          0.49076       0.3281      BK7            0.760
   3         -0.84226       0.0182      Air            0.760
   4          0.65510       0.2806      K5             1.060
   5          2.99551       2.6373      Air            1.000
   6          3.80120       0.0808      BASF2          0.800
   7          0.75419       0.2317      SK5            0.800
   8         -1.39190       0.0201      Air            0.800
   9          1.39190       0.2317      SK5            0.800
  10         -0.75419       0.0808      BASF2          0.800
  11         -3.80120       1.9231      Air            0.800
14-6         RELAY LENS 1/5X
   0          0.00000       5.0000      Air            0.320
   1          1.41762       0.2500      SF4            1.100
   2          0.91371       0.1829      Air            0.840
   3         -1.19430       0.3304      LAFN21         0.840
   4         -1.20238       0.0209      Air            1.100
   5          5.54790       0.3500      LAFN21         1.100
   6         -1.89990       0.0205      Air            1.100
   7           Stop         0.1508      Air            0.988
   8         -0.99151       0.2493      SF4            1.000
   9          1.48728       0.3602      LAK10          1.280
  10         -1.50369       0.0207      Air            1.280
  11          1.67360       0.2523      LAFN21         1.280
  12         -4.49468       1.2986      Air            1.280
15-10    Ritchey-Chretien
      0       0.0000   1.0000E+11       Air
      1         Stop      63.0701       Air          25.000
      2    -187.5040     -63.0701       MIRROR       25.427
      3     -98.1833      81.8111       MIRROR        8.773
15-2          CASSEGRAIN LENS  ZnS 3.2 to 4.2 micron
   1         43.46138       0.3797     ZnS             4.600
   2          0.00000       4.0000     Air             4.600
   3         -9.79524       0.5500     ZnS             4.160
   4        -11.90806      -0.5500     Mirror/ZnS      4.380
   5         -9.79524      -3.8200     Air             4.160
   6         -6.38180       3.9792     Mirror          1.450
15-3         f/1.57 15 DEGREE CATADIOPTRIC
   1         -9.69598       0.2750      BK7            2.750
   2        -12.89434       1.3662      Air            2.850
   3         -6.50950      -1.3662      Mirror         2.800
   4        -12.89434      -0.2750      BK7            2.850
   5         -9.69598       0.2750      Mirror/BK7     2.750
   6        -12.89434       1.3662      Air            2.850
   7        -40.57582       0.2311      SF2            1.620
   8          1.46999       0.5096      LAKN7          1.620
   9         -3.22355       0.1192      Air            1.620
  10          1.25132       0.1832      SK16           1.480
  11          1.68256       0.5849      Air            1.340
15-4        f/11 1000 MM CASSEGRAIN
   1         -5.16251       0.4525      BK7            5.050
   2         -5.41781       8.5519      Air            5.280
   3        -22.42740      -8.1591      Mirror         4.920
   4         -9.88275       7.9423      Mirror         1.080
   5         -4.02610       0.1388      BK7            1.400
   6         21.05001       0.0180      Air            1.500
   7          3.38011       0.3947      SF1            1.500
   8          4.09688       1.8171      Air            1.400
15-5        f/14 Cassegrain Telescope
   1        -13.69544       0.6000      Silica         5.250
   2        -13.88461      10.9993      Air            5.400
   3        -32.61588     -10.9993      Mirror         5.020
   4        -13.88461      -0.6000      Silica         1.220
   5        -13.69544       0.6000      Mirror/Silica  1.080
   6        -13.88461      10.4992      Air            1.100
   7         10.01837       0.1926      BK7            1.700
   8         21.85435       1.0287      Air            1.700
   9         -7.29090       0.1926      SF1            1.700
  10         -9.45275       3.5358      Air            1.700
15-6        10 INCH FL f/1.23 CASSEGRAIN LENS
   1         19.68695       0.5412      BK7            8.250
   2          0.00000       2.1942      Air            8.250
   3        -13.00717       0.3509      BK7            7.800
   4        -18.93058       1.8118      Air            7.900
   5        -10.38543       0.3987      BK7            7.700
   6        -15.04273       3.7922      Air            7.900
   7        -12.97655      -3.7922      Mirror         8.000
   8        -15.04273       3.2927      Mirror         3.660
   9        -24.65875       0.1590      BK7            2.160
  10        -10.22278       0.0200      Air            2.160
  11          2.18312       0.3643      BK7            1.980
  12          2.28226       0.3555      Air            1.700
15-7        SCHMIDT OBJECTIVE
   1          0.00000       0.3000     Silica          5.600
   2          0.00000      20.0000     Air             5.600
   3        -20.00000     -10.0138     Mirror          8.100
15-8         REFLECTING OBJECTIVE f/2.5
   1          1.89149      -1.7946      Mirror         0.800
   2          3.63835       1.7946      Mirror         2.550
   3          1.89149       0.3193      BK7            1.800
   4          1.49667       0.3410      Air            1.600
   5          4.41392       0.3000      SF1            1.520
   6          4.53570       2.8493      Air            1.360
15-9        250 INCH , F/10 CASSEGRAIN
   1       -101.99116     -37.2973      Mirror        25.350
   2        -36.67501      47.4148      Mirror         7.100
   3         18.08219       0.2500      SK16           2.170
   4         10.42742       0.3600      LF5            2.170
   5         51.26888       1.1030      Air            2.170
   6         -9.45943       0.2500      LLF1           1.960
   7          2.80216       0.5000      LF5            1.960
   8         27.65025       5.6949      Air            1.960
16-1         PERISCOPE LENS
   0          0.00000   1.00000E+05     Air
   1         -1.74000       0.1309     LAKN9           1.340
   2         -1.95700       0.1969     LAF2            1.600
   3         -1.18700       0.9965     Air             1.600
   4          0.00000       0.2238     LAKN7           2.320
   5         -4.78000       0.8560     Air             2.320
   6          2.90200       0.8068     SK4             2.600
   7         -2.03200       0.2000     SF1             2.600
   8          0.00000      15.5160     Air             2.600
   9          2.54500       0.2602     LAF20           1.930
  10          1.82000       0.6260     F6              1.930
  11          0.00000       0.9772     Air             1.930
  12         -7.96000       0.3254     FK51            1.240
  13         -2.20600       0.3111     LLF1            1.450
  14          0.00000       0.1871     Air             1.450
  15          2.00100       0.4431     LAKN22          1.450
  16         -1.32500       0.1416     SF5             1.450
  17          0.91400       0.2715     Air             0.790
  18           Iris         0.2715     Air             0.810
  19         -0.65100       0.1461     SF5             0.830
  20          2.63000       0.5657     LAKN22          1.450
  21         -1.30800       0.0202     Air             1.450
  22         -3.31300       0.2809     LAF2            1.450
  23         -1.98600       0.0198     Air             1.930
  24         -6.34700       0.5149     LAF20           1.620
  25         -2.03200       0.0999     Air             1.930
  26          0.00000       5.2561     SK16            1.710
  27          0.00000       3.5520     Air             1.710
16-2          65 MM  FORMAT  PERISCOPE
   1         -2.53781       0.4255     LAFN23          1.270
   2         -0.78495       0.3603     SF1             1.400
   3         -1.77334       0.9654     Air             1.980
   4          0.00000       0.4220     LAKN12          3.160
   5         -4.27376       1.4623     Air             3.160
   6          4.82423       0.8338     LAKN12          3.860
   7          0.00000       0.3837     Air             3.860
   8          3.09811       0.8996     PK2             3.560
   9         -5.31950       0.2935     SF1             3.560
  10          7.95826       0.7202     Air             3.200
  11         -3.77796       0.2617     SK4             3.200
  12          0.00000       0.4529     SF1             3.260
  13         -7.85088      10.1482     Air             3.260
  14          4.47828       0.7039     SF5             3.110
  15         -9.06419       0.8307     Air             3.110
  16          0.00000       0.3743     FK51            2.280
  17         -3.34290       0.1705     K7              2.280
  18         12.13393       0.0933     Air             2.280
  19          1.24162       0.5661     LAKN22          1.750
  20         -2.08402       0.1537     SF5             1.750
  21          0.70219       0.7595     Air             1.100
  22         -0.76030       0.1545     SF5             1.000
  23         12.32645       0.4786     LAKN22          1.130
  24         -1.19560       0.0192     Air             1.130
  25         -2.07104       0.3773     LAF2            1.080
  26         -1.71724       0.0292     Air             1.180
  27         -3.70720       0.3169     LAF20           1.080
  28         -1.95831       0.4416     Air             1.180
  29           Iris         6.5755     Air             0.824
17-2        FLIR SYSTEM
   1          7.68650       0.6227     Germanium       9.180
   2          9.77390       5.9974     Air             9.000
   3          2.06920       0.1753     Germanium       2.850
   4          2.04300       0.4994     Air             2.700
   5         12.77000       0.1750     ZnSe            2.500
   6          6.93060       1.0077     Air             2.300
   7        -46.96900       0.1000     Germanium       1.300
   8          2.99040       2.2350     Air             1.200
   9          0.00000       1.2909     Scan Mirror     1.800
  10          3.39650       0.2000     Germanium       2.160
  11          4.38450       0.3670     Air             2.050
  12         -6.21400       0.1500     ZnSe            2.050
  13         -7.13230       2.3190     Air             2.160
  14          1.78200       0.1920     Germanium       1.600
  15          2.14470       0.6745     Air             1.500
  16          0.00000       0.0400     Germanium       1.000
  17          0.00000       0.2682     Air             1.000
17-3        IR LENS 3.2 TO 4.2 MICRON
   1          8.56517       0.3249      Silicon        3.260
   2         40.18391       1.0590      Air            3.160
   3         -7.34648       0.2048      Germanium      2.300
   4        -16.83771       2.0131      Air            2.380
   5          3.87768       0.1571      Germanium      2.430
   6          3.46173       0.1561      Air            2.300
   7         18.52989       0.2179      Silicon        2.430
   8        -11.30569       2.7012      Air            2.430
17-4     10 X Beam Expander, 10.6 micron
      1         Stop       0.5000         Air         0.300
      2      -0.2745       0.0500         ZNSE        0.300
      3       0.0000       1.2921         Air         0.369
      4      -2.4955       0.5000         ZNSE        2.824
      5      -1.7706       0.0200         Air         3.010
      6     -28.1662       0.3100         ZNSE        3.559
      7      -6.1966                      Air         3.594
18-1         Silica-CaF2 LENS
   0          0.00000     1.00E+07      Air
   1          1.81630       0.2688      CaF2           1.500
   2         -9.70194       0.1363      Air            1.500
   3         -1.71562       0.1619      Silica         1.400
   4          1.72652       0.3324      Air            1.400
   5          4.26856       0.3909      CaF2           1.500
   6         -1.73853       0.0223      Air            1.500
   7          4.39230       0.4152      CaF2           1.500
   8         -1.78979       0.3056      Air            1.500
   9         -1.70410       0.2496      Silica         1.200
  10          5.60739       3.7241      Air            1.200
18-2         CASSEGRAIN OBJECTIVE ALL Silica
   0          0.00000       39.370      Air
   1         -0.98911       0.2134      Silica         1.230
   2         -1.14451       0.7869      Air            1.390
   3         -2.75430       0.1617      Silica         1.460
   4         -2.74164      -0.1617      Mirror/Silica  1.570
   5         -2.75430      -0.7869      Air            1.460
   6         -1.59975       0.7566      Mirror         0.580
   7        -13.92287       0.1242      Silica         0.470
   8         -0.69773       0.0110      Air            0.470
   9         -0.64031       0.0480      Silica         0.410
  10          3.05088       0.5769      Air            0.470
18-3     LITHOGRAPHY PROJECTION LENS
      0       0.0000       4.2403                     3.685
      1     -22.1726       1.1965       SILICA        4.724
      2      -8.0708       0.0340                     4.948
      3       7.8597       2.8011       SILICA        4.979
      4     -16.7458       0.0197                     4.536
      5      17.0155       0.2780       SILICA        4.393
      6       6.9624       0.5206                     4.215
      7     -15.0217       0.2737       SILICA        4.203
      8       9.9267       1.2230                     4.154
      9    -118.0014       0.4544       SILICA        4.254
     10       8.9161       1.3041                     4.314
     11      -3.2403       0.4537       SILICA        4.386
     12      22.5155       0.3582                     5.602
     13     218.4297       1.4444       SILICA        5.952
     14      -6.1734       0.0357                     6.441
     15      24.1039       1.6301       SILICA        7.441
     16      -8.7303       0.0296                     7.623
     17      20.9338       1.2186       SILICA        7.765
     18     -22.3623       0.0219                     7.737
     19      16.6893       0.8660       SILICA        7.529
     20     -55.2167       0.0229                     7.426
     21       8.0228       0.8944       SILICA        6.883
     22      32.8470       2.6744                     6.680
     23     -29.0004       0.3302       SILICA        4.250
     24       4.1066       0.9537                     3.766
     25      -7.1881       0.4344       SILICA        3.679
     26      11.4624       2.2895                     3.649
     27      -2.9371       0.4466       SILICA        3.806
     28         Stop       0.4483                     4.512
     29     -11.1591       0.8745       SILICA        4.779
     30      -5.6000       0.0546                     5.314
     31    -228.0996       1.5604       SILICA        6.157
     32      -5.7742       0.0357                     6.567
     33      25.7835       1.4195       SILICA        7.149
     34     -13.6893       0.0210                     7.279
     35      10.0326       1.2422       SILICA        7.291
     36      84.2350       0.0328                     7.132
     37       6.4925       1.0965       SILICA        6.819
     38      13.7781       0.0317                     6.497
     39       4.2927       2.8749       SILICA        5.923
     40       2.9789       2.1318                     3.541
     41       1.8260       0.6676       SILICA        1.973
     42       3.9400       0.5148                     1.525
     43       0.0000       0.0000                     0.921
19-1         DOCUMENT SCANNER
   0          0.00000    1.000E+08      Air
   1         -5.04096       0.3554      LAKN22         2.900
   2         -3.42954       0.0315      Air            3.080
   3         -3.04156       0.4005      ZKN7           3.040
   4          6.22287       0.0317      Air            3.840
   5          6.55330       0.7052      LAKN22         3.840
   6         -5.58009       1.1996      Air            3.840
   7        363.61124       0.6667      SF1            5.610
   8          8.48491       0.6158      Air            4.540
   9         11.21622       0.5155      LAKN22         5.610
  10        -28.91675      25.2000      Air            5.610
19-2        ARGON LASER SCAN LENS
   1         -1.18815       0.1221      F4             1.170
   2         -1.24034       0.0232      Air            1.300
   3         -3.95935       0.1409      SF18           1.300
   4         -2.96846       0.5432      Air            1.440
   5         -1.33106       0.1617      F5             1.520
   6         -1.43429      21.1878      Air            1.700
19-3     Scanning Lens for .6328 micron laser
      1         Stop       1.0000                     0.667
      2      -1.3472       0.6742         SF57        1.000
      3      -2.2750       0.2541                     1.420
      4      31.2679       0.3753         SF57        1.680
      5      -3.6913       0.1199                     1.680
      6       3.6146       0.7496         SF57        1.680
      7     -47.9697       0.8578                     1.680
      8      -2.9183       0.5843         SF57        1.240
      9      -3.7040       0.2148                     1.300
     10       1.4362       0.5219         SF57        1.300
     11       0.8715       0.2686                     0.880
     12       0.8596       0.1681         SF57        0.920
     13       1.0989       0.2773                     0.780
     14       0.0000       0.0000                     0.697
20-1        ENDOSCOPE
   0          0.00000    1.000E+07      Water
   1          0.00000       0.0310      BK7            0.160
   2          0.06157       0.0999      Air            0.090
   3           Stop         0.0076      Air            0.041
   4          0.28205       0.1139      LAKN12         0.130
   5         -0.18104       0.0574      Air            0.130
   6          0.16108       0.1050      SK16           0.160
   7         -0.06792       0.0321      SF4            0.134
   8         -0.32075       0.1635      Air            0.160
   9          0.58699       0.8304      LAFN21         0.300
  10         -0.32643       0.1884      SF4            0.300
  11         -0.69376       0.2429      Air            0.300
  12          0.64588       0.0969      SF4            0.300
  13          0.21519       0.7971      LAFN21         0.300
  14         -1.69480       0.4423      Air            0.300
  15          0.58699       0.8304      LAFN21         0.300
  16         -0.32643       0.1884      SF4            0.300
  17         -0.69376       0.2429      Air            0.300
  18          0.64588       0.0969      SF4            0.300
  19          0.21519       0.7971      LAFN21         0.300
  20         -1.69480       0.4423      Air            0.300
  21          0.58699       0.8304      LAFN21         0.300
  22         -0.32643       0.1884      SF4            0.300
  23         -0.69376       0.2429      Air            0.300
  24          0.64588       0.0969      SF4            0.300
  25          0.21519       0.7971      LAFN21         0.300
  26         -0.19603       0.1914      Air            0.300
21-1         65 MM f/4 10 X ENLARGING LENS
   0          0.00000      26.5300      Air
   1          0.99475       0.1893      LAF2           1.220
   2          2.56734       0.0116      Air            1.220
   3          0.78085       0.1966      PK2            1.020
   4          3.66775       0.0553      F4             1.020
   5          0.49146       0.3420      Air            0.660
   6           Iris         0.4509      Air            0.420
   7         -0.67335       0.0963      SF1            0.720
   8         -2.86335       0.2556      LAKN7          1.090
   9         -0.81751       0.0058      Air            1.090
  10        -32.38740       0.1707      LAF2           1.260
  11         -1.70995       1.9624      Air            1.260
22-1        3.0 INCH f/1.8 PROJECTION LENS
   1          2.29280       0.4300      SK16           2.600
   2          7.62805       0.0155      Air            2.500
   3          1.19781       0.5376      SK2            2.060
   4          2.86446       0.1346      F4             1.760
   5          0.71271       0.6649      Air            1.240
   6           Stop         0.2231      Air            0.950
   7         -1.02332       0.1262      F4             1.010
   8          1.38177       0.6049      SK2            1.540
   9         -1.28556       0.0127      Air            1.540
  10          2.70103       0.3803      SK16           1.700
  11         -3.63592       1.8022      Air            1.700
22-3     Projection Lens for 70 mm Film
      0       0.0000     1.00E+10
      1       5.4309       0.7220          FK5        4.460
      2       2.3942       1.2934                     3.620
      3      -3.8629       0.7140          SF5        3.620
      4      -5.5409       0.0115                     4.460
      5     -16.0642       1.6219         LAK9        3.940
      6      -6.5538       0.0134                     4.460
      7       4.3769       1.6521        LAK10        4.460
      8      -4.1619       0.4850           F2        4.460
      9       9.8038       1.5399                     3.000
     10         Stop       0.5755                     1.732
     11      -3.8829       0.1769          SF4        1.920
     12       5.4280       0.0844                     2.080
     13      35.4552       0.3503        LAK10        2.280
     14      -3.2140       0.0100                     2.280
     15       3.2160       0.6218         LAK9        2.520
     16     -36.2242       0.0004                     2.520
     17       2.0680       0.5136         LAK9        2.520
     18       1.6122       2.3729                     2.100
     19       0.0000       0.0000                     2.246
22-4         38.1mm FOCAL LENGTH LENS f/2.
   0          0.00000     1.00E+10      Air
   1         10.59621       0.5398      SK14           5.480
   2          0.00000       0.6701      Air            5.480
   3          5.67687       0.2988      SF2            3.320
   4          1.28858       1.3654      Air            2.280
   5        -22.98210       0.4491      FK5            2.000
   6          1.28091       0.2279      Air            1.700
   7          3.32654       0.4939      SF6            1.780
   8         -9.84090       0.5778      Air            1.780
   9            Stop        0.1031      Air            1.552
  10          3.04039       0.6438      LAF2           1.900
  11         -2.22659       0.0240      Air            1.900
  12         26.35518       0.5294      FK5            1.860
  13         -1.31642       0.1060      SF6            1.860
  14          2.32165       0.1862      Air            1.860
  15         33.26503       0.3124      LAK9           1.900
  16         -2.75162       0.0238      Air            1.900
  17          5.26397       0.2939      LAK9           2.100
  18         -8.10888       2.2448      Air            2.100
22-5        PLASTIC PROJECTION LENS 10 INCH f/2
   1          6.61320       0.8152      Acrylic        5.720
   2        -98.64314       0.0183      Air            5.720
   3          2.87612       1.2556      Acrylic        4.880
   4          8.09377       0.2322      Air            4.420
   5         27.63460       0.3986      Polystyrene    4.420
   6          2.39872       0.5505      Air            3.780
   7          4.90627       0.3937      Polystyrene    3.940
   8          3.74047       1.5837      Air            3.840
   9          5.12128       1.2149      Acrylic        5.590
  10        -15.37367       4.6860      Air            5.590
22-7     50 mm LCD Projection
     SURF     RADIUS      THICKNNESS     MATERIAL     DIAMETE
      0       0.0000     1.00E+10
      1       3.9304       0.2500         PSK3        3.040
      2       1.4231       0.6829          SF4        2.400
      3       1.7647       2.1545                     2.040
      4         Stop       0.8588                     0.424
      5      -0.8867       0.1874          SF8        1.080
      6     -12.8800       0.0661                     1.720
      7      -3.3142       0.3809       PSK53A        1.470
      8      -1.1853       0.0175                     1.720
      9      14.7759       0.4193       PSK53A        2.260
     10      -2.1747       0.3699                     2.260
     11       5.7671       0.9422         PSK3        2.480
     12      -5.4309       0.5000                     2.480
     13       0.0000       2.5000          BK7        2.500
     14       0.0000       0.1127         ZKN7        2.500
     15       0.0000       0.4916                     2.500
     16       0.0000       0.0000                     1.751
23-1        20 X PROFILE PROJECTOR
   0          0.00000       50.000
   1          3.88595       0.2304      K10            1.640
   2          1.53641       2.0943      Air            1.440
   3          2.82407       0.4079      LAKN12         1.400
   4         -4.02049       0.1097      Air            1.400
   5            Stop        1.0022      Air            1.168
   6         -1.50892       0.1290      F5             1.120
   7          1.63110       0.7910      Air            1.220
   8          5.72732       0.7130      SK5            2.240
   9         -1.88036       0.0182      Air            2.240
  10          3.91529       0.2144      SF1            2.240
  11          1.33230       0.8045      BALF4          2.040
  12         -7.18973       3.0203      Air            2.040
23-2        TELECENTRIC LENS f/2.8
   1        -47.63383       0.2638      FK5            1.530
   2          2.13147       0.1461      Air            1.450
   3           Stop         2.1542      Air            1.446
   4         26.39803       0.3942      LAK8           3.340
   5         -6.03104       1.7429      Air            3.340
   6          5.61254       0.6345      LAK8           3.940
   7        -13.21876       0.2750      Air            3.940
   8         13.78651       0.3389      SF1            3.660
   9          3.06698       0.3894      Air            3.330
  10         11.76266       0.2807      SF1            3.400
  11          3.04728       0.8596      LAKN12         3.400
  12         -5.79673       5.2507      Air            3.400
23-3        TELECENTRIC LENS F/2.  40. DEG FOV
   1         19.61108       0.2495      LAFN21         4.020
   2          2.61682       1.3560      BK7            3.620
   3         -5.66570       0.9991      Air            3.620
   4          1.45549       0.8142      SF4            2.080
   5        -25.73312       0.2006      BAFN10         2.080
   6          0.53295       0.9160      Air            0.900
   7           Stop         0.0418      Air            0.490
   8         -1.55613       0.3968      SF4            0.520
   9          1.26921       0.3767      SK16           1.080
  10         -1.08945       0.4385      Air            1.080
  11          3.94797       0.6082      LAKN12         1.620
  12         -2.17713       0.0108      Air            1.620
  13          1.41656       0.6481      SK16           1.580
  14         -6.95994       0.2668      SF4            1.580
  15          4.20851       0.7388      Air            1.160
24-1         f/1.  VIDEO DISC LENS
   0          0.00000    1.000E+06      Air
   1          0.46045       0.0747      SF6            0.250
   2         -1.19418       0.0238      Air            0.250
   3         -0.27590       0.0225      BK7            0.190
   4         -0.57779       0.0693      Air            0.250
   5          0.14885       0.1094      SF6            0.190
   6          0.59850       0.0838      Air            0.190
24-3        LASER FOCUSING LENS  .308 MICRON
   1          3.17381       0.2592      Silica         1.100
   2         -6.10489       0.1395      Air            1.100
   3         -2.43609       0.2496      Silica         0.960
   4         -2.88562       4.6691      Air            1.100
24-4     Laser focus lens, HeNe
      0       0.0000   1.0000E+10      Air
      1       .30153       0.2300      Polystyrene    0.500
      2      -3.4042       0.3469      Air            0.500
25-1     HEADS UP DISPLAY LENS
      0       0.0000   1.0000E+10
      1         Stop      25.0000                     6.000
      2       7.4702       1.9817         SK16        7.900
      3     -10.7389       0.7000          SF6        7.900
      4       0.0000       6.1000                     7.900
      5       8.6772       0.5212          SF6        5.840
      6      34.0874       0.0200                     5.840
      7       4.1812       0.8597          SF6        5.400
      8      13.8540       0.3291                     5.200
      9     -50.2546       0.3500          SF6        5.400
     10       3.8134       2.2935                     4.440
     11       0.0000       0.1890           K5        4.280
     12       0.0000       0.0000                     4.280
     13       0.0000       0.0000                     4.267
25-2     BIOCULAR LENS
      0       0.0000   1.0000E+10
      1        Pupil       2.0000                     2.757
      2       2.9339       1.1001         PSK3        3.140
      3       7.7247       0.0200                     2.800
      4       2.6343       0.2680          SF2        2.780
      5       1.1996       1.3501          FK5        2.280
      6     -10.7987       0.2943                     2.280
      7      -1.8077       0.5547          LF5        2.080
      8      -1.7849       1.9276                     2.280
27-4     35 mm f/2.0 lens for rotary prism camera
      0       0.0000   1.0000E+10                      0.00
      1       0.6772       0.3057          SF1        1.000
      2       0.4532       0.1514                     0.700
      3       0.8751       0.2287         LAF3        0.740
      4      -2.8782       0.0704           F2        0.740
      5       0.7460       0.0845                     0.560
      6         Stop       0.3159                     0.532
      7      -0.8706       0.1083           F2        0.720
      8       2.7059       0.2949     N-LASF30        1.000
      9      -0.8075       0.2816                     1.000
     10       1.2784       0.3380       LAKN12        1.040
     11      -0.9851       0.1408          SF1        1.040
     12      21.6185       0.3300                     0.880
     13       0.0000       0.4480       LAK16A        0.448
     14       0.0000       0.3300                     0.448
     15       0.0000       0.0000                     0.496
28-1 2X anamorphic front attachment for 35 mm projection
      1      46.7733       0.3497          SF5        3.940
      2     -10.3251       0.2416         BK10        3.940
      3       3.5659       8.8451                     3.460
      4     -19.2836       0.2006        BASF2        2.040
      5      21.4963       0.2658           K5        2.080
      6      -5.5945       1.9830                     2.080
      7      exit pupil    3.0025                     2.001
      8       0.0000       0.0000                     0.943
28-2     2X anamorphic front attachment for 70 mm projectio
      0       0.0000  1.0000E+10
      1     245.3505       0.5063         SK14        7.280
      2     -19.3729       0.9290                     7.280
      3       0.0000       0.5930         SK14        5.460
      4       2.8590       2.8612                     4.280
      5     -12.2116       0.4711          SF1        4.200
      6      -5.6140       2.9392                     4.300
      7      -6.5068       0.7266          K10        3.020
      8      -2.6171       0.3618                     3.080
      9      -1.9681       0.2990         LAF3        2.560
     10     -20.8007       0.5907          FK5        2.840
     11      -2.1197       1.9320                     2.840
     12    exit pupil      3.9936                     1.588
     13       0.0000       0.0000                     1.923
28-3     1.5 X Anamorphic Expander
      0       0.0000      -4.8210                     0.985
      1   entrance pupil   1.4959                     1.200
      2       1.3427       0.1692          FK5        1.200
      3       2.6937       0.1180          SF1        1.200
      4       3.9371       0.0100                     1.200
      5       3.4446       0.1111         LAF2        1.200
      6       1.3284       1.0172                     1.100
      7       8.0086       0.1385          FK5        1.140
      8      -6.5103       0.0924          SF1        1.140
      9      -5.3699       0.3703                     1.140
     10      -2.1393       0.0999          FK5        1.040
     11       2.2439       0.2314                     1.040
     12      -0.9081       0.1671       PSK53A        1.040
     13      -4.2869       0.1955          LF5        1.140
     14      -1.1707       1.0106                     1.140
     15       0.0000       0.0000                     1.124
29-1         QUARTZ CONDENSER   1 X
   0          0.00000       4.4990                     0.500
   1          0.00000       0.4815     Silica          2.600
   2         -2.22208       0.0370     Air             2.600
   3          2.22208       0.4815     Silica          2.600
   4          0.00000       0.2470     Air             2.600
   5         Aperture       3.8621     Air             2.000
29-2       QUARTZ CONDENSER .2X
   0          0.00000      11.0330                     1.000
   1         Aperture       0.2000                     2.000
   2          3.63494       0.4212     Silica          2.180
   3         -3.63494       0.0349     Air             2.180
   4          1.31930       0.4541     Silica          1.920
   5          6.26928       1.7556     Air             1.680
29-3         PYREX  CONDENSER
   0          0.00000       3.6877                     0.500
   1          0.00000       0.3500      Pyrex          2.360
   2         -3.00000       0.0500      Air            2.360
   3          5.00000       0.4000      Pyrex          2.450
   4         -5.00000       0.0500      Air            2.450
   5          3.00000       0.3500      Pyrex          2.360
   6          0.00000       0.2500      Air            2.360
   7          Aperture      3.0387      Air            2.000
29-4        CONDENSER SYSTEM 10X PROJECTION
   0          0.00000  1.10164E+01                     1.192
   1          0.00000       1.1760      BK7            8.400
   2         -8.90300       0.1100      Air            8.400
   3          0.00000       1.0490      BK7            8.780
   4        -12.55440      11.9390      Air            8.780
   5         23.46300       0.8390      Pyrex          7.700
   6        -23.46300       0.1100      Air            7.700
   7          5.40520       1.0300      Pyrex          7.010
   8         15.92130       2.7680      Air            6.820
   9          1.86540       0.9580      Pyrex          3.550
  10          3.32290       1.7000      Air            3.160
30-1     Wide Angle Aerial Camera Lens
      0       0.0000    1.000E+10
      1      92.3336       0.4604          FK5        8.800
      2       3.4528       0.8787                     6.160
      3       5.1264       1.0619         LAF3        6.240
      4      12.6041       0.6390           K5        6.240
      5      11.8613       1.9753                     5.420
      6       4.6234       0.8039       LAKN13        3.520
      7      -4.4757       0.2475         LLF1        3.520
      8       4.3683       1.1785       LAKN13        2.480
      9       7.5606       0.0881                     1.320
     10         Stop       0.3288                     1.183
     11     -64.8414       0.6324         FK51        2.040
     12      -1.3538       0.9310          SF4        2.040
     13      -2.5319       0.0125                     3.120
     14       5.9816       0.4039          SF4        4.220
     15      10.7565       0.6655         LAK8        4.220
     16       6.1021       2.0959                     4.160
     17      -2.6917       0.4604          SK5        4.600
     18     -11.2615       0.7000                     6.740
     19       0.0000       0.0000                     9.984
  30-2        12 INCH f/4 AERIAL CAMERA LENS
   0          0.00000    1.000E+10
   1          6.44702       0.3864      SK16           4.350
   2         17.24534       0.2034                     4.200
   3          4.96331       0.6852      SK16           3.880
   4         17.73774       0.0702                     3.500
   5         48.46703       0.4095      F6             3.530
   6          7.28391       0.0245                     3.060
   7          5.76310       0.4028      F6             3.060
   8          3.42257       0.5841                     2.620
   9          Stop          3.6069                     2.320
  10         18.03505       0.4267      SK16           4.800
  11        -67.91694       1.3394                     4.800
  12         16.08596       1.1250      SK16           5.450
  13         -7.21560       0.2140                     5.450
  14         -8.33950       0.3612      SF1            5.280
  15        -16.68175       2.4948                     5.390
  16         -6.72850       0.3607      F6             5.140
  17         21.90122       1.9607                     5.400
30-3        18 INCH f/3 AERIAL LENS
   0          0.00000     1.00E+10
   1         10.61548       1.9083       SK4           8.400
   2         38.28208       1.1510                     7.800
   3          5.83702       2.1280       SK4           6.740
   4        -42.26294       0.0139                     6.740
   5        -47.69489       0.5397       F5            5.830
   6          3.75269       3.0564                     4.580
   7          Stop          0.5204                     3.320
   8         -4.27948       0.8918       LF5           3.380
   9         32.19332       0.1553                     3.940
  10         31.29194       1.7507       SK4           4.530
  11         -5.96022       0.9353                     4.530
  12         32.44910       0.4504       SK4           4.720
  13        -16.52077      10.6248                     4.720
30-4        24 INCH FL f/6 AERIAL LENS
   0          0.00000     1.000E+10
   1          5.38182       1.3902      LAKN22         6.310
   2         33.89543       0.3784                     5.860
   3         37.83808       0.6007      LF5            5.460
   4          3.98992       0.2944                     4.480
   5          6.30323       0.9070      SK4            4.520
   6          9.49052       1.7266                     4.060
   7           Stop         0.2957                     2.880
   8        -10.79902       0.7134      SK4            3.040
   9         -6.66237       0.5534                     3.330
  10         -4.52682       0.8391      LF7            3.440
  11        -29.80600       0.9761                     4.020
  12        -65.30257       0.9242      LAKN22         4.720
  13         -6.96796      17.8836                     5.000
31-1        RADIATION RESISTANT LENS 25 MM f/2.8
   0          0.00000    1.000E+07
   1          0.32506       0.1179      LAK9G15        0.450
   2          0.74930       0.0438                     0.370
   3         -1.40604       0.0355      F2G12          0.350
   4          0.30229       0.0510                     0.310
   5           Stop         0.0100                     0.290
   6          0.62453       0.1034      LAK9G15        0.390
   7         -0.77895       0.7817                     0.390
32-1        24 X MICRO-PROJECTION
   0          0.00000      38.0116
   1          0.89262       0.2126      SSK4A          0.940
   2        -49.08679       0.0209                     0.940
   3          0.62971       0.2137      SSKN5          0.740
   4         -1.87244       0.1055      SF1            0.740
   5          0.39596       0.0532                     0.380
   6            Stop        0.0438                     0.340
   7         -0.61216       0.2171      LAKN7          0.400
   8         -0.51034       0.0800                     0.620
   9         -0.40081       0.1280      K10            0.500
  10         -1.04802       0.0218                     0.620
  11          4.52618       0.1718      LAKN7          0.680
  12         -0.98872       0.7183                     0.680
35-1     10 X ZOOM LENS
      0       0.0000    1.000E+10
      1      10.1098       1.1937         LAK9        5.720
      2      -6.3839       0.2360          SF5        5.720
      3      15.4899       0.0100                     5.260
      4       6.6703       0.4254       LAFN21        5.200
      5      16.0779       0.1335                     5.100
      6      17.6988       0.1400         LAK9        2.400
      7       1.6653       0.4664                     1.960
      8      -3.7115       0.1400         LAK9        1.960
      9       1.2520       0.5434          SF5        2.000
     10     -50.0672       5.6883                     2.000
     11       3.3233       0.3154         LAK9        1.800
     12      -5.3099       0.0195                     1.800
     13       1.6006       0.1169          SF1        1.680
     14       0.7352       0.4803         LAK9        1.340
     15       6.8782       0.0432                     1.340
     16         Stop       0.2947                     0.639
     17      -1.2146       0.1191         LAK8        0.620
     18      -3.9731       0.0984          SF1        0.700
     19       1.9568       0.0955                     0.660
     20      -2.4821       0.2734          SF8        0.680
     21      -0.8604       0.0243                     0.880
     22       1.9237       0.2929         BAK4        0.880
     23      -0.7665       0.1550          SF1        0.880
     24      -3.5517       0.9170                     0.880
     25       0.0000       0.0000                     0.598
35-2     AFOCAL ZOOM FOR MICROSCOPE
      0       0.0000   1.0000E+10
      1         Stop      -2.3622                     0.400
      2       1.2388       0.1504          K10        0.760
      3       9.3542       0.0234                     0.760
      4       1.3062       0.0787          SF1        0.700
      5       0.6690       0.1145         PSK3        0.700
      6       2.4729       0.6310                     0.600
      7       2.6233       0.0709         SK16        0.460
      8       0.2835       0.1794        SSKN5        0.460
      9       0.9740       0.3496                     0.360
     10      -0.6347       0.0606         SK16        0.320
     11       3.7396       0.3475                     0.320
     12      -1.7308       0.0492         SK16        0.400
     13       0.6212       0.1614          SF1        0.500
     14       2.3140       0.1352                     0.440
     15      38.9045       0.0789          SF1        0.880
     16       1.5054       0.1923         PSK3        0.880
     17      -2.5537       0.0362                     0.880
     18       5.2888       0.2755          BK7        0.880
     19      -1.7936       0.0000                     0.880
35-3         ZOOM CASSEGRAIN
      1      41.7742       0.3797      IRTRAN2        4.330
      2       0.0000       3.9956                     4.330
      3      -9.9443       0.5500      IRTRAN2        3.760
      4     -12.1154       0.0000     MIRROR/IRTRAN2  3.860
      5      -9.9443      -3.8239                     3.700
      6         Stop       3.2207                     1.100
      7     -36.2852       0.1000    GERMANIUM        0.450
      8      -2.3898       0.0553                     0.450
      9      -2.7359       0.1000      SILICON        0.450
     10       2.5240       3.5389                     0.450
     11       1.7824       0.1245      SILICON        1.260
     12      16.4118       0.2891                     1.260
     13      -2.6837       0.0756    GERMANIUM        0.940
     14       0.0000       0.5701                     1.260
     15       1.0989       0.1181    GERMANIUM        0.780
     16       0.8329       0.0207                     0.650
     17       0.8891       0.1502      SILICON        0.780
     18       1.7684       0.3616                     0.780
     19       0.0000       0.0788      SILICON        0.390
     20       1.1734       0.4048                     0.390
     21       3.2380       0.1000      SILICON        0.390
     22      -1.3825       0.0264                     0.390
     23      -0.9210       0.1000    GERMANIUM        0.390
     24      -1.1487       0.6101                     0.390
     25       0.0000       0.0000                     0.180
35-4     ZOOM RIFLE SCOPE
      0       0.0000   1.0000E+10
      1       4.0394       0.3138         BAK2        1.654
      2      -3.5518       0.0521                     1.654
      3      -3.3885       0.2002          SF1        1.575
      4     -10.3062       5.7204                     1.654
      5       0.8467       0.1969           K5        0.945
      6       3.2325       0.4504                     0.945
      7       0.0000       0.1181           K5        0.709
      8       0.0000       0.9254                     0.709
      9       1.2332       0.0787          SF4        0.551
     10       0.3915       0.3145         SSK2        0.551
     11      -0.8397       0.8349                     0.551
     12       1.1365       0.0787          SF4        0.551
     13       0.3899       0.3754         SSK2        0.551
     14      -0.8309       2.0650                     0.551
     15      -5.5677       0.1378          SF4        1.102
     16       2.2165       0.4087          BK7        1.339
     17      -1.3068       0.0197                     1.339
     18       2.5341       0.2601         SK15        1.339
     19      -5.4323       3.5433                     1.339
35-5     STEREO MICROSCOPE
      0       0.0000   1.0000E+10
      1       1.8446       0.1017          SF1        0.331
      2       0.8936       0.1220         SK14        0.331
      3      -1.5598       0.0197                     0.331
      4       1.5598       0.1220         SK14        0.331
      5      -0.8936       0.1017          SF1        0.331
      6      -1.8446       5.5073                     0.331
      7       0.0000       0.9843          BK7        0.394
      8       0.0000       0.6890                     0.394
      9         Stop       1.0210                     0.394
     10       1.0373       0.1451          SF1        0.575
     11       0.6255       0.2101          FK5        0.575
     12      -3.4421       1.5684                     0.575
     13      -0.8369       0.0748           K7        0.472
     14       0.3053       0.1649          SF4        0.472
     15       0.4539       0.4174                     0.472
     16       4.7394       0.1682          FK5        0.906
     17       5.9833       0.0197                     0.906
     18       1.3819       0.0906          SF4        0.906
     19       0.7705       0.2719           K7        0.906
     20      -1.6815       7.1763                     0.906
35-6     ZOOM MICROSCOPE
      0       0.0000   1.0000E+10
      1       5.1837       0.0834          SK5        0.504
      2      -1.0536       0.0198                     0.504
      3       1.0605       0.1310          PK2        0.504
      4      -0.9616       0.0591          SF1        0.504
      5       4.4730       1.0221                     0.504
      6       0.0000       3.4759                     0.420
      7      -1.9918       0.0866          SF1        0.992
      8      -1.8161       0.0866         BAK1        1.102
      9      -2.1348       0.0197                     1.102
     10       1.5302       0.1049          SF1        1.142
     11       0.8165       0.2953         BAK1        1.142
     12      -7.3527       3.6710                     1.142
     13      -1.0239       0.1530          SF1        0.176
     14      -0.5613       0.0598         BAK1        0.201
     15      -4.4802       0.0672                     0.315
     16      -3.5666       0.0600         BAK1        0.315
     17       5.2239       0.3385                     0.315
     18      21.6742       0.0787           F5        0.701
     19       1.1738       0.1969          FK5        0.701
     20      -1.1066       0.0315                     0.701
     21       1.1066       0.1969          FK5        0.701
     22      -1.1738       0.0787           F5        0.701
     23     -21.6742       2.0732                     0.701
35-7     20 TO 110 MM ZOOM LENS, 16 MM IMAGE
      1       7.8280       0.1969          SF6        3.992
      2       2.8307       0.9140         LAK9        3.740
      3     -10.7459       0.0197                     3.740
      4       2.9002       0.3832         LAK9        3.307
      5       6.9126       1.8613                     3.228
      6       0.0000       0.1181       LAFN28        1.339
      7       1.1254       0.2587                     1.102
      8      -1.3799       0.0984         LAK9        1.102
      9       1.1861       0.1903         SF57        1.181
     10       0.0000       0.0175                     1.181
     11         Iris       0.5199                     0.930
     12       5.1084       0.6153          BK7        1.843
     13      -1.3631       0.1181          SF8        1.843
     14      -2.1947       0.6104                     1.843
     15       4.2413       0.2257         LAF2        1.953
     16     -11.3549       0.1752                     1.953
     17      -2.5532       0.1575         SF57        1.850
     18     -16.1840       0.0197                     1.953
     19       1.8858       0.3128         LAK9        2.063
     20       8.2502       1.0418                     2.063
     21       3.1532       0.1575          SF6        1.496
     22       1.0632       0.2655                     1.417
     23      18.9826       0.2100          BK7        1.496
     24      -1.8327       0.0197                     1.496
     25       1.0689       0.3605        LAK10        1.496
     26       7.1817       0.7870                     1.496
35-8     25 TO 125 MM ( 3 GROUPS)
      1      13.0839       0.4481        LAK21        5.100
      2       7.5719       0.0861                     4.560
      3       8.8048       0.3177        LAK21        4.620
      4       4.7224       0.8616                     4.160
      5     -46.3801       0.7096          SF6        4.040
      6      -5.8725       0.5362          LF5        4.040
      7      11.3528       0.6574                     3.400
      8      -5.0519       0.2708        LAK10        3.440
      9     -10.7181       0.5442                     3.700
     10       0.0000       0.2676          SF6        3.940
     11       9.3521       0.6051         SK16        3.940
     12      -6.8485       0.0197                     3.940
     13       9.3534       0.2676          SF6        4.040
     14       4.9965       0.5994        LAK21        4.040
     15     -16.9145       0.0197                     4.040
     16       3.7464       0.5004        LAK21        3.900
     17      17.1248       0.1071                     3.800
     18       6.2694       0.1417       LAFN21        2.060
     19       1.5955       1.0782                     1.740
     20      -2.4228       0.1169         LAF3        1.620
     21       2.0118       0.7414          SF6        1.900
     22     -16.3788       3.2611                     1.900
     23      30.9694       0.1260          SF6        1.960
     24       2.3413       0.4365        SSKN5        1.960
     25      -2.8669       0.0197                     1.960
     26       2.8661       0.3012          FK5        1.920
     27      -5.8595       0.0269                     1.920
     28         Iris       0.1017                     0.966
     29      -2.1793       0.0792       LAFN23        0.980
     30       1.4875       0.1887          SF6        1.100
     31      25.3790       0.5406                     1.100
     32      -7.5399       0.3504          PK2        1.140
     33      -2.2715       0.4459                     1.260
     34      10.9873       0.0906          SF6        1.280
     35       1.3382       0.2751         PSK2        1.280
     36      -3.3161       3.0844                     1.280
35-9     TV Zoom, 12 to 234 mm
      0       0.0000   1.0000E+10
      1       6.7937       0.3000        SF56A        4.900
      2       3.9082       0.8330       PSK53A        4.620
      3     -87.2079       0.0100                     4.620
      4       3.8585       0.7975         FK51        4.400
      5       8.9733       0.0047                     4.100
      6       4.3545       0.0900           F2        2.120
      7       1.3078       0.2174                     1.760
      8       3.0849       0.4000         SF57        1.820
      9      -2.4100       0.0900         LAF2        1.820
     10       2.7985       0.2156                     1.420
     11      -2.3266       0.0900         LAK8        1.420
     12      10.1497       3.0904                     1.380
     13      -1.0960       0.0630        SSKN8        0.760
     14       0.8686       0.1034          SF6        0.860
     15       2.1800       0.7088                     0.860
     16         Iris       0.1181                     1.021
     17       6.5649       0.1689      LASFN30        1.240
     18      -1.9870       0.0100                     1.240
     19       8.3231       0.1059         LAK9        1.240
     20      -6.4489       0.0090                     1.240
     21       2.1218       0.2534          FK5        1.240
     22      -1.4584       0.0700          SF6        1.240
     23       9.4126       0.3978                     1.140
     24       1.2410       0.4000         FK51        1.240
     25      12.7718       0.2673                     1.040
     26       0.9389       0.0945        LAFN7        0.940
     27       0.6195       0.3105                     0.800
     28       1.1200       0.3000         PSK3        0.840
     29      -4.1366       0.5000                     0.840
     30       0.0000       0.1378          BK7        0.388
     31       0.0000       0.0000                     0.336
36-1     OZOOM 100 - 200 MM EFL FULL FRAME 35
      0       0.0000   1.0000E+10
      1       7.8491       0.3238          LF5        3.140
      2       4.7883       0.3238         LAK8        3.140
      3       5.8979       1.4358                     2.900
      4       4.9300       0.2568          SF4        2.800
      5       2.2971       0.4961       BAFN10        2.600
      6     -24.6447       1.4590                     2.600
      7     -11.1125       0.1634         SK14        1.820
      8       2.7388       0.2578                     1.740
      9      -4.1362       0.1633         SK14        1.740
     10       2.2929       0.2655          SF4        1.795
     11      29.7026       0.1111                     1.880
     12      47.4998       0.5507         SK14        1.940
     13      -3.2744       0.2670                     1.940
     14       3.6694       0.3179         SK14        1.940
     15      -2.8881       0.1619          SF4        1.940
     16       0.0000       1.3775                     1.940
     17         Iris       0.1680                     1.072
     18      -2.2685       0.1053         BAF4        1.080
     19       5.9067       0.0729                     1.140
     20       2.5231       0.1694        BASF2        1.260
     21      -8.6344       0.6323                     1.260
     22     125.1504       0.1053          SF2        1.340
     23       2.1238       0.1147                     1.240
     24       6.9089       0.2034         LAK8        1.340
     25      -2.9516       4.8619                     1.340
36-2     SLR OZOOM
      0       0.0000   1.0000E+10
      1       6.3722       0.2000          SF4        3.900
      2       2.4419       1.4087       BAFN10        3.580
      3     -11.3894       0.1950                     3.580
      4      -4.2529       0.1824         SK14        1.980
      5       5.1930       0.2837                     1.860
      6      -3.8762       0.1614         SK14        1.860
      7       1.8348       0.4068          SF4        1.920
      8       7.4125       1.7731                     1.920
      9     -56.1977       0.4140         SK14        1.840
     10      -3.4184       0.0193                     1.920
     11       3.5401       0.3230         SK14        1.840
     12      -3.3877       0.0900          SF4        1.840
     13     -27.6999       0.0223                     1.840
     14         Iris       0.0426                     0.903
     15      -2.6701       0.0750         BAK2        0.920
     16      13.1555       0.0188                     0.960
     17       2.5097       0.1780       BAFN10        1.080
     18      -4.4983       0.3888                     1.080
     19      -2.3194       0.0750          SF2        1.020
     20       2.0389       0.1558                     1.060
     21       4.0040       0.2505         LAK9        1.280
     22      -2.1983       3.5669                     1.280
36-3     PROJECTOR 6.25 TO 12.5X
      0       0.0000      30.0000                     8.000
      1       2.5446       0.7345         SK16        3.380
      2       7.0456       0.0200                     3.380
      3       2.0978       0.8020         SK16        2.880
      4      -7.5172       0.1900          LF5        2.880
      5       0.9438       4.2107                     1.660
      6         Stop       0.3882                     0.169
      7      -0.9443       0.0500          LF5        0.340
      8       0.8194       0.1300         SK16        0.460
      9      -1.7325       0.0220                     0.460
     10       1.8215       0.1800         SK16        0.520
     11      -3.4941       2.4236                     0.520
     12       2.1220       0.3000        SSKN5        1.080
     13     -18.9215       5.3285                     1.080
     14       2.3567       0.2040         SK16        1.040
     15     -16.9190       0.0539                     1.040
     16      -4.3567       0.2000           F2        0.940
     17     -12.8973       0.0224                     1.040
     18       2.1351       0.1408         SK16        0.980
     19     -28.6302       0.4280                     0.980
     20      -2.6205       0.1500          SF1        0.700
     21       1.7463       0.0932                     0.660
     22       2.0930       0.2918       LAKN22        0.680
     23      -1.8006       0.0200                     0.680
     24      -2.0298       0.2000       LAK16A        0.620
     25       0.8564       0.1324           F6        0.620
     26       1.7744       0.8098                     0.620
     27      33.2129       0.2001         SK16        0.620
     28      -1.9145       0.0208                     0.620
     29       9.8754       0.2000           F2        0.620
     30       4.2642       0.0253                     0.560
     31      12.8548       0.2014         SK16        0.620
     32      -2.4380       4.0315                     0.620
37-1     XEROGRAPHIC ZOOM
      0       0.0000      21.2311                    11.120
      1       8.4566       0.3261         SK16        4.780
      2      45.5618       0.0100                     4.780
      3       9.2944       0.3404         SK16        4.560
      4       0.0000       1.8552                     4.560
      5     -24.4940       0.2116         SK16        2.380
      6      -3.6662       0.2480          LF5        2.380
      7      61.4561       0.2986                     2.380
      8      -5.8879       0.1653          LF5        1.740
      9       5.3808       0.8823                     1.580
     10         Stop       0.0197                     1.051
     11      90.0804       0.2203         SK10        1.260
     12       0.0000       0.9623                     1.260
     13      37.9841       0.3436         SK16        2.340
     14      -5.2393      27.0195                     2.340
37-2     Copier Lens
      0       0.0000      19.4935                    13.900
      1       2.9849       0.4000       LAKN12        1.600
      2     -38.8801       0.2639                     1.600
      3     -27.5817       0.1200          LF5        1.120
      4       2.9046       0.4901                     1.020
      5         Stop       0.4901                     0.500
      6      -2.9046       0.1200          LF5        1.020
      7      27.5817       0.2639                     1.120
      8      38.8801       0.4000       LAKN12        1.600
      9      -2.9849      23.9584                     1.600
     10       0.0000       0.0000                    16.875
38-1     VARIABLE FOCAL LENGTH PROJECTION
      0       0.0000   1.0000E+10
      1     -50.0181       0.1575         LAF2        2.480
      2       2.0722       1.2396                     2.120
      3       2.8295       0.1181        LAFN7        2.000
      4       1.6333       0.4022         SF55        2.000
      5       3.6331       3.4241                     1.720
      6         Stop       0.0000                     0.512
      7       3.2202       0.1000        LAK10        0.600
      8      -4.6843       0.0110                     0.600
      9       0.9301       0.0917        BAF51        0.600
     10       3.0263       0.1816                     0.600
     11     -20.0034       0.1568          SF6        0.560
     12       0.9297       0.2698                     0.560
     13      -5.2817       0.0901        BALF4        0.760
     14      -1.4390       2.4578                     0.760
38-2     V. F. LENS, MOTION PICTURE PROJECTION
      0       0.0000   1.0000E+10
      1       4.6897       0.3347         LAK9        2.480
      2    -135.1888       0.3150          SF8        2.480
      3       6.7937       0.1478                     2.100
      4      -9.9116       0.1500         LAF2        2.100
      5      -7.8073       0.0421                     2.200
      6      -4.7155       0.1260           F5        1.720
      7    -172.3283       0.0759                     1.800
      8      -4.9638       0.2247       LAKN12        1.640
      9       1.6566       0.2524          SF8        1.640
     10      14.7483       3.2415                     1.640
     11         Stop       0.0000                     0.868
     12       2.3852       0.0820        BASF2        0.980
     13       1.5410       0.0200                     0.900
     14       1.9066       0.1290       LAKN12        1.000
     15      -6.4898       0.0100                     1.000
     16       0.9935       0.3114       LAKN13        1.000
     17      21.7701       0.0127                     1.000
     18     -37.7932       0.1547          SF8        0.880
     19       0.8207       0.5040                     0.800
     20       8.0699       0.0891       LAKN13        1.000
     21      -6.0327       1.8589                     1.000
39-3      10 X MICROSCOPE OBJECTIVE
      0       0.0000       6.0639                     0.630
      1         Stop       0.0120                     0.303
      2       0.5052       0.1309           K5        0.360
      3      -0.3671       0.0700           F2        0.360
      4      -3.2840       0.4006                     0.360
      5       0.4699       0.1023       BASF51        0.280
      6      -0.1845       0.0300       G51SFN        0.280
      7       0.0000       0.2700                     0.280
      8       0.0000       0.0070           K5        0.067
      9       0.0000       0.0000                     0.065
39-4     Laser focus lens, HeNe
      1       4.4701       0.1705       G23SFN        1.500
      2     123.6921       5.9069                     1.485
      3       0.0000       0.0000                     0.107
39-5     Radial Gradient Lens
      1         Stop       0.0000                     2.000
      2       0.0000       0.2000        Radial       2.000
      3       0.0000      49.9592                     2.000
      4       0.0000       0.0000                     0.874
39-6     SELFOC lens
      0       0.0000       0.0800                     0.020
      1         Stop       2.0546       SLS-1.0       0.041
      2       0.0000       0.0298                     0.041
      3       0.0000       0.0000                     0.024
发表于 2007-9-7 11:53:29 | 显示全部楼层
怎么看?谢谢告诉我,非常感谢
发表于 2007-9-7 16:25:12 | 显示全部楼层
看不到了吗?
发表于 2007-9-22 01:49:27 | 显示全部楼层
发表于 2007-9-22 01:59:29 | 显示全部楼层
发表于 2007-10-2 12:36:14 | 显示全部楼层
欣赏楼主的慷慨
顶上
发表于 2007-10-13 22:51:28 | 显示全部楼层
看不过来了
呵呵
发表于 2010-10-19 12:12:37 | 显示全部楼层
很好的资料
发表于 2010-10-19 14:00:22 | 显示全部楼层
发表于 2010-10-24 17:38:37 | 显示全部楼层
好资料,难得
