查看: 10189|回复: 0
光电子KODENSHI一级代理
发表于 2007-9-13 00:20:08 | 显示全部楼层 |阅读模式
我司为KODENSHI(光电子)最重要的战略合作伙伴之一,致力于为中国广大客户提供世界最出色的光电产品
KODENSHI产品主要有:红外线发射管,红外线接收头,红外线接收管(PIN),红外线光敏管(NPN),红外线硅光电池,环境亮度传感器、PSD位置传感器,编码光电传感器,光电IC,蓝敏接收二极管,光电耦合器,光电传感器,红引线数据输器,发光二极管。
部分产品型号:
光电接收二极管(PHOTODIODES):
SP-1CL3,SP1CL3R2,SP101,SP-1KL,SP-1ML,SP-2ML,SP-3ML,SP45ML,HP-1LR1,HP-202,HP-2ML,HP-2MLR,HP-2FR4-HP-304,HP-3ML,HP-308S,HP-3MLR2,HP-5FR2,HP-5FR4
光电接收二极管(PIN PHOTODIODES):
HPI-103,HPI-1K1,HPI-1K3,HPI-1KL5,HPI-201,HPI-23G,HPI-2C,HPI-2CR2,HPI-307,HPI-304R4L,HPI-5FCR2,HPI-6FER2,HPI-6FFR4,HPI-6FGR4,HPI-6FFR2,HPI-6FH
光电接收二极管(分割式)PIN PHOTODIODES DIVIDED):
HPI-146A64S,HPI-147A66,HPI-2464,HPI-2464RS,HPI-3663,HPI-14262
光敏接收三极管(PHOTOTRANSISTROS):
ST-1CL3H,ST-1CL5,ST-1KA,ST-1KB,ST-1KL3A,ST-1KL3B,ST-1KLA,ST-1KLB,ST-1MLA,ST-1MLAR2,ST-1MLB,ST-1MLBR2,ST-23G,ST-302,ST-305,ST-308,ST-308F,ST-309,ST-313R4,ST-324R4
光敏达琳顿接收管:PT23G,PT-1CL3,PT-1KLB,PT-304R2L
环境亮度传感器:
PSD位置传感器:SD101,SD102,SD103,SD112,SD112F2,SD201,SD202,SD303,SD306,SD402,SD503,SD506F,SD612
红外线发射管(940nm):EL-1CL3,EL-1CL3H,EL-1K3,EL-1KL3,EL-1KL5,EL-1KL6,EL-1ML2,EL-1L7,EL-23G,EL-302,EL-303,EL-305,EL-308,EL-313,EL-314,EL-315,EL-316,EL-321,EL-325,EL-55L,EL-6F11
红外线发射管:AL-1KL3,AL-1KL5,AL-402,CL-1CL3,CL-1KL7,CL-1KL8,CL-203,CL-304L,CL-402,ML-1K3,GL-23G,GL-402
光通信专用发射管:BL05-1211(650nm),BL5-1101(650nm),BL15-1212(650nm),BL15-2002(650nm),BL15-325(650nm),BL15-6F(650nm),BL-23G(660nm),FL-1ML2(830nm),FL-1ML3(830nm)
对射式光电传感器:SG-203,SG-204,SG-205,SG-206,SG-207,SG-209,SG-211V,SG-213,SG-214,SG-215,SG-220,SG-222V,SG-223,SG-226,SG-227V,SG-233,SG-238V,SG-23FF,SG-23FI,SG-23FT,SG-240,SG-243,SG-244,SG-246,SG-2481,SG2481R。SG-255,SG-256,SG-257,SG-258S,SG-260,SG-264,SG-266,SG-267,SG-268,SG-269,SG-288,SG-290,SG402,SG405,DG290,DV-211V
对射式光电传感器(光电IC放大输出):LG-205L,LG-205D,LG-206L,LG-206D,LG-207L,LG-207D,LG209L,LG-209D,LG-214L,LG214D,LG-23FFD,LG-217L,LG-217D,LG-248L1,LG-248D1,LG-413L,LG-413D,
反射式光电传感器:SG103,SG105,SG105F,SG107,SG107F3,SG107F4,SG112,SG113,SG114F2,SG2BC
分离式光电传感器:发射器:G310,PIE310,接收器:ST-310,HPI-310,DI310,PID-310L,PID310D
数位式倾斜传感器:SG302,SG303
光电开关(PICS):PSS-S13/PSS-S13A(透过型),PST-SH13/PST-SH13A(透过型)
扩散反射型:PST-RV31/PST-RV31A,限定反射型:PST-R11/PST-R11A,PSS-U50/PSS-50A(透过型)
反射式传感器(长距离):HS-101,HS101S
纸位传感器:PSD-117D/L,PS-R11D/L,PS-R50D/L
光电IC:PIC-0103,PIC-0903,PIC-1503,PIC-2503,
CD pick-up Photo IC:PIC-2410,PIC-3005
复位IC(RESET IC):BMR-0101C,BMR-0101D,BMR-0101E,BMR-0101F,BMR-0101G,BMR-0101H,BMR-0101I,BMR-0101J,BMR-0101K,BMR-0101L,BMR-0201C,BMR-0201D,BMR-0201E,BMR-0201F,BMR-0201G,BMR-0201H,BMR-0201I,BMR-0201J,BMR-0201K,BMR-0201L,BMR-0301C,BMR-0301D,BMR-0301E,BMR-0301F,BMR-0301G,BMR-0301H,BMR-0301I,BMR-0301J,BMR-0301K,BMR-0301L,BMR-0302C,BMR-0302D,BMR-0302E,BMR-0302F,BMR-0302G,BMR-0302H,BMR-0302I,BMR-0302J,BMR-0302K,BMR-0302L,BMR-0401C,BMR-0401D,BMR-0401E,BMR-0401F,BMR-0401G,BMR-0401H,BMR-0401I
红外线接收头:
KSM-603LM,KSM803LM,PIC37-43LM,KSM-903LM
更多更详细的产品资料请来电来信咨询!
联系方式:
公司:广州创光电子有限公司
地址:广州市芳村区花地大道中89号芳村金融大厦5楼
联系人:覃(QIN)松艺 先生
电话:020-81615486-808  81615589  81615485
手机:13332892276
传真:020-81615489
http://www.bright-gz.com
E-mail:opto163@126.com
