查看: 3982|回复: 8
LAS-CAD软件下载
发表于 2007-10-31 18:40:51 | 显示全部楼层 |阅读模式
LAS-CAD激光腔体设计软件演示版本 y5F+~z }{
]=t}8H
下载地址:https://www.las-cad.com/lascad_download.php ;4!H- qZ
发表于 2007-10-31 19:03:41 | 显示全部楼层
演示版比正式版功能差多少呀?
发表于 2007-10-31 21:11:02 | 显示全部楼层
路过。演示的也看看。先
 楼主| 发表于 2007-11-1 14:52:00 | 显示全部楼层
演示版有些功能不能用,据称,我也刚开始学这个软件呢!
发表于 2008-2-27 12:26:52 | 显示全部楼层
下不下来!开始特慢,后来错误!
发表于 2008-2-27 14:01:23 | 显示全部楼层
Screenshots of LASCAD
Please click on the images for a larger version.
Graphical user interface of LASCAD
Temperature distribution in an end pumped rod
Deformation of an end pumped rod
zz component of stress in an end pumped rod
Parabolic fit of refractive index
Coupling into a graded index fiber
Convergence of beam radius with laser cavity iteration
Intensity profile at outcoupling mirror
Phase profile at outcoupling mirror
Spectrum of transverse eigenfrequencies
Stability diagram
Overlap of laser modes and pump beam
Laser power output
TEM22 Eigenmode
Heat load in a end pumped rod
Heat load in a end pumped bloc with undoped end-capes
Heat load in a rod pumped from 3 sides
Heat load in a rod pumped from 2 sides
Dual end pumped rod with undoped endcapes
Absorbed pump power and temperature distribution in a sandwiched slab pumped from two sides
Flashlamp pumping ZEMAX
发表于 2008-2-29 16:57:54 | 显示全部楼层
演示版中振荡激光波长和腔内元件数被锁死了,这就是区别。
发表于 2009-5-27 10:57:04 | 显示全部楼层
为什么就没有PIRATE的呢?
发表于 2009-5-27 14:24:03 | 显示全部楼层
因为需要一个“密钥”所以一般没有盗版的,国内有人代理卖这个软件。还是很强大的,个人觉得有FEA分析是在是太方便了。
